Home » Modeling » TMF (Xtext) » [Xtext 2.2] NPE in JvmMemberRenameStrategy in a JDT project
[Xtext 2.2] NPE in JvmMemberRenameStrategy in a JDT project [message #762355] Wed, 07 December 2011 18:40 Go to next message
Greetings,
I upgraded to Xtext 2.2 (v2.2.0.v201112071226) this morning in Eclipse 3.7.1. I'm doing a simple rename refactoring in a JDT project (a project that does not have any Xtext-related files) and refactoring fails with the following stack trace:
ava.lang.NullPointerException
	at org.eclipse.xtext.common.types.ui.refactoring.participant.JvmMemberRenameStrategy.setName(JvmMemberRenameStrategy.java:56)
	at org.eclipse.xtext.common.types.ui.refactoring.participant.JvmMemberRenameStrategy.revertDeclarationChange(JvmMemberRenameStrategy.java:51)
	at org.eclipse.xtext.ui.refactoring.impl.RenamedElementTracker.renameAndTrack(RenamedElementTracker.java:39)
	at org.eclipse.xtext.ui.refactoring.impl.RenameElementProcessor.checkFinalConditions(RenameElementProcessor.java:208)
	at org.eclipse.xtext.ui.refactoring.impl.AbstractProcessorBasedRenameParticipant.checkConditions(AbstractProcessorBasedRenameParticipant.java:113)
	at org.eclipse.ltk.core.refactoring.participants.ProcessorBasedRefactoring.checkFinalConditions(ProcessorBasedRefactoring.java:257)
	at org.eclipse.ltk.core.refactoring.CheckConditionsOperation.run(CheckConditionsOperation.java:85)
	at org.eclipse.ltk.core.refactoring.CreateChangeOperation.run(CreateChangeOperation.java:121)
	at org.eclipse.ltk.core.refactoring.PerformChangeOperation.run(PerformChangeOperation.java:209)
	at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
	at org.eclipse.ltk.internal.ui.refactoring.WorkbenchRunnableAdapter.run(WorkbenchRunnableAdapter.java:87)
	at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
Is anybody seeing the same?
-Alex
[Updated on: Wed, 07 December 2011 18:41] by Moderator
Re: [Xtext 2.2] NPE in JvmMemberRenameStrategy in a JDT project [message #762358 is a reply to message #762355] Wed, 07 December 2011 18:48 Go to previous messageGo to next message
The same operation (Java enum renaming) throws the following error in Xtext 2.1.1 (but at least the rename succeeds)
java.lang.StringIndexOutOfBoundsException: String index out of range: -1
	at java.lang.String.substring(String.java:1949)
	at org.eclipse.xtext.common.types.access.impl.AbstractClassMirror.getEObject(AbstractClassMirror.java:85)
	at org.eclipse.xtext.common.types.access.impl.AbstractClassMirror.getEObject(AbstractClassMirror.java:86)
	at org.eclipse.xtext.common.types.access.TypeResource.getEObject(TypeResource.java:54)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObject(ResourceSetImpl.java:219)
	at org.eclipse.xtext.common.types.ui.refactoring.participant.JvmMemberRenameStrategy.setName(JvmMemberRenameStrategy.java:55)
	at org.eclipse.ltk.core.refactoring.Refactoring.checkAllConditions(Refactoring.java:160)
	at org.eclipse.jdt.internal.ui.refactoring.RefactoringExecutionHelper$Operation.run(RefactoringExecutionHelper.java:80)
	at org.eclipse.jdt.internal.core.BatchOperation.executeOperation(BatchOperation.java:39)
	at org.eclipse.jdt.internal.core.JavaModelOperation.run(JavaModelOperation.java:728)
	at org.eclipse.jdt.core.JavaCore.run(JavaCore.java:4873)
	at org.eclipse.jdt.internal.ui.actions.WorkbenchRunnableAdapter.run(WorkbenchRunnableAdapter.java:106)
Re: [Xtext 2.2] NPE in JvmMemberRenameStrategy in a JDT project [message #762361 is a reply to message #762358] Wed, 07 December 2011 18:57 Go to previous messageGo to next message
It seems that the problem only happens when renaming a Java enum. I just renamed an interface and a class without problems. Sorry for being lazy and not finding out myself but...is this a known bug?
-Alex
Re: [Xtext 2.2] NPE in JvmMemberRenameStrategy in a JDT project [message #762537 is a reply to message #762361] Thu, 08 December 2011 04:00 Go to previous messageGo to next message
Alex,
please file a ticket. This looks rather critical to me.
Sebastian
Am 08.12.11 00:57, schrieb Alex Ruiz:
> -Alex
Re: [Xtext 2.2] NPE in JvmMemberRenameStrategy in a JDT project [message #762597 is a reply to message #762537] Thu, 08 December 2011 06:08 Go to previous messageGo to next message
I've filed a bug for this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=366005
Re: [Xtext 2.2] NPE in JvmMemberRenameStrategy in a JDT project [message #763440 is a reply to message #762597] Fri, 09 December 2011 14:16 Go to previous message
Thanks Sebastian and Jan Smile
Previous Topic:[xtend2.2] Semantics of "it" with "switch"
Next Topic:content assist across files
Current Time: Sun Jul 27 07:57:43 EDT 2025
Powered by FUDForum. Page generated in 0.04004 seconds
