Re: Unable to see EGL Web Project [message #762943 is a reply to message #760808] |
Thu, 08 December 2011 15:58  |
Hi Jan,
Once you create an EGL project using either of the Web 2.0 project templates (or the Hello World template), the Dojo widgets (org.eclipse.edt.rui.dojo) and the Standard widgets and utilities (org.eclipse.edt.rui.widgets) projects should be loaded into your workspace. As you are going through the New EGL Project wizard, you should see a page for Library settings where these projects are listed. (There is no need to separately load the Dojo toolkit into your workspace.)
For more advanced folks -- If you want to use a remote implementation of Dojo, select "0.7.0 (Dojo 1.6.1 Remote)" from the Version column on the Dojo widgets row of the Library list. Note, the remote Dojo requires an Internet connection and a Google API key to be inserted into the /WebContent/config/includeDojo.html file of the org.eclipse.edt.rui.dojo.remote project.
The project's EGL build path (under Properties) will be automatically set to depend on the library projects selected.
Hope this helps!
Theresa
FUDForum. Page generated in 0.30095 seconds
