Home » Archived » BIRT » Cannot render chart to image - possibly a bug
Cannot render chart to image - possibly a bug [message #759715] |
Tue, 29 November 2011 13:00  |
I use birt 2.6.1. I use the example on this page:
http://www.birt-exchange.org/org/wiki/index.php?title=BIRT:Charts2.2
to render a chart to an image but the bottom of the image is missing. Here
is the code:
// DEFINE A CHART STRUCTURE
Chart cm = SampleCharts.createMyChart();
// OBTAIN A PNG IMAGE DEVICE RENDERER
PluginSettings ps = PluginSettings.instance();
IDeviceRenderer idr = null;
try {
idr = ps.getDevice("dv.PNG");
} catch (ChartException pex)
DefaultLoggerImpl.instance().log(pex);
// DEFINE THE BOUNDS IN POINTS
Bounds bo = BoundsImpl.create(0, 0, 800, 600); // IN POINTS
// BUILD THE RENDERED CHART STRUCTURE
Generator gr = Generator.instance();
GeneratedChartState gcs = null;
try {
gcs = gr.build( idr.getDisplayServer(),cm, null,bo, null);
} catch (ChartException gex)
DefaultLoggerImpl.instance().log(gex);
System.exit(0);
// RENDER THE CHART TO A PNG FILE
BufferedImage img = new BufferedImage((int) bo.getWidth(), (int)
bo.getHeight(), BufferedImage.TYPE_INT_ARGB);
idr.setProperty(IDeviceRenderer.CACHED_IMAGE, img);
idr.setProperty(IDeviceRenderer.FILE_IDENTIFIER, "chart.png");
try {
gr.render(idr, gcs);
} catch (ChartException rex)
DefaultLoggerImpl.instance().log(rex);
ImageIcon icon = new ImageIcon(img);
JLabel label = new JLabel(icon, JLabel.CENTER);
JOptionPane.showMessageDialog(null, label, "icon", -1);
The image that is written to disk looks fine though. Its has been up before
and it seems to be a bug:
http://www.eclipse.org/forums/index.php/m/94425/
but I cannot find the bug on the birt bugzilla.
Is this still a bug or has it been fixed in versions > 2.6.1?
Re: Cannot render chart to image - possibly a bug [message #759968 is a reply to message #759715] |
Wed, 30 November 2011 13:32   |
Have you tried the swing viewer examples from the examples view?
Take a look at the attached files.
Jason
> Here is the code:
> try {
> try {
> System.exit(0);
> try {
> before and it seems to be a bug:
Re: Cannot render chart to image - possibly a bug [message #759969 is a reply to message #759968] |
Wed, 30 November 2011 13:34   |
BTW if you could build a small swing app that shows the issue it could
help us debug it.
Jason
> Jason
>> Here is the code:
>> try {
>> try {
>> System.exit(0);
>> try {
Re: Cannot render chart to image - possibly a bug [message #760061 is a reply to message #759969] |
Thu, 01 December 2011 01:47   |
Rendering to swing works fine. The problem is when I render the chart to an
image:
double width = chart.getBlock().getBounds().getWidth();
double height = chart.getBlock().getBounds().getHeight();
Bounds bo = BoundsImpl.create(0, 0, width, height);
BufferedImage img = null;
try {
img = new BufferedImage((int) bo.getWidth(), (int) bo.getHeight(),
idr.setProperty(IDeviceRenderer.EXPECTED_BOUNDS, bo);
gcs = gr.build(idr.getDisplayServer(), chart, null, bo, null);
} catch (ChartException pex) {
ImageIcon icon = new ImageIcon(image);
If I render to png file it works fine:
try {
idr.setProperty(IDeviceRenderer.FILE_IDENTIFIER, out.getAbsolutePath());
"Jason Weathersby" wrote in message news:jb5sv1$6fg$2@news.eclipse.org...
help us debug it.
Jason
> Jason
>> Here is the code:
>> try {
>> try {
>> System.exit(0);
>> try {
Re: Cannot render chart to image - possibly a bug [message #760220 is a reply to message #760061] |
Thu, 01 December 2011 11:01   |
Can you try the example below?
import java.awt.Graphics;
import java.awt.Graphics2D;
import java.awt.image.BufferedImage;
import javax.swing.ImageIcon;
import javax.swing.JLabel;
import javax.swing.JOptionPane;
import org.eclipse.birt.chart.api.ChartEngine;
import org.eclipse.birt.chart.device.IDeviceRenderer;
import org.eclipse.birt.chart.device.IDisplayServer;
import org.eclipse.birt.chart.exception.ChartException;
import org.eclipse.birt.chart.factory.GeneratedChartState;
import org.eclipse.birt.chart.factory.IGenerator;
import org.eclipse.birt.chart.model.Chart;
import org.eclipse.birt.chart.model.ChartWithAxes;
import org.eclipse.birt.chart.model.attribute.ActionType;
import org.eclipse.birt.chart.model.attribute.AxisType;
import org.eclipse.birt.chart.model.attribute.Bounds;
import org.eclipse.birt.chart.model.attribute.IntersectionType;
import org.eclipse.birt.chart.model.attribute.LegendItemType;
import org.eclipse.birt.chart.model.attribute.Position;
import org.eclipse.birt.chart.model.attribute.TickStyle;
import org.eclipse.birt.chart.model.attribute.TriggerCondition;
import org.eclipse.birt.chart.model.attribute.impl.BoundsImpl;
import org.eclipse.birt.chart.model.attribute.impl.ColorDefinitionImpl;
import org.eclipse.birt.chart.model.attribute.impl.TooltipValueImpl;
import org.eclipse.birt.chart.model.attribute.impl.URLValueImpl;
import org.eclipse.birt.chart.model.component.Axis;
import org.eclipse.birt.chart.model.component.Series;
import org.eclipse.birt.chart.model.component.impl.SeriesImpl;
import org.eclipse.birt.chart.model.data.BaseSampleData;
import org.eclipse.birt.chart.model.data.DataFactory;
import org.eclipse.birt.chart.model.data.NumberDataSet;
import org.eclipse.birt.chart.model.data.OrthogonalSampleData;
import org.eclipse.birt.chart.model.data.SampleData;
import org.eclipse.birt.chart.model.data.SeriesDefinition;
import org.eclipse.birt.chart.model.data.TextDataSet;
import org.eclipse.birt.chart.model.data.Trigger;
import org.eclipse.birt.chart.model.data.impl.ActionImpl;
import org.eclipse.birt.chart.model.data.impl.NumberDataSetImpl;
import org.eclipse.birt.chart.model.data.impl.SeriesDefinitionImpl;
import org.eclipse.birt.chart.model.data.impl.TextDataSetImpl;
import org.eclipse.birt.chart.model.data.impl.TriggerImpl;
import org.eclipse.birt.chart.model.impl.ChartWithAxesImpl;
import org.eclipse.birt.chart.model.layout.Legend;
import org.eclipse.birt.chart.model.layout.Plot;
import org.eclipse.birt.chart.model.type.BarSeries;
import org.eclipse.birt.chart.model.type.impl.BarSeriesImpl;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.core.framework.PlatformConfig;
import org.eclipse.emf.ecore.util.EcoreUtil;
* Test decription:
* </p>
* Chart script: BeforeDrawLegendItem()
* </p>
public class StandaloneChartOSGi
private static String OUTPUT = "output/StandaloneOSGi.png"; //$NON-NLS-1$
* Comment for <code>serialVersionUID</code>
private static final long serialVersionUID = 1L;
* A chart model instance
private Chart cm = null;
* The swing rendering device
private IDeviceRenderer dRenderer = null;
private IDisplayServer dServer = null;
private GeneratedChartState gcs = null;
* execute application
* @param args
public static void main( String[] args )
new StandaloneChartOSGi( );
System.out.println("Finished");
* Constructor
public StandaloneChartOSGi( )
//The deployment runtime libs can be used to build the code
//if using osgi, must have valid plugins directory
PlatformConfig pf = new PlatformConfig();
pf.setBIRTHome("C:/birt/birt-runtime-2_6_1/birt-runtime-2_6_1/ReportEngine");
//Returns a singleton instance of the Chart Engine
ChartEngine ce = ChartEngine.instance(pf);
//Returns a singleton instance of the Generator
IGenerator gr = ce.getGenerator();
try
dRenderer = ce.getRenderer("dv.PNG");
dServer =dRenderer.getDisplayServer( );
catch( Exception ex)
ex.printStackTrace();
cm = StandaloneChartOSGi.createStackedBar();
600,
600,
BufferedImage.TYPE_INT_ARGB );
Graphics g = img.getGraphics( );
Graphics2D g2d = (Graphics2D) g;
dRenderer.setProperty( IDeviceRenderer.GRAPHICS_CONTEXT, g2d );
//dRenderer.setProperty( IDeviceRenderer.FILE_IDENTIFIER, OUTPUT );
//$NON-NLS-1$
dRenderer.setProperty(IDeviceRenderer.CACHED_IMAGE, img);
Bounds bo = BoundsImpl.create( 0, 0, 600, 600 );
bo.scale( 72d / dRenderer.getDisplayServer( ).getDpiResolution( ) );
try
gcs = gr.build(
dServer,
cm,
bo,
null,
null,
null );
gr.render( dRenderer, gcs );
catch ( ChartException e )
e.printStackTrace( );
//Only shutdown OSGi if started
Platform.shutdown();
public static final Chart createStackedBar()
ChartWithAxes cwaBar = ChartWithAxesImpl.create();
cwaBar.setType("Bar Chart"); //$NON-NLS-1$
cwaBar.setSubType("Stacked"); //$NON-NLS-1$
// Plot
cwaBar.getBlock().setBackground(ColorDefinitionImpl.WHITE());
cwaBar.getBlock().getOutline().setVisible(true);
Plot p = cwaBar.getPlot();
p.getClientArea().setBackground(ColorDefinitionImpl.create(255,
255,
225));
// Title
cwaBar.getTitle()
.getLabel()
.getCaption()
.setValue("Stacked Bar Chart"); //$NON-NLS-1$
// Legend
Legend lg = cwaBar.getLegend();
lg.setItemType(LegendItemType.SERIES_LITERAL);
//Add Script
cwaBar
.setScript("function beforeGeneration( cm, icsc )"
+ "{importPackage(Packages.org.eclipse.birt.chart.model.attribute); "
importPackage(Packages.org.eclipse.birt.chart.model.attribute.impl); "
+ " cm.getLegend().getOutline( ).setStyle(
LineStyle.DASH_DOTTED_LITERAL );"
+ " cm.getLegend().getOutline( ).setColor(
ColorDefinitionImpl.GREEN() );"
+ " cm.getLegend().getOutline( ).setVisible( true );} ");
// X-Axis
Axis xAxisPrimary = cwaBar.getPrimaryBaseAxes()[0];
xAxisPrimary.setType(AxisType.TEXT_LITERAL);
xAxisPrimary.getMajorGrid().setTickStyle(TickStyle.BELOW_LITERAL);
xAxisPrimary.getOrigin().setType(IntersectionType.MIN_LITERAL);
// Y-Axis
Axis yAxisPrimary = cwaBar.getPrimaryOrthogonalAxis(xAxisPrimary);
yAxisPrimary.getMajorGrid().setTickStyle(TickStyle.LEFT_LITERAL);
yAxisPrimary.setType(AxisType.LINEAR_LITERAL);
yAxisPrimary.setLabelPosition(Position.RIGHT_LITERAL);
yAxisPrimary.getLabel().getCaption().getFont().setRotation(45);
// Data Set
TextDataSet categoryValues = TextDataSetImpl.create(new String[] {
"Item 1", "Item 2", "Item 3", "Item 4", "Item 5" }); //$NON-NLS-1$
//$NON-NLS-2$ //$NON-NLS-3$ //$NON-NLS-4$ //$NON-NLS-5$
NumberDataSet orthoValues1 = NumberDataSetImpl.create(new double[] {
25, 35, 15, 5, 20
NumberDataSet orthoValues2 = NumberDataSetImpl.create(new double[] {
5, 10, 25, 10, 5
SampleData sd = DataFactory.eINSTANCE.createSampleData();
BaseSampleData sdBase = DataFactory.eINSTANCE.createBaseSampleData();
sdBase.setDataSetRepresentation("");//$NON-NLS-1$
sd.getBaseSampleData().add(sdBase);
OrthogonalSampleData sdOrthogonal1 = DataFactory.eINSTANCE
.createOrthogonalSampleData();
sdOrthogonal1.setDataSetRepresentation("");//$NON-NLS-1$
sdOrthogonal1.setSeriesDefinitionIndex(0);
sd.getOrthogonalSampleData().add(sdOrthogonal1);
OrthogonalSampleData sdOrthogonal2 = DataFactory.eINSTANCE
sdOrthogonal2.setDataSetRepresentation("");//$NON-NLS-1$
sdOrthogonal2.setSeriesDefinitionIndex(1);
sd.getOrthogonalSampleData().add(sdOrthogonal2);
cwaBar.setSampleData(sd);
// X-Series
Series seCategory = SeriesImpl.create();
seCategory.setDataSet(categoryValues);
SeriesDefinition sdX = SeriesDefinitionImpl.create();
xAxisPrimary.getSeriesDefinitions().add(sdX);
sdX.getSeries().add(seCategory);
// Y-Series
BarSeries bs1 = (BarSeries) BarSeriesImpl.create();
bs1.setDataSet(orthoValues1);
bs1.setStacked(true);
bs1.getLabel().setVisible(true);
bs1.setLabelPosition(Position.INSIDE_LITERAL);
BarSeries bs2 = (BarSeries) BarSeriesImpl.create();
bs2.setDataSet(orthoValues2);
bs2.setStacked(true);
bs2.getLabel().setVisible(true);
bs2.setLabelPosition(Position.INSIDE_LITERAL);
Trigger tr1 = TriggerImpl.create(TriggerCondition.ONMOUSEOVER_LITERAL,
ActionImpl.create(ActionType.SHOW_TOOLTIP_LITERAL,
TooltipValueImpl.create(200, null)));
Trigger tr2 = TriggerImpl.create(TriggerCondition.ONCLICK_LITERAL,
ActionImpl.create(ActionType.URL_REDIRECT_LITERAL, URLValueImpl
.create("https://www.google.com", null, "component",
"value", "")));
//Trigger tr3 =
Trigger tr3 = (Trigger) EcoreUtil.copy(tr1);
Trigger tr4 = (Trigger) EcoreUtil.copy(tr2);
bs1.getTriggers().add(tr1);
bs1.getTriggers().add(tr2);
bs2.getTriggers().add(tr3);
bs2.getTriggers().add(tr4);
SeriesDefinition sdY = SeriesDefinitionImpl.create();
sdY.getSeriesPalette().shift(0);
yAxisPrimary.getSeriesDefinitions().add(sdY);
sdY.getSeries().add(bs1);
sdY.getSeries().add(bs2);
return cwaBar;
Jason
> an image:
> try {
> try {
> help us debug it.
> Jason
>> Jason
>>> Here is the code:
>>> try {
>>> try {
>>> System.exit(0);
>>> try {
Re: Cannot render chart to image - possibly a bug [message #760328 is a reply to message #760220] |
Thu, 01 December 2011 16:52  |
Thank you very much I have now made it work using your example, I am not
quite sure how though :-)
"Jason Weathersby" wrote in message news:jb88c8$ps1$1@news.eclipse.org...
* Test decription:
* </p>
* </p>
* @param args
* Constructor
try
600,
600,
//$NON-NLS-1$
try
gcs = gr.build(
dServer,
cm,
bo,
null,
null,
null );
// Plot
255,
225));
// Title
cwaBar.getTitle()
..getLabel()
..getCaption()
..setValue("Stacked Bar Chart"); //$NON-NLS-1$
// Legend
//Add Script
cwaBar
..setScript("function beforeGeneration( cm, icsc )"
// X-Axis
// Y-Axis
// Data Set
25, 35, 15, 5, 20
5, 10, 25, 10, 5
..createOrthogonalSampleData();
// X-Series
// Y-Series
..create("https://www.google.com", null, "component",
"value", "")));
//Trigger tr3 =
return cwaBar;
Jason
> an image:
> try {
> try {
> help us debug it.
> Jason
>> Jason
>>> Here is the code:
>>> try {
>>> try {
>>> System.exit(0);
>>> try {
Current Time: Sun Jul 27 09:40:27 EDT 2025
Powered by FUDForum. Page generated in 0.05752 seconds
