Home » Archived » BIRT » How to use a value from one of the
How to use a value from one of the [message #75918] Tue, 20 September 2005 11:12 Go to next message
Originally posted by: ahundal.research.telcordia.com
Hi everyone,
I am new to using BIRT, so maybe the question comes as a naive one.
Can anyone tell me how to use a value from a column of a table ( that i
fetched from the database) to filter data from some other table and
display it? For example, if there are two tables A and B, then after
fetching table A, I want to fetch only those elements from table B that
have the same value as one of the fields of table A.
I would appreciate your help.
Thanks and best regards
Ahsan hundal
Re: How to use a value from one of the [message #75936 is a reply to message #75918] Tue, 20 September 2005 12:02 Go to previous messageGo to next message
Ahsan,
This is probaly better done in the query. If you use any of the filters
available you will have excess rows that are fetched.
Jason Weathersby
BIRT PMC
"Ahsan Hundal" <ahundal@research.telcordia.com> wrote in message
news:4571c63a2addd33d53b3554ca56f4d64$1@www.eclipse.org...
> Hi everyone,
> I am new to using BIRT, so maybe the question comes as a naive one. Can
> have the same value as one of the fields of table A. I would appreciate
> your help.
> Ahsan hundal
Re: How to use a value from one of the [message #75967 is a reply to message #75936] Tue, 20 September 2005 13:19 Go to previous messageGo to next message
Thanks for your response, but i want to use a value fetched from one of
the tables and use it to fetch other records from some other table based
on that value. To accomplish that I would have to create a dynamic query,
which uses values fetched from the other table. How can i accomplish it in
BIRT? Eg. I want a report containing the name of a person in the first
column and then the number of transactions he made in the second. The name
is stored in a separate table and the number of transactions in a separate
and linked through the userId. how do I show it?
Ahsan
Re: How to use a value from one of the [message #75986 is a reply to message #75967] Tue, 20 September 2005 13:40 Go to previous messageGo to next message
If you want only one html table in the output and in the first column all
the users and in the second column all there transactions, why would you not
just put your query in like
select usertable.user, sum(trantable.transactions)
from usertable, trantable
where usertable.userId = trantable.userID
group by usertable.user
If you only want the table to contain one user use a dataset parameter
and usertable.user = ?
I am probally misunderstanding what you want.
Jason Weathersby
BIRT PMC
news:deeacee6a68d9c4c31253eb41ee97281$1@www.eclipse.org...
> Thanks
> Ahsan
Re: How to use a value from one of the [message #76031 is a reply to message #75986] Tue, 20 September 2005 14:49 Go to previous messageGo to next message
Sorry for being a bit ambiguous. Let me clarify to you exactly what i want
to do. The customers table has a list of the customers names and the
customer ids.
Customer Table:
customerId customerName
Now in the transaction table there is customer id and then transaction
id alongwith the time it was created.
Transaction Table:
transactionId customerId timeOfCreation
So what I have to do is to display the customer name and then with the
customers name i need to display the number of transactions he made within
the last day or month. They should be in sync. this should be the HTML
table
CustomerName #ofTransactions
I hope now things wud be more clear.
I would appreciate ur help again and thanks for ur responses.
Best regards
ahsan
Re: How to use a value from one of the [message #76059 is a reply to message #76031] Tue, 20 September 2005 18:07 Go to previous message
Ahsan
This is an example query that should work with MySQL.
select CustomerTable.customerName, CustomerTable.customerId,
count(TransactionTable.transactionId)
from CustomerTable, TransactionTable
where CustomerTable.customerId = TransactionTable.customerId
and DATE_SUB(CURDATE (), INTERVAL 30 DAY) <= TransactionTable.timeOfCreation
group by CustomerTable.customerId
Jason Weathersby
BIRT PMC
news:453b7d904ba78366d7708abe53f0454c$1@www.eclipse.org...
> customer ids. Customer Table:
> Transaction Table:
> table
> Best regards
> ahsan
Previous Topic:Examples
Next Topic:BIRT logging
Current Time: Tue Nov 04 21:11:00 EST 2025
Powered by FUDForum. Page generated in 0.03924 seconds
