Home » Newcomers » Newcomers » Error when opening eclipse
Error when opening eclipse [message #760561] Fri, 02 December 2011 17:08 Go to next message
I downloaded the eclipse IDE for java developers and unzipped the folder to my C drive then edited the eclipse.ini file. Pretty sure it's not correct because when I run the .exe it says
Java was started but returned exit code=13
C:\program Files (x86)\java\jdk1.7.0.01\bin\javaw.exe
-dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx384m
--Xx:maxPermSize=256m
-jar
C:\eclipse\\plugins/org.eclipse.equinox.launcher_1.1.1.R36x_v20101122_1400.jar
-os win32
-arch x86_64
-showsplash
-launcher c:\eclipse.exe
-name Eclipse
-launcher.library
C:\eclipse\\plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.2.R36x_v
20101222\eclipse_1312.dll
-startup
-exitdata a90_58
-product org.eclipse.epp.package.java.product
-vm C:\Program Files(x86)\Java\jdk1.7.0_01\bin\javaw.exe
-vmargs
-Xms40m
-Xmx384m
-XX:MaxPermSize=256m
-jar
and this is what my eclipse.ini looks like...
-startup
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.2.R36x_v20101222
-product
--launcher.defaultActionopenFile
--launcher.XXMaxPermSize256M
-showsplashorg.eclipse.platform
--launcher.XXMaxPermSize256m
-vm
C:\Program Files (x86)\Java\jdk1.7.0_01\bin\javaw.exe
-vmargs
-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx384m
any help is much appreciated.
Re: Error when opening eclipse [message #760563 is a reply to message #760561] Fri, 02 December 2011 18:23 Go to previous messageGo to next message
> -Xms40m
> -Xmx384m
> -jar
> -os win32
> -arch x86_64
> -showsplash
> -name Eclipse
> -launcher.library
> -startup
> -exitdata a90_58
> -vmargs
> -Xms40m
> -Xmx384m
> -jar
> -startup
> --launcher.library
> -product
> -vm
> -vmargs
> -Xms40m
> -Xmx384m
You are trying to run a 64 bit Eclipse on a 32 bit JVM. That won't
work. The bit size has to match between the two. You either have to
install a 64 bit JVM, or download the 32 bit Eclipse version.
Re: Error when opening eclipse [message #760660 is a reply to message #760561] Sat, 03 December 2011 18:20 Go to previous messageGo to next message
> -Xms40m
> -Xmx384m
> -jar
> -os win32
> -arch x86_64
> -showsplash
> -name Eclipse
> -launcher.library
> -startup
> -exitdata a90_58
> -vmargs
> -Xms40m
> -Xmx384m
> -jar
> -startup
> --launcher.library
> -product
> -vm
> -vmargs
> -Xms40m
> -Xmx384m
Are you trying to run a 64-bit Eclipse download on a 32-bit JDK?
Re: Error when opening eclipse [message #760896 is a reply to message #760660] Mon, 05 December 2011 09:29 Go to previous message
I had actually thought about that as i read the error again. I must have just clicked the wrong link for the JDK i'll try installing the 64 bit.
Previous Topic:Ant build after clean not triggering
Next Topic:Does the number of faults in files vary significantly in Eclipse?
Current Time: Sun Nov 09 20:09:21 EST 2025
Powered by FUDForum. Page generated in 0.09880 seconds
