Home » Modeling » Epsilon » [Eugenia] Change node's image after a changing of an attribute
[Eugenia] Change node's image after a changing of an attribute [message #759728] Tue, 29 November 2011 14:04 Go to next message
I've made my editor and following "image instead of shape" tutorial i use some images to represent my nodes in the diagram. i want to ask if there is a way to change image of a node at runtime if an attribute of its related element change. For example if the attribute isStart change to true, node's image change....
Re: [Eugenia] Change node's image after a changing of an attribute [message #759740 is a reply to message #759728] Tue, 29 November 2011 14:45 Go to previous messageGo to next message
This should help: http://eclipse.org/gmt/epsilon/doc/articles/eugenia-nodes-with-runtime-images/
Dimitris
Re: [Eugenia] Change node's image after a changing of an attribute [message #759766 is a reply to message #759740] Tue, 29 November 2011 16:38 Go to previous messageGo to next message
hi Dimitris,
i had alredy read this tutorial and seems example code allow users to change an image but not to change an image in relationship with a change of an attribute.... is simply to modify to do this?
Re: [Eugenia] Change node's image after a changing of an attribute [message #759767 is a reply to message #759766] Tue, 29 November 2011 16:41 Go to previous message
The image in the article depends on the value of the imagePath attribute - I suspect that it should be straightforward to extract a subset of the code to use in your case.
Dimitris
[Updated on: Tue, 29 November 2011 16:42] by Moderator
Previous Topic:how the gmf editor supports a constraint in the ecore model
Next Topic:[EGL] How to add a content type
Current Time: Sun Jul 27 09:26:22 EDT 2025
Powered by FUDForum. Page generated in 0.03522 seconds
