Home » Eclipse Projects » Eclipse 4 » "Handler service cannot be null" exception in launching eclipse product.(Handler service cannot be null execption while launching an application from eclipse 4.1.1)
"Handler service cannot be null" exception in launching eclipse product. [message #761451] Tue, 06 December 2011 08:49 Go to next message
I am working on upgrading eclipse application from 3.2 to eclipse 4.1.1
buildId=M20110912-1510
java.version=1.6.0_12
When I will try to launch the eclipse it throws following exception
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.NullPointerException: The handler service cannot be null
at
org.eclipse.ui.internal.commands.WorkbenchCommandSupport.<init>(WorkbenchCommandSupport.java:75)
at
org.eclipse.ui.internal.Workbench.initializeDefaultServices(Workbench.java:1893)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1526)
at org.eclipse.ui.internal.Workbench.access$36(Workbench.java:1481)
at org.eclipse.ui.internal.Workbench$66.run(Workbench.java:2592)
at
at
I had tried many configuration settings but still no luck. Can anyone know the cause of this exception?
Please let me know if there is any guide available to upgrade from 3.2 to 4.1.1
Re: "Handler service cannot be null" exception in launching eclipse product. [message #787367 is a reply to message #761451] Tue, 31 January 2012 08:59 Go to previous message
I think you are missing required bundles for the compatibility mode.
See my Eclipse 4 and the Compatibility Layer - Tutorial tutorial.
Previous Topic:Given a view id can I find the Perspective(s) it is in
Next Topic:Is E4 - XWT stable or is it still under development
Current Time: Sat Jul 26 10:13:37 EDT 2025
Powered by FUDForum. Page generated in 0.07583 seconds
