Home » Modeling » OCL » CompleteOCL validation step by step
CompleteOCL validation step by step [message #761332] Tue, 06 December 2011 04:55 Go to next message
Hi there,
I want to programmatically call CompleteOCL validation on my EMF model
instances.
However, I want to have control in my App about which OCL invariants
from the big OCL file are executed. Is it possible to validate only a
specific set of invariants?
Rationale: I want to create a big library of constraints and want to
enable the user to choose only a small subset of them.
Hauke
Re: CompleteOCL validation step by step [message #761349 is a reply to message #761332] Tue, 06 December 2011 05:34 Go to previous message
Hi Hauke
A substantial debug/validation control GUI is on the to-do list. See
http://wiki.eclipse.org/MDT/OCL/Debugger for draft ideas. All
contributions welcome.
For now, Topcased adds an OCL Validation Control layer. You might find
that they do what you want or provide something you can work with. But I
don't think they've moved on to the new PIvot model used by the Xtext
editors yet.
Thinking quickly about the underlying technology. Either the standard
validator is used, in which case unwanted constraints must detect that
they're disabled, or a custom validator is used allowing unwanted
constraints to be ignored. Only a custom validator makes sense, so I
suspect that the solution is to have a new standard validator that
recognises a validation control model in which at least individual
constraints can be enabled/disabled, perhaps have their severities
affected, messages reformatted, target objects filtered ...
You might be able to squeeze all this into the existing validation
context map, but I suspect a new tree traversal is the least of the
difficulties.
Ed Willink
On 06/12/2011 09:55, Hauke Fuhrmann wrote:
> Hi there,
> instances.
> Cheers,
> Hauke
Previous Topic:xtext.completeocl.ui export packages
Next Topic:Run CompleteOCL Validation manually
Current Time: Sat Jul 26 11:48:54 EDT 2025
Powered by FUDForum. Page generated in 0.05518 seconds
