Home » Modeling » TMF (Xtext) » Is Xtext good solution for my project?
Is Xtext good solution for my project? [message #761689] Tue, 06 December 2011 17:15 Go to next message
We currently have a GEF+EMF based solution to create a process flow that describes relationships between objects. This works well for small to medium flows, but for flows that are getting too big (100+ objects) GUI solution does not work quite well sometimes. I was thinking about using Xtext to create a DSL that would allow users to express their process flows through code.
My question is would I be able to create both graphical and code representations of the flow? Would the user be able to edit GUI flow and the change be applied to DSL counterpart and vise-versa? Is this even a good approach for GUI flows or should I spend time introducing logical blocks to the flow where parts of it could be moved to different subflows?
Alex
Re: Is Xtext good solution for my project? [message #762539 is a reply to message #761689] Thu, 08 December 2011 04:10 Go to previous message
Jep, that's all possible, thanks to the fact that Xtext is based on EMF.
Have a look at the docs, especially
http://www.eclipse.org/Xtext/documentation/2_1_0/210-emf-integration.php
Nevertheless, the deeper you integrate the different editors (textual
and graphical) the better you have to know the underlying technologies.
Building a GMF editor that actually writes its semantic model in an
Xtext based syntax is easy, making two different editors edit the same
model at the same time is a lot harder.
Am 06.12.11 23:15, schrieb Alex:
> Hello,
> flows through code.
> Alex
Previous Topic:Dynamic grammar
Next Topic:separate spec generation from model
Current Time: Mon Jul 28 16:35:55 EDT 2025
Powered by FUDForum. Page generated in 0.06036 seconds
