Home » Language IDEs » Java Development Tools (JDT) » @RunWith(Enclosed.class) annotated JUnit test classes hang when whole project is tested
@RunWith(Enclosed.class) annotated JUnit test classes hang when whole project is tested [message #759723] Tue, 29 November 2011 13:37 Go to next message
I've tried out the Enclosed test runner lately to group my test methods.
Running single test classes works fine, but running them all causes the
junit tree view of eclipse to hang at some indefinited points in time.
It's unlikely that these classes affect each other in a way that could
cause this problem. Maven executes all tests.
I'm currently using eclipse 3.7 and junit 4.10. Any ideas how to solve
this issue?
Jens
Re: @RunWith(Enclosed.class) annotated JUnit test classes hang when whole project is tested [message #759837 is a reply to message #759723] Wed, 30 November 2011 04:29 Go to previous messageGo to next message
On 11/30/2011 12:07 AM, Jens Piegsa wrote:
> this issue?
> Regards,
> Jens
Eclipse runs all tests in a single VM. Does Maven run the tests in
separate VMs?
Deepak Azad
http://wiki.eclipse.org/JDT/FAQ
Re: @RunWith(Enclosed.class) annotated JUnit test classes hang when whole project is tested [message #759935 is a reply to message #759837] Wed, 30 November 2011 10:43 Go to previous messageGo to next message
it looks like Maven also uses only a single VM instance.
I figured out that running a TestSuite instead of letting
eclipse collect all tests doesn't cause a hang.
cheers,
Jens
Am 30.11.2011 10:29, schrieb Deepak Azad:
>> Hi,
>> this issue?
>> Regards,
>> Jens
> separate VMs?
Re: @RunWith(Enclosed.class) annotated JUnit test classes hang when whole project is tested [message #759957 is a reply to message #759935] Wed, 30 November 2011 12:20 Go to previous message
Please open a bug against JDT/UI
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=JDT
Deepak Azad
Previous Topic:HELPPPP :(
Next Topic:Unable to update Eclipse
Current Time: Sun Jul 27 09:24:59 EDT 2025
Powered by FUDForum. Page generated in 0.74926 seconds
