Home » Newcomers » Newcomers » Uncertain of what component in Eclipse against which to file bug
Uncertain of what component in Eclipse against which to file bug [message #762113] Wed, 07 December 2011 10:08 Go to next message
I've stumbled upon, played around with, and discussed a problem that has
turned out to be a bug in Eclipse's ant implementation. I don't mind
making the Bugzilla entry and I can log in, begin creating it, but I
just don't know which Eclipse component to lodge it against.
Thanks for your suggestion,
Russ
Here's the substance:
It concerns being able to ant-contrib into the mix for a build.xml and
the manifestation of the problem is a nasty, ugly error message in the
Ant view. The build.xml nevertheless works fine in Eclipse just as it
does from command-line ant.
<!-- Work-around: uncomment the following dummy property definition:
<property name="eclipse_bug"
value="make Eclipse not complain about pulling in ant-contrib" />
<taskdef resource="net/sf/antcontrib/antcontrib.properties">
<classpath>
<pathelement location="${ant.library.dir}/ant-contrib-1.0b3.jar" />
</classpath>
</taskdef>
It doesn't matter whether the ant-contrib JAR is placed local to the
project (how I've decided to do it) or dropped into your formal ant
download/installation (which I also tried and that is depicted in this
example).
An illustration of the Ant view can be had at:
http://stackoverflow.com/questions/8406332/ant-contrib-needed-in-1-8-2-build-xml-but-causes-errors/8414132#8414132
Re: Uncertain of what component in Eclipse against which to file bug [message #762529 is a reply to message #762113] Thu, 08 December 2011 03:49 Go to previous messageGo to next message
> has turned out to be a bug in Eclipse's ant implementation. I don't
> mind making the Bugzilla entry and I can log in, begin creating it,
> but I just don't know which Eclipse component to lodge it against.
http://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform&component=Ant
Dani
> Russ
> ant-contrib" />
> <classpath>
> </classpath>
> </taskdef>
> example).
Re: Uncertain of what component in Eclipse against which to file bug [message #762532 is a reply to message #762529] Thu, 08 December 2011 03:55 Go to previous message
Sorry, the above link doesn't work. It's Platform Ant. Log in to
bugzilla and then
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform&component=Ant
Dani
> Dani
>> Russ
>> and the manifestation of the problem is a nasty, ugly error message
>> in the Ant view. The build.xml nevertheless works fine in Eclipse
>> just as it does from command-line ant.
>> ant-contrib" />
>> <classpath>
>> </classpath>
>> </taskdef>
>> this example).
Previous Topic:Articles and Downloads for Eclipse Beginners
Next Topic:Java programming Questions
Current Time: Sun Jul 27 11:15:42 EDT 2025
Powered by FUDForum. Page generated in 0.08166 seconds
