Home » Archived » BIRT » running BIRT viewer within my application(having the BIRT viewer run from within my application)
running BIRT viewer within my application [message #755579] |
Tue, 08 November 2011 15:44  |
hello all,
I have recently started working with BIRT and have created several rptdesigns from within my struts application on a JBOSS server. I have everything installed and have made it so that one of my action classes sends the rptdesign to the birt.war file and it then displays perfectly in my jsp page. up to this point I have not had one bit of trouble, however, I now am faced with the following issue:
the birt.war file is located in my C:\jboss-5.1.0.GA\server\default\deploy folder, while my application is located in C:\Documents and Settings\John\workspace\JohnsApp folder. This is fine and well when testing and running on my own machine because it deploys the viewer through localhost, however, for what I am attempting I need the viewer to be a part of my application. I have searched left, right, up, down and middle on the net and found many situations like this, but unless im misunderstanding some things, I havnt found one that shows where to place what files, or what code to isert into my application to make the viewer a part of my app.
if there is anyone who is familiar with any way to tie the Birt Viewer into a dynamic web application using struts in eclipse I have hit a wall and I am open to any helpful suggestions.
thanks a lot!
-John
Re: running BIRT viewer within my application [message #755594 is a reply to message #755579] |
Tue, 08 November 2011 16:39   |
John,
I may be misunderstanding what you need, but BIRT does have a download
for WTP integration to deploy the viewer in a dynamic web app. Look at
the full build for the release. For example on 3.7.1
http://download.eclipse.org/birt/downloads/build.php?build=R-R1-3_7_1-201109131734
Jason
On 11/8/2011 3:44 PM, jahits88 wrote:
> hello all,
> thanks a lot!
> -John
Re: running BIRT viewer within my application [message #755792 is a reply to message #755594] |
Wed, 09 November 2011 10:36   |
Jason,
first off thanks for your help, however, I did download the updated version and I am still having the same issue. Ill try to explain it better as I can see that my question from before might not make sense.
my issue is that I have my application in a workspace folder. I create the rptdesign files from the application, and store the files within my application. from one of my jsp pages I call the viewer and it is supposed to display the charts. It does, however, it only displays the charts if I copy thier .rptdesign file and paste it in the Birt.war folder( which is located in the JBOSS folder on my C drive ). My problem is that I am trying to have everything work from within my application, so that it will be accesible to anyone using my application, not just the localhost/my computer.
So in essence, i simply need to have the BirtViewer run from within my application, instead of running from out of the Birt.war folder. Is there anyway that I am able to accomplish this so that the files within my application can run from within my application without having to be copied over to a different folder?
Re: running BIRT viewer within my application [message #755866 is a reply to message #755792] |
Wed, 09 November 2011 16:45   |
Is your application a web app or an rcp based application? You can have
the birt.war reference design files outside of the war, but you will
need to set the url report path policy in the web.xml:
Settings for how to deal with the url report path. e.g.
"http://host/repo/test.rptdesign".
Following values are supported:
<all> - All paths.
<domain> - Only the paths with host matches current domain. Note the
comparison is literal, "127.0.0.1" and "localhost" are considered as
different hosts.
<none> - URL paths are not supported.
Defaults to "domain".
<context-param>
<param-name>URL_REPORT_PATH_POLICY</param-name>
<param-value>domain</param-value>
</context-param>
Jason
On 11/9/2011 10:36 AM, jahits88 wrote:
> Jason,
Re: running BIRT viewer within my application [message #760253 is a reply to message #755866] |
Thu, 01 December 2011 12:05   |
I have a similar requirement as John (aka jahits88) does.
My app is an RCP, and would like to add to the RCP the Report Viewer
Servlet http service, but one that I can modify it's configurations like
BIRT_VIEWER_WORKING_FOLDER and BIRT_RESOURCE_PATH so that they are
customized for the localhost environment that my RCP app is installed
on. (To standardize locations and eliminate the need to use absolute
paths within URL parameters when calling the servlet.)
When I install BIRT in my RCP app, I see that I do have a generic
Report Viewer Servlet available as a http service. Is there anyway to
modify it's configuration (via extension points?) and reuse it for my
above requirements?
thanks for any help,
John
> <all> - All paths.
> different hosts.
> <context-param>
> </context-param>
> Jason
>> Jason,
Re: running BIRT viewer within my application [message #760263 is a reply to message #760253] |
Thu, 01 December 2011 12:30   |
The BIRT designer uses the Jetty app server installed in Eclipse to
launch the viewer for previewing reports. Is this what you want your
app to do?
Jason
> When I install BIRT in my RCP app, I see that I do have a generic Report
> Viewer Servlet available as a http service. Is there anyway to modify
> it's configuration (via extension points?) and reuse it for my above
> requirements?
> John
>> <all> - All paths.
>> different hosts.
>> <context-param>
>> </context-param>
>> Jason
>>> Jason,
Re: running BIRT viewer within my application [message #760266 is a reply to message #760263] |
Thu, 01 December 2011 12:35   |
Yes, to access the Report Viewer running in Jetty.
John
> launch the viewer for previewing reports. Is this what you want your app
> to do?
> Jason
>> requirements?
>> John
>>> <all> - All paths.
>>> different hosts.
>>> <context-param>
>>> </context-param>
>>> Jason
>>>> Jason,
>>>> problem
Re: running BIRT viewer within my application [message #760308 is a reply to message #760266] |
Thu, 01 December 2011 15:09   |
Hi Jason,
So is it possible to change the BIRT_VIEWER_WORKING_FOLDER and
BIRT_RESOURCE_PATH on the Report Viewer Servlet running in the BIRT
designer's Jetty app server?
If not could I just create a second http Report Viewer Service, one that
I could change these configuration vars?
thanks,
John
> John
>> to do?
>> Jason
>>> requirements?
>>> John
>>>> <all> - All paths.
>>>> different hosts.
>>>> <context-param>
>>>> </context-param>
>>>> Jason
>>>>> Jason,
>>>>> within my
>>>>> problem
>>>>> application,
>>>>> within
Re: running BIRT viewer within my application [message #760521 is a reply to message #760308] |
Fri, 02 December 2011 11:49   |
John,
Are you including the Report Designer in your project? Or do you just
want the viewer? If you have the designer installed you can set the
resource folder as a preference (Window->preferences->Report
Design->Resource) If you deploy the viewer as part of your app you can
set the resource folder with code. The working folder is a bit more
complicated.
Jason
On 12/1/2011 3:09 PM, John E. Conlon wrote:
> Hi Jason,
> thanks,
> John
>> John
>>> to do?
>>> Jason
>>>> like
>>>> Report
>>>> requirements?
>>>> John
>>>>> have
>>>>> <all> - All paths.
>>>>> different hosts.
>>>>> <context-param>
>>>>> </context-param>
>>>>> Jason
>>>>>> Jason,
>>>>>> sense.
>>>>>> create
>>>>>> within my
>>>>>> the
>>>>>> problem
>>>>>> application,
>>>>>> within my
>>>>>> within
>>>>>> to be
Re: running BIRT viewer within my application [message #760549 is a reply to message #760521] |
Fri, 02 December 2011 14:31   |
Hi Jason,
Yes, I am including the Report Designer and yes and I have been using
> Design->Resource)
Sorry, guess I have not explained my use case very well - What I am
attempting to do is provide my users with Geo-spacial front ends (using
Google Earth or ...) that will allow them to choose a geo placemark
element and from the description balloon, launch element specific BIRT
reports via report parameters and the Report Viewer Servlet. This will
be no problem when our public servers are in place and we have BIRT and
all reports and libraries deployed to the server.
(FWI - To do these things I have already created a BIRT KML Emitter for
generating KML archive documents that build all the links to the Report
Servlet with standard and report specific parameters.)
But we do have scientists that wish to work offline from there own
workbench, since they will be doing the report design work and analysis
with BIRT on their desktop. In this mode from the BIRT Designer there is
absolutely no problem setting up a resource with libraries (using
preference) and launching reports from the Navigator Report popup
menus. Issue is when they wish to generate a KML file with links with
__report parameters that will work in a second localhost environment -
ie __report parms that are NOT absolute.
So we will need to create two different kinds of KML documents with two
different kind of link __report params:
1. Production KML reports with links to BIRT and the Report Viewer with
well known reports and library locations. (Solved)
2. Development KML reports with links to BIRT and the Report Viewer
running on the localhost Jetty. In this scenario, I would like to have
the designers saving dev reports to the BIRT_VIEWER_WORKING_FOLDER and
libraries to 2.1.8 BIRT_RESOURCE_PATH of their specific desktop. Then
the URL __report paramters can be created within the KML documents that
are relative and the __resourceFolder parameter can be omitted.
So I am trying to find out what configures the ReportViewer on the
localhost running under Jetty when the ReportDesigner is installed.
From what I have determined from looking at the configuration of my
Eclipse RCP after it boots:
birt.viewer.root.path=/opt/Verticon/tracker_0.8.0/tracker/plugins/org.eclipse.birt.report.viewer_3.7.1.v20110905/birt/
birt.viewer.working.path=/home/jconlon/workspace/.metadata/.plugins/org.eclipse.birt.report.viewer
Although the birt.viewer.working.path seems to be set, it also appears
to be ignored by the report viewer. Testing the localhost based Report
Viewer (there is a test.rptdesign file in it) shows that the
birt.viewer.root.path is the one that the Report Viewer uses for both
the BIRT_VIEWER_WORKING_FOLDER and BIRT_RESOURCE_PATH.
I tried changing the web.xml configuration in the root.path but that
also does not seem to change the real working path. Any ideas if this
default can be reconfigured from the default?
thanks for all the help,
John
On 12/02/2011 10:49 AM, Jason Weathersby wrote:
> John,
> complicated.
> Jason
>> Hi Jason,
>> thanks,
>> John
>>> John
>>>> app
>>>> to do?
>>>> Jason
>>>>> like
>>>>> Report
>>>>> requirements?
>>>>> John
>>>>>> have
>>>>>> <all> - All paths.
>>>>>> different hosts.
>>>>>> <context-param>
>>>>>> </context-param>
>>>>>> Jason
>>>>>>> Jason,
>>>>>>> sense.
>>>>>>> create
>>>>>>> within my
>>>>>>> the
>>>>>>> problem
>>>>>>> application,
>>>>>>> just
>>>>>>> within my
>>>>>>> within
>>>>>>> to be
Re: running BIRT viewer within my application [message #760573 is a reply to message #760549] |
Sat, 03 December 2011 00:05   |
The issue is the jetty plugin does not use any of the init parameters.
If you set birt.viewer.root.path or
birt.viewer.working.path they will get seen by the system and set
initially. The issue is the resource folder gets overwritten with the
__resourceFolder url parameter which is appended automatically when you
preview the report. If you preview with an external browser(setting in
preferences) you will see it in the url and the location of the report
is self is retrieve from the filepath of the currently opened report.
Jason
On 12/2/2011 2:31 PM, John E. Conlon wrote:
> Hi Jason,
>> Design->Resource)
> preference) and launching reports from the Navigator Report popup menus.
> Issue is when they wish to generate a KML file with links with __report
> parameters that will work in a second localhost environment - ie
> localhost running under Jetty when the ReportDesigner is installed. From
> what I have determined from looking at the configuration of my Eclipse
> RCP after it boots:
> John
>> John,
>> complicated.
>> Jason
>>> Hi Jason,
>>> thanks,
>>> John
>>>> John
>>>>> app
>>>>> to do?
>>>>> Jason
>>>>>> like
>>>>>> Report
>>>>>> requirements?
>>>>>> John
>>>>>>> have
>>>>>>> <all> - All paths.
>>>>>>> different hosts.
>>>>>>> <context-param>
>>>>>>> </context-param>
>>>>>>> Jason
>>>>>>>> Jason,
>>>>>>>> sense.
>>>>>>>> create
>>>>>>>> within my
>>>>>>>> the
>>>>>>>> problem
>>>>>>>> application,
>>>>>>>> just
>>>>>>>> within my
>>>>>>>> within
>>>>>>>> to be
Re: running BIRT viewer within my application [message #764737 is a reply to message #764720] |
Mon, 12 December 2011 14:13  |
Yes it was successful. It is just an older version of BIRT and that is
why your new reports do not work. You could look at this post to see
how to update the BIRT version.
http://www.birt-exchange.org/org/devshare/deploying-birt-reports/743-calling-birt-from-php/
Jason
On 12/12/2011 1:44 PM, singlepoint wrote:
> javaBridge.jar
> php-servlet.jar
> php-script.jar
> I tried another thing, the javaBridge.war which comes bundled with the
> documentation at this location
> sourceforge.net/projects/php-java-bridge/files/Binary%20package/php-java-bridge_6.2.1/
> I tried to use this, it contained a lot of sample birt reports and
> corresponding .php files, then I copied the same directory to my htdocs
> (for apache), surprisingly, sample reports started working. That is, the
> php sample files you included are working fine when deployed in apache.
> And important point is that javaBridge.war contains a lot of jar files
> including birtEngine.jar (not only the above 3 in WEB-INF/lib). Should I
> consider this a successful working of php/java bridge. Only the sample
> reports you provided are working, the reports I designed aren't working,
> it simply says that "error in .rptdesign file etc". What is the
> difference between these javaBridge.war files.
> Regards
Current Time: Sun Jul 27 14:32:51 EDT 2025
Powered by FUDForum. Page generated in 0.08376 seconds
