Home » Archived » BIRT » ClassLoader Problem in Event Handler(Two different class loaders used for the type of data item values.)
icon5.gif  ClassLoader Problem in Event Handler [message #760392] Fri, 02 December 2011 04:31 Go to next message
I have an Eclipse project with a report file and a class extending DataItemEventAdapter.
public void onRender(IDataItemInstance data, IReportContext reportContext) throws ScriptException {
	Object value = data.getValue();
Since I'm using the EMF ODA driver, the 'value' in this example is of the type 'org.eclipse.emf.oda.ecore.impl.ResultSet.JavaObject'. Logical step for me is to add the required plug-in (org.eclipse.emf.oda.ecore) as a dependency, so I have the required classes in my class path.
index.php/fa/6313/0/
Now to my problem: When running my report (in designer/preview mode) with this handler and the two lines below, I get a ClassCastException for 'JavaObject'.
JavaObject myObject = (JavaObject) value;
I tried the following to see where the problem is.
try {
	System.out.println("Value CL = " + value.getClass().getClassLoader());
	JavaObject reference = new JavaObject(null);
	System.out.println("Reference CL = " + reference .getClass().getClassLoader());
	reference = (JavaObject) value;
The two objects are not loaded by the same class loader. One is loaded by BIRT, one is loaded by the default OSGI loader. The code above produces the following output:
Value CL = org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader@1417a47
Reference CL = org.eclipse.birt.core.framework.URLClassLoader@1713428
java.lang.ClassCastException: org.eclipse.emf.oda.ecore.impl.ResultSet$JavaObject cannot be cast to org.eclipse.emf.oda.ecore.impl.ResultSet$JavaObject
	at my.Handler.onRender(Handler.java:24)
Am I doing it wrong? Is this a specific problem with the EMF ODA driver? I can't possibly be the first person to try something like that.
Any advice in this matter is appreciated.
Chris
Re: ClassLoader Problem in Event Handler [message #760537 is a reply to message #760392] Fri, 02 December 2011 13:09 Go to previous messageGo to next message
This looks like it may be a bug. Where did you add the dependency?
It may have to be added to the report engine plugin.
Jason
On 12/2/2011 4:31 AM, Christian Weisskopf wrote:
> @Override
> try {
> Chris
Re: ClassLoader Problem in Event Handler [message #762484 is a reply to message #760537] Thu, 08 December 2011 01:50 Go to previous message
Jason,
Thanks for your answer.
My problems were fixed after adding the report engine plugin to my workspace and adding the required dependencies there. Thanks!
-Chris
Previous Topic:BIRT 3.7 - dynamic image from byte[] bound to column
Next Topic:vector rendering of svg in pdf
Current Time: Fri Jul 25 09:52:32 EDT 2025
Powered by FUDForum. Page generated in 0.25917 seconds
