NPE in AbstractRecord.get() after failed insert [message #760619] |
Sat, 03 December 2011 10:38  |
I am one of the developers of the Firebird JDBC driver (Jaybird). One of our users reported a NPE in EclipseLink with a project they are working on. I have trouble pinpointing the cause of this error. I hope somebody with knowledge of the inner-workings of EclipseLink can help me out to find out if this problem is caused by Jaybird, if this is a problem in EclipseLink itself or something else.
The error is a NullPointerException which is triggered in org.eclipse.persistence.internal.sessions.AbstractRecord#get(DatabaseField)
Reproduction steps are:
1) User creates a movie with a duplicate title (enter an already existing title and any year, then press 'Sauvegarder')
=> This triggers a unique constraint violation (expected)
2) User then creates a movie with a new (not yet existing) title
=> The new movie is saved (only visible if you rerun the project or access the database in another way)
3) System then refreshes the list of movies
=> This triggers a NullPointerException
I have tried to walk through the code, but I get lost in the complexity of EclipseLink. I have seen this is caused by the classIndicatorField in org.eclipse.persistence.descriptors.InheritancePolicy being null, but I have no idea why it is null. So I hope somebody can give me a hand here.
The reproduction project is available at tracker.firebirdsql.org/browse/JDBC-199 in the attached file CineProg.zip, the database is in the file CINEPROG.FDB. To install and run this project this you will need to install Firebird server, available at www.firebirdsql.org/en/server-packages/
The easiest way to setup the project is to use NetBeans 7 and Glassfish 3.1 and install the maven project from the zip. Then update src/main/setup/glassfish-resources.xml with the location of CINEPROG.FDB on your machine (property databaseName)
The project uses EclipseLink 2.2.0 by default, but I have also tried it with EclipseLink 2.3.1.
The reported error (against EclipseLink 2.3.1) is:
WARNING: A system exception occurred during an invocation on EJB MovieEJB method public java.util.List fr.cinematheque.dao.AbstractFacade.findAll()
javax.ejb.EJBException
at com.sun.ejb.containers.BaseContainer.processSystemException(BaseContainer.java:5194)
at com.sun.ejb.containers.BaseContainer.completeNewTx(BaseContainer.java:5092)
at com.sun.ejb.containers.BaseContainer.postInvokeTx(BaseContainer.java:4880)
at com.sun.ejb.containers.BaseContainer.postInvoke(BaseContainer.java:2039)
at com.sun.ejb.containers.BaseContainer.postInvoke(BaseContainer.java:1990)
at com.sun.ejb.containers.EJBLocalObjectInvocationHandler.invoke(EJBLocalObjectInvocationHandler.java:222)
at com.sun.ejb.containers.EJBLocalObjectInvocationHandlerDelegate.invoke(EJBLocalObjectInvocationHandlerDelegate.java:88)
at $Proxy152.findAll(Unknown Source)
at fr.cinematheque.dao.__EJB31_Generated__MovieEJB__Intf____Bean__.findAll(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at flex.messaging.services.remoting.adapters.JavaAdapter.invoke(JavaAdapter.java:418)
at flex.messaging.services.RemotingService.serviceMessage(RemotingService.java:183)
at flex.messaging.MessageBroker.routeMessageToService(MessageBroker.java:1400)
at flex.messaging.endpoints.AbstractEndpoint.serviceMessage(AbstractEndpoint.java:1005)
at flex.messaging.endpoints.amf.MessageBrokerFilter.invoke(MessageBrokerFilter.java:103)
at flex.messaging.endpoints.amf.LegacyFilter.invoke(LegacyFilter.java:158)
at flex.messaging.endpoints.amf.SessionFilter.invoke(SessionFilter.java:44)
at flex.messaging.endpoints.amf.BatchProcessFilter.invoke(BatchProcessFilter.java:67)
at flex.messaging.endpoints.amf.SerializationFilter.invoke(SerializationFilter.java:166)
at flex.messaging.endpoints.BaseHTTPEndpoint.service(BaseHTTPEndpoint.java:291)
at flex.messaging.MessageBrokerServlet.service(MessageBrokerServlet.java:353)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
at org.apache.catalina.core.StandardWrapper.service(StandardWrapper.java:1534)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:281)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
at org.apache.catalina.core.StandardPipeline.doInvoke(StandardPipeline.java:655)
at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:595)
at com.sun.enterprise.web.WebPipeline.invoke(WebPipeline.java:98)
at com.sun.enterprise.web.PESessionLockingStandardPipeline.invoke(PESessionLockingStandardPipeline.java:91)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:162)
at org.apache.catalina.connector.CoyoteAdapter.doService(CoyoteAdapter.java:326)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:227)
at com.sun.enterprise.v3.services.impl.ContainerMapper.service(ContainerMapper.java:170)
at com.sun.grizzly.http.ProcessorTask.invokeAdapter(ProcessorTask.java:822)
at com.sun.grizzly.http.ProcessorTask.doProcess(ProcessorTask.java:719)
at com.sun.grizzly.http.ProcessorTask.process(ProcessorTask.java:1013)
at com.sun.grizzly.http.DefaultProtocolFilter.execute(DefaultProtocolFilter.java:225)
at com.sun.grizzly.DefaultProtocolChain.executeProtocolFilter(DefaultProtocolChain.java:137)
at com.sun.grizzly.DefaultProtocolChain.execute(DefaultProtocolChain.java:104)
at com.sun.grizzly.DefaultProtocolChain.execute(DefaultProtocolChain.java:90)
at com.sun.grizzly.http.HttpProtocolChain.execute(HttpProtocolChain.java:79)
at com.sun.grizzly.ProtocolChainContextTask.doCall(ProtocolChainContextTask.java:54)
at com.sun.grizzly.SelectionKeyContextTask.call(SelectionKeyContextTask.java:59)
at com.sun.grizzly.ContextTask.run(ContextTask.java:71)
at com.sun.grizzly.util.AbstractThreadPool$Worker.doWork(AbstractThreadPool.java:532)
at com.sun.grizzly.util.AbstractThreadPool$Worker.run(AbstractThreadPool.java:513)
at java.lang.Thread.run(Thread.java:662)
at org.eclipse.persistence.internal.sessions.AbstractRecord.get(AbstractRecord.java:276)
at org.eclipse.persistence.descriptors.InheritancePolicy.classFromRow(InheritancePolicy.java:336)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObject(ObjectBuilder.java:485)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObject(ObjectBuilder.java:456)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.buildObject(ObjectLevelReadQuery.java:723)
at org.eclipse.persistence.queries.ReadAllQuery.registerResultInUnitOfWork(ReadAllQuery.java:742)
at org.eclipse.persistence.queries.ReadAllQuery.executeObjectLevelReadQuery(ReadAllQuery.java:423)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeDatabaseQuery(ObjectLevelReadQuery.java:1080)
at org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:808)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute(ObjectLevelReadQuery.java:1040)
at org.eclipse.persistence.queries.ReadAllQuery.execute(ReadAllQuery.java:383)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeInUnitOfWork(ObjectLevelReadQuery.java:1126)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:2842)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1521)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1503)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1477)
at org.eclipse.persistence.internal.jpa.EJBQueryImpl.executeReadQuery(EJBQueryImpl.java:484)
at org.eclipse.persistence.internal.jpa.EJBQueryImpl.getResultList(EJBQueryImpl.java:741)
at fr.cinematheque.dao.AbstractFacade.findAll(AbstractFacade.java:41)
at org.glassfish.ejb.security.application.EJBSecurityManager.runMethod(EJBSecurityManager.java:1052)
at org.glassfish.ejb.security.application.EJBSecurityManager.invoke(EJBSecurityManager.java:1124)
at com.sun.ejb.containers.BaseContainer.invokeBeanMethod(BaseContainer.java:5367)
at com.sun.ejb.EjbInvocation.invokeBeanMethod(EjbInvocation.java:619)
at com.sun.ejb.containers.interceptors.AroundInvokeChainImpl.invokeNext(InterceptorManager.java:801)
at com.sun.ejb.EjbInvocation.proceed(EjbInvocation.java:571)
at org.jboss.weld.ejb.SessionBeanInterceptor.aroundInvoke(SessionBeanInterceptor.java:46)
at com.sun.ejb.containers.interceptors.AroundInvokeInterceptor.intercept(InterceptorManager.java:862)
at com.sun.ejb.containers.interceptors.SystemInterceptorProxy.doAround(SystemInterceptorProxy.java:162)
at com.sun.ejb.containers.interceptors.SystemInterceptorProxy.aroundInvoke(SystemInterceptorProxy.java:144)
at com.sun.ejb.containers.interceptors.InterceptorManager.intercept(InterceptorManager.java:371)
at com.sun.ejb.containers.BaseContainer.__intercept(BaseContainer.java:5339)
at com.sun.ejb.containers.BaseContainer.intercept(BaseContainer.java:5327)
at com.sun.ejb.containers.EJBLocalObjectInvocationHandler.invoke(EJBLocalObjectInvocationHandler.java:214)
... 44 more
[Updated on: Sat, 03 December 2011 10:39] by Moderator
FUDForum. Page generated in 0.04091 seconds
