Home » Archived » BIRT » Reg: Grid lines in Excel files(Reg: Grid lines in Excel files)
Reg: Grid lines in Excel files [message #761389] Tue, 06 December 2011 07:03 Go to next message
We are using Native Excel emitter to generate excel files and we are getting the xls files generated, but we are not getting any grid lines in the excel files.
Below is the code used to generate the excel files:
EXCELRenderOption options = new EXCELRenderOption();
options.setOption("excelRenderOption.hideGridlines",false);
options.setOption("fixed_column_width",true);
options.setWrappingText(true);
options.setEnableMultipleSheet(false);
options.setEmitterID("org.eclipse.birt.report.engine.emitter.nativexls");
options.setOutputFormat(ReportingConstants.OUTPUT_TYPE_XLS);
options.setOutputFileName(buildDocumentName(workingFolder, jobBo, ReportingConstants.OUTPUT_TYPE_XLS));
task1 = birtReportEngine.createRenderTask(document);
task1.setRenderOption(options);
task1.render();
In spite of setting options.setOption("excelRenderOption.hideGridlines",false); we are getting grid lines in the excel.
Any thoughts on how to get the grid lines in the excel file.
KKP
Re: Reg: Grid lines in Excel files [message #761570 is a reply to message #761389] Tue, 06 December 2011 12:08 Go to previous messageGo to next message
Can you reproduce with report against the sample db and post the report
and output? BTW what version of BIRT are you using?
Jason
On 12/6/2011 7:03 AM, kkp wrote:
> in the excel files.
> task1.render();
> In spite of setting
> KKP
Re: Reg: Grid lines in Excel files [message #761625 is a reply to message #761570] Tue, 06 December 2011 14:07 Go to previous messageGo to next message
Jason,
Below is the environment in which our reports run:
Birt:3.7
Weblogic:10.0.2
Jdk:1.5
Linux
Oracle 1g.
We are generating usinng birt tld.Shall post sample rptdesign and excel file.
KKP
Re: Reg: Grid lines in Excel files [message #761977 is a reply to message #761389] Wed, 07 December 2011 06:25 Go to previous messageGo to next message
Jason,
Please find attached sample rptdesign and excel documents.
Birt:3.7
Weblogic:10.0.2
Jdk:1.5
Linux
Oracle 1g.
KKP
Re: Reg: Grid lines in Excel files [message #762232 is a reply to message #761977] Wed, 07 December 2011 13:37 Go to previous messageGo to next message
I tried this with the re api and it worked for me. Can you look at the
attached output and source I used?
Jason
On 12/7/2011 6:25 AM, kkp wrote:
> Jason,
> Birt:3.7
> Weblogic:10.0.2
> Jdk:1.5
> Linux
> Oracle 1g.
> KKP
Re: Reg: Grid lines in Excel files [message #762431 is a reply to message #762232] Wed, 07 December 2011 22:36 Go to previous messageGo to next message
Jason,
in the source you used, the excel is generated using default birt excel emitter api, we are using native excel emitter api and the version of re api is from birt 3.7.
Could you please try once with below code and let us know if its worked.
Also the grid lines from the xls file attached are not visible in excel2003 version.
> task1.render();
KKP
[Updated on: Wed, 07 December 2011 22:39] by Moderator
Re: Reg: Grid lines in Excel files [message #762888 is a reply to message #762431] Thu, 08 December 2011 14:20 Go to previous messageGo to next message
Jason,
Could you please advise on how to get grid lines displayed in excel.
Re: Reg: Grid lines in Excel files [message #762900 is a reply to message #762888] Thu, 08 December 2011 14:30 Go to previous messageGo to next message
Where did you download the native excel emitter from and what version
are you using?
Jason
On 12/8/2011 2:20 PM, kkp wrote:
> Jason,
Re: Reg: Grid lines in Excel files [message #762902 is a reply to message #762900] Thu, 08 December 2011 14:38 Go to previous messageGo to next message
I have downloaded from below link:
http://code.google.com/a/eclipselabs.org/p/native-excel-emitter-birt-plugin/
Re: Reg: Grid lines in Excel files [message #762912 is a reply to message #762902] Thu, 08 December 2011 14:56 Go to previous messageGo to next message
Can you use go to this page:
http://www.birt-exchange.org/org/devshare/designing-birt-reports/1421-native-excel-emitter-plugin-for-birt/
And ask the question in the comments?
Jason
Re: Reg: Grid lines in Excel files [message #763214 is a reply to message #762912] Fri, 09 December 2011 06:10 Go to previous messageGo to next message
Jason,
Thanks it worked.
-KKP
Re: Reg: Grid lines in Excel files [message #844641 is a reply to message #761389] Sat, 14 April 2012 03:14 Go to previous messageGo to next message
I have tried using "Native Excel Emitter Plug-in for BIRT".I am using BIRT 3.7 and org.eclipse.birt.report.engine.emitter.nativexls_1.0.0.201110122114. I have followed the following steps.
1) remove the following files
• org.eclipse.birt.report.engine.emitter.prototype.excel_3.7.0.v20110602
• org.eclipse.birt.report.engine.emitter.excel.config_3.7.0.v20110602
from eclipse\plugins folder.
2) Copy org.eclipse.birt.report.engine.emitter.nativexls_1.0.0.201110122114.jar to eclipse\plugins folder.
But the chart/image is not coming when I export the report in a excel file.
Could anyone help me regarding this.
Re: Reg: Grid lines in Excel files [message #846978 is a reply to message #844641] Mon, 16 April 2012 19:12 Go to previous message
This worked for me. Can you try starting eclipse with the -clean option?
Jason
> BIRT 3.7 and
> 2) Copy
> to eclipse\plugins folder. But the chart/image is not coming when I
Previous Topic:Is there way to create accessible reports in BIRT?
Next Topic:Mapping a Single Report Param to 2 query params
Current Time: Wed Sep 03 15:03:38 EDT 2025
Powered by FUDForum. Page generated in 0.04973 seconds
