Home » Archived » Sapphire » Instantiation a popup test UI of Sapphire
Instantiation a popup test UI of Sapphire [message #760030] Wed, 30 November 2011 20:48 Go to next message
I was wondering if a mechanism is being worked on now to simply click an action and have the constructed Sapphire UI popup a test showing how the UI would appear when run in eclipse.
Googles WindowBuilderPro, Jigloo, and XWT all have such tools. This makes usage quite user-friendly. This would help us a lot.
Re: Instantiation a popup test UI of Sapphire [message #760049 is a reply to message #760030] Thu, 01 December 2011 00:55 Go to previous messageGo to next message
I am not familiar with this action in other tools, but how is this different from simply running your code using regular means?
- Konstantin
Re: Instantiation a popup test UI of Sapphire [message #760054 is a reply to message #760049] Thu, 01 December 2011 01:01 Go to previous messageGo to next message
Hello Konstantin,
To run the code currently, just to see the UI, I have to execute the eclipse 4.2 product each time!
With a popup UI button, I simply clicked the button and it instantiates the UI as it would appear when eclipse is run.
Download/install via update site Google WindowBuilder Pro, create a UI using SWT, JFace widgets and then click the test button on the context menu. The UI will popup as it would appear when eclipse is run.
For Sapphire, this feature is even more important since currently there is no represntatation of the UI as it would appear when the eclipse product is run, quite unlike the other tools mentioned previously.
Re: Instantiation a popup test UI of Sapphire [message #760117 is a reply to message #760054] Thu, 01 December 2011 06:13 Go to previous messageGo to next message
It sounds like you are referring to WYSIWYG preview. It is possible that we would implement something like that for Sapphire in the future, but there are no plans at the moment to do so.
- Konstantin
Re: Instantiation a popup test UI of Sapphire [message #760156 is a reply to message #760117] Thu, 01 December 2011 08:49 Go to previous message
Hello Konstantin,
Yes, it is WYSIWYG preview.
I hope this will float to the top of your priorities not too far in the distance future.
Previous Topic:Running a sapphire application in a simple java main method
Next Topic:Announcing Sapphire 0.4 Release
Current Time: Wed Aug 13 07:24:48 EDT 2025
Powered by FUDForum. Page generated in 0.03903 seconds
