Localization issue with parameters group prompts [message #759026] |
Fri, 25 November 2011 11:12  |
in a portlet tomcat context, API 3.7.1, i use this below code to retrieve parameters definition.As shown in the code, i use task.setLocale(request.getLocale()) to manage localization. I have an issue with parameters groups prompt, it seems it doesnt use the correct language value (it uses my tomcat's locale, instead of request.getLocale()), whereas scalar parameters prompt are correct.
Anyone used these group prompt successfully with api?
Should i log a bugzilla entry or am i doing something wrong?
EDIT: i tried my report with WebBirtViewer, and this kind of url:
http://localhost:8080/birt/frameset?__report=report/welcome.rptdesign&__locale=en
I got exactly the same issue than in my portlet: In parameters Dialog, Viewer displays scalar with "en" locale values, but parameters groups with "fr" values
Thanks!
IGetParameterDefinitionTask task = birtReportEngine.createGetParameterDefinitionTask(this.getRptDesign());
task.setLocale(request.getLocale());
Collection params = task.getParameterDefns( true );
Iterator iter = params.iterator( );
while ( iter.hasNext( ) ) {
IParameterDefnBase param = (IParameterDefnBase) iter.next( );
if ( param instanceof IParameterGroupDefn ){
IParameterGroupDefn group = (IParameterGroupDefn) param;
Iterator iterGroup = group.getContents( ).iterator( );
// -------> group.getPromptText() and param.getPromptText() returns 'fr_FR' value, wich is my desktop local
}else{
// -------> param.getPromptText() returns the request.getLocale() value, which is the expected behavior
}//end while
task.close();
[Updated on: Fri, 25 November 2011 14:13] by Moderator
Re: Localization issue with group prompts [message #759504 is a reply to message #759026] |
Mon, 28 November 2011 15:16   |
This does appear to be a bug. Can you open a bugzilla request?
Jason
On 11/25/2011 11:12 AM, dpardon wrote:
> retrieve parameter definition.As shown in the code, i use
> issue with parameters group prompt, it seems it doesnt use the correct
> language value, whereas scalar parameters prompt are correct. Anyone
> used these group prompt successfully with api? Should i log a bugzilla
> Thanks!
> while ( iter.hasNext( ) ) { IParameterDefnBase param =
> Iterator iterGroup = group.getContents( ).iterator( ); // ------->
> group.getPromptText() and param.getPromptText returns 'fr_FR' value,
> } }else{
> // -------> param.getPromptText() returns the request.getLocale(), which
> }//end while
> task.close();
FUDForum. Page generated in 0.08131 seconds
