Home » Modeling » TMF (Xtext) » Additional proposal info for content assist
Additional proposal info for content assist [message #643639] Tue, 07 December 2010 12:53 Go to next message
In order to make the info popup appear side-by-side with the content assist popup, one has to set the so-called additional proposal info text in the ConfigurableCompletionProposal.
The easiest way I've found to do this, is, in the MyDSLProposalProvider, to override doCreateProposal as follows:
  protected ConfigurableCompletionProposal doCreateProposal(String proposal,
		StyledString displayString, Image image, int priority,
		ContentAssistContext context) {
	ConfigurableCompletionProposal theproposal = super
					.doCreateProposal(proposal, displayString, image, priority, context);
	if ( /* test the context */)
	        //Calculate the info text
		theproposal.setAdditionalProposalInfo(infotext);
	return theproposal;
This has the intended effect, i.e. the extra text is displayed in a popup when scrolling the content assist. However, there are some severe drawbacks:
- not all context information is known at this point, making the recovery of extra info pretty difficult. I'm not sure, for example, that the current candidate EObject or EObjectReference can be found.
- I'm not quite sure it's safe to start digging in the model at that point.
Lastly, it also seems impossible to override the way the info is displayed, in order, for example, to replace the plain text viewer with something more convenient, like a javadoc viewer.
Any thoughts on the subject are welcome.
Re: Additional proposal info for content assist [message #643655 is a reply to message #643639] Tue, 07 December 2010 13:43 Go to previous messageGo to next message
Hi Jerome,
please see below.
Am 07.12.10 18:53, schrieb Jerome:
> @Override
> return theproposal;
> drawbacks:
Right, that is inconvenient.
You could try to replace the
AbstractJavaBasedContentProposalProvider.DefaultProposalCrea tor which
provides access to the target object of a cross link.
It's always safe to navigate the object graphs that are provided by the
context.
You proposal has to implement ICompleteProposalExtension3 in order to
replace the information control creator.
Xtext 2.0 has a very nice solution for this problem. Please feel free to
dig into the code of the master branch.
Sebastian
Re: Additional proposal info for content assist [message #644668 is a reply to message #643639] Mon, 13 December 2010 12:21 Go to previous messageGo to next message
Thanks for the tips.
I ended up extending ConfigurableCompletionProposal with implementation of ICompletionProposalExtension3 and override one doCreateProposal signature in the xtext-created MydslProposalProvider:
			StyledString displayString, Image image, int replacementOffset,
			int replacementLength)
       // create the extended configurable completion proposal
          return new MydslConfigurableCompletionProposal(proposal, displayString, image,
				replacementOffset, replacementLength)
The actual calculation of the additional info text is done in the override of :
public ICompletionProposal apply(IEObjectDescription candidate) {
           ICompletionProposal proposal = super.apply(candidate);
           ConfigurableCompletionProposal castproposal = (ConfigurableCompletionProposal) proposal;
           // calculate help string from the candidate
           castproposal.setAdditionalProposalInfo(helptxt);
           return castproposal;
The MydslConfigurableCompletionProposal then can implement getInformationControlCreator() to create a DefaultInformationControl that supports a small subset of HTML tags, which is not the case in the default 1.0.1 implementation. It also must implement the constructor used above via a super call.
[Updated on: Tue, 14 December 2010 05:04] by Moderator
Re: Additional proposal info for content assist [message #644760 is a reply to message #644668] Tue, 14 December 2010 02:29 Go to previous messageGo to next message
Hi Jerome,
thanks for keeping us posted. However, you messages seems to be
trunkated (see below). Would you mind to repost it so others can use
your solution as a reference?
Sebastian
Am 13.12.10 18:21, schrieb Jerome:
> override of public ICompletionProposal apply(IEObjectDescription candidate)
> Apparently, there is no need to inject anything more than
Re: Additional proposal info for content assist [message #644811 is a reply to message #643639] Tue, 14 December 2010 05:05 Go to previous messageGo to next message
Yes, I had made a mistake in pressing the publish button too quickly. The message is now up to date.
Re: Additional proposal info for content assist [message #761592 is a reply to message #644668] Tue, 06 December 2011 12:46 Go to previous message
jerome.fouletier wrote on Mon, 13 December 2010 12:21
Exist another InformationControl that support all the html tags?
I tryed to test the BrowserInformationControl but i get "DiscouragedAccess".
EDIT:
I solved that adding this class in my project http://java2s.com/Open-Source/Java-Document/IDE-Eclipse/pde/org/eclipse/pde/internal/ui/editor/contentassist/display/BrowserInformationControl.java.htm
EDIT2:
Is not solved, the BrowserInformationControl support all html tags, but not work properly, the content assist close if i try to scroll.
EDIT3:
Apparently "discourage warning" not affect the use of BrowserInformationControl, i did not know that, sorry. Its working.
Me -> Noob
Ignore the post.
[Updated on: Tue, 06 December 2011 15:21] by Moderator
Previous Topic:String to Integer Conversion in Xtend2
Next Topic:Folding woes
Current Time: Fri Jul 18 06:03:37 EDT 2025
Powered by FUDForum. Page generated in 0.10834 seconds
