Home » Archived » XML Schema Definition (XSD) » Is XSD2Ecore able to handle *.xsd files with multiple depedencies ?
Is XSD2Ecore able to handle *.xsd files with multiple depedencies ? [message #76028] Mon, 27 October 2008 12:02 Go to next message
Hi!
I used XSD2Ecore to create *.ecore files out of *.xsds.
Concretely these:
XMLSchema.xsd (http://www.w3.org/2001/XMLSchema)
WSDL.xsd (http://schemas.xmlsoap.org/wsdl/)
SOAP.xsd (http://schemas.xmlsoap.org/wsdl/soap/)
These are the official W3C files, I did not alter them in any way.
WSDL.xsd is using elments of XMLSchema.xsd.
SOAP.xsd is using elements of both, XMLSchema.xsd and WSDL.xsd.
Now here comes the problem: when converting WSDL.xsd to ecore no
XMLSchema.ecore is required. The same happens, when I convert SOAP.xsd
to ecore. Like expected I have to specify the WSDL.ecore. But I dont
have to specify the XMLSchema.ecore.
Like I said, WSDL.xsd and SOAP.xsd use several elements from XMLSchema.xsd
but when I want to generate the ecore file, I dont have to specify the
appropriate XMLSchema.ecore. Why not ? Is it even possible to generate
an ecore file for a *.xsd file which is depedent on more then one other
*.xsd
file ?
Thanks in advance,
Tim
Re: Is XSD2Ecore able to handle *.xsd files with multiple depedencies ? [message #76046 is a reply to message #76028] Mon, 27 October 2008 12:35 Go to previous messageGo to next message
Tim,
Comments below.
Tim Brömme wrote:
> Hi!
> Concretely these:
Neither of these schemas import XMLSchema.xsd so they don't depend on that.
> WSDL.xsd is using elments of XMLSchema.xsd. SOAP.xsd is using elements
Maybe I'm missing something, but I just don't see imports.
> XMLSchema.xsd
Can you point out specifically an example of what you mean?
> other *.xsd
> file ?
Keep in mind that XMLTypedPackage provides all the built-in types for
XML Schema, so if you're just using built-in types, you don't need an
Ecore build for that because there's a built-in model/package for it.
> Thanks in advance,
> Tim
Re: Is XSD2Ecore able to handle *.xsd files with multiple depedencies ? [message #76062 is a reply to message #76046] Wed, 29 October 2008 07:33 Go to previous messageGo to next message
I think I used the word "depend" wrong :)
What I meant is, that all the files declare namepaces,
to use elements which they don't define by themselves.
Exaple:
>SOAP.xsd
>xmlns:xs="http://www.w3.org/2001/XMLSchema
>xmlns:wsdl="http://schemas.xmlsoap.org/wsdl/
><xs:extension base="wsdl:tExtensibilityElement" >
SOAP.xsd uses elements from the namespaces of the XMLSchema and WSDL.
In this case "extension", which is originally from XMLSchema.xsd
and "tExtensibilityElement", which is part of the WSDL.xsd.
So I would expect, when I convert the SOAP.xsd to *.ecore, that
the resulting *.ecore has references to the appropiate metamodels,
in which the elements are, it uses.
But instead the obove example creates an "Extended Meta Data" Element,
which has no references or indicators, that this element is part
of another metamodel.
Thanks for your help,
Tim
Re: Is XSD2Ecore able to handle *.xsd files with multiple depedencies ? [message #76080 is a reply to message #76062] Wed, 29 October 2008 07:56 Go to previous message
--------------020008050903080205080302
Tim,
Comments below.
Tim Br
Re: Is XSD2Ecore able to handle *.xsd files with multiple depedencies ? [message #603376 is a reply to message #76028] Mon, 27 October 2008 12:35 Go to previous message
Tim,
Comments below.
Tim Brömme wrote:
> Hi!
> Concretely these:
> XMLSchema.xsd
> other *.xsd
> file ?
> Thanks in advance,
> Tim
Re: Is XSD2Ecore able to handle *.xsd files with multiple depedencies ? [message #603381 is a reply to message #76046] Wed, 29 October 2008 07:33 Go to previous message
Exaple:
>SOAP.xsd
Tim
Re: Is XSD2Ecore able to handle *.xsd files with multiple depedencies ? [message #603384 is a reply to message #76062] Wed, 29 October 2008 07:56 Go to previous message
Tim,
Comments below.
Tim Br
Previous Topic:Is XSD2Ecore able to handle *.xsd files with multiple depedencies ?
Next Topic:Finding possible values for enumerations from XSD
Current Time: Thu Sep 04 12:30:49 EDT 2025
Powered by FUDForum. Page generated in 0.09935 seconds
