Home » Archived » BIRT » Problem when starting birt platform (migrating to birt 3.7)
Problem when starting birt platform (migrating to birt 3.7) [message #761061] Mon, 05 December 2011 15:44 Go to next message
I am trying to migrate my birt application to 3.7. I have read this guide
http://www.eclipse.org/birt/phoenix/project/notable3.7.php
added the runtime (approx 11 MB) lib to my project (everything compiles
fine) and changed my engine code to:
try {
designConfig = new DesignConfig();
// designConfig.setProperty("BIRT_HOME", path);
Platform.startup(designConfig);
// Platform.startup();
IDesignEngineFactory designFactory = (IDesignEngineFactory)
Platform.createFactoryObject(IDesignEngineFactory.EXTENSION_DESIGN_ENGINE_FACTORY);
IDesignEngine designEngine = designFactory.createDesignEngine(designConfig);
session = designEngine.newSessionHandle(ULocale.ENGLISH);
} catch (Exception e) {
logEngineError(e);
Doing this:
gives:
java.lang.NoClassDefFoundError: org/eclipse/core/runtime/CoreException
at
org.eclipse.birt.core.framework.Platform.createPlatformLauncher(Platform.java:115)
Not starting the Platform results in the below designFactory being null:
Any ideas on how the new pattern should be implemented - its seems that its
not enough to simply change:
to :
Re: Problem when starting birt platform (migrating to birt 3.7) [message #761072 is a reply to message #761061] Mon, 05 December 2011 16:03 Go to previous messageGo to next message
Do you have all the jars from the runtime/ReportEngine/lib directory or
just the BIRT one?
Jason
> try {
> logEngineError(e);
> Doing this:
> gives:
> at
> its not enough to simply change:
> to :
Re: Problem when starting birt platform (migrating to birt 3.7) [message #761087 is a reply to message #761072] Mon, 05 December 2011 16:42 Go to previous messageGo to next message
I am currently working on adding them one by one to minimize the size of my
application. The wierd thing is that the :
org.eclipse.birt.runtime_3.7.1.v20110913-1734.jar
included in the lib folder in the runtime does NOT contain the
CoreException:
Instead I have tried to add:
<dependency>
<groupId>org.eclipse.core</groupId>
<artifactId>org.eclipse.core.runtime</artifactId>
<version>3.6.0.v20100505</version>
<type>jar</type>
<scope>compile</scope>
</dependency>
That fixes that error even though the class is not located in that jar
either. Any ideas on which jar actually contains the CoreException from the
3.7.1 libs?
"Jason Weathersby" wrote in message news:jbjbj5$t2v$2@news.eclipse.org...
just the BIRT one?
Jason
> try {
> logEngineError(e);
> Doing this:
> gives:
> at
> to :
Re: Problem when starting birt platform (migrating to birt 3.7) [message #761089 is a reply to message #761087] Mon, 05 December 2011 16:46 Go to previous message
Found it in :
org.eclipse.equinox.common_3.6.0.v20110523.jar
which is included when including the 3.6.0 version of the o.e.c.runtime.
"Anton" wrote in message news:jbjdst$1v8$1@news.eclipse.org...
CoreException:
<dependency>
<type>jar</type>
</dependency>
3.7.1 libs?
just the BIRT one?
Jason
> try {
> logEngineError(e);
> Doing this:
> gives:
> at
> to :
Previous Topic:what is the system id of the report design?
Next Topic:Can Java and BIRT use same Oracle database session connection
Current Time: Fri Jul 25 09:09:12 EDT 2025
Powered by FUDForum. Page generated in 0.04498 seconds
