Home » Modeling » EMF » How to store gmf diagrams in CDO (Connected Data Objects) server ?(How to store gmf diagrams derived from emf model in CDO (Connected Data Objects) server ?)
How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #759643] Tue, 29 November 2011 07:45 Go to next message
I am developing an RCP Application, As I want to store GMF diagrams which is derived from EMF model, I observe that CDO (Connected Data Objects) server would be helpful in storing diagrams but I am not sure how exactly I can acheive that ?
Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #759667 is a reply to message #759643] Tue, 29 November 2011 09:53 Go to previous messageGo to next message
Vinay,
Have a look at http://wiki.eclipse.org/Dawn
On 29/11/2011 1:45 PM, vinny503 wrote:
> Regards,
> Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #759884 is a reply to message #759667] Wed, 30 November 2011 08:34 Go to previous messageGo to next message
Hi Ed,
Is it possible to install Dawn for Eclipse 3.6.1 version ?
Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #759890 is a reply to message #759884] Wed, 30 November 2011 08:46 Go to previous messageGo to next message
Vinay,
I'm not sure. Did you try it?
On 30/11/2011 2:34 PM, vinny503 wrote:
> Hi Ed,
> Regards,
> Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #759905 is a reply to message #759890] Wed, 30 November 2011 09:29 Go to previous messageGo to next message
I tried with the download url mentioned in the following site..
wiki.eclipse.org/Getting_Started_with_Dawn but it did not work, probably it is made for Eclipse Indigo release.
Can you provide the download link of Dawn ?
Vinay
[Updated on: Wed, 30 November 2011 09:40] by Moderator
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #759955 is a reply to message #759905] Wed, 30 November 2011 11:59 Go to previous messageGo to next message
Vinay,
comments below
Am 30.11.2011 15:29, schrieb vinny503:
> http://wiki.eclipse.org/Getting_Started_with_Dawn but it did not work,
Yes, it is. It points to the current release. What does "did not work"
mean? Any exceptions?
Actually Dawn 1.0 from the Indigo Release should work on Helios if you
have CDO 4.0 and EMF 2.6 installed. But you might experience trouble
with the Dawn generator due to some changes in GMF. I would recommend to
update to Eclipe 3.7 if possible.
Martin
> Regards,
> Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #760003 is a reply to message #759955] Wed, 30 November 2011 16:23 Go to previous messageGo to next message
I tried Dawn briefly. I think it is mostly for model editing, right? Can we use it for model instance editing? That would be cool...
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #760045 is a reply to message #760003] Thu, 01 December 2011 00:32 Go to previous messageGo to next message
Simon,
Yes it works for any EMF model instances.
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #760066 is a reply to message #760003] Thu, 01 December 2011 02:26 Go to previous messageGo to next message
Simon,
Can you provide me the steps that you followed to work with Dawn ?
I have already GMF Diagrams created now In order to store this for later use, I just need to use Dawn.
Vinay
[Updated on: Thu, 01 December 2011 02:29] by Moderator
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #760110 is a reply to message #760066] Thu, 01 December 2011 05:57 Go to previous messageGo to next message
I am facing problem in starting the CDO server. Shows the following error
Variable references non-existent resource : ${resource_loc:<path>}
I have the cdo-server.xml in the eclipse folder.
D:\eclipse-SDK-3.7.1-win32\eclipse
Vinay
[Updated on: Thu, 01 December 2011 07:18] by Moderator
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #760168 is a reply to message #760110] Thu, 01 December 2011 09:16 Go to previous messageGo to next message
Vinay,
Here is a pretty good instruction on how to get CDO working:
http://www.rcp-vision.com/?p=1285&lang=en
It seems that you didn't specify the path to cdo-server.xml correctly.
For Dawn, all I did was following the regular steps here:
-Simon
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #760198 is a reply to message #760168] Thu, 01 December 2011 10:16 Go to previous messageGo to next message
Simon,
I have 2 Queries...
1. Can you please tell me how you were able to store GMF Diagrams and how you were able to retain that in RCP Application ?
2. VM arguments which I have given is shown below
-Dnet4j.config=${workspace_loc}/cdo-server.xml
my workspace is where I launch Eclipse.
cdo-server.xml is in eclipse folder
Now I am getting the following error
org.osgi.framework.BundleException: Exception in org.eclipse.equinox.internal.simpleconfigurator.Activator.start() of bundle org.eclipse.equinox.simpleconfigurator.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:389)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1131)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
Caused by: java.lang.IllegalStateException: The System Bundle was updated. The framework must be restarted to finalize the configuration change
at org.eclipse.equinox.internal.simpleconfigurator.ConfigApplier.install(ConfigApplier.java:71)
at org.eclipse.equinox.internal.simpleconfigurator.SimpleConfiguratorImpl.applyConfiguration(SimpleConfiguratorImpl.java:129)
at org.eclipse.equinox.internal.simpleconfigurator.SimpleConfiguratorImpl.applyConfiguration(SimpleConfiguratorImpl.java:143)
at org.eclipse.equinox.internal.simpleconfigurator.Activator.start(Activator.java:48)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
... 12 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2011-12-01 18:06:51.781
!MESSAGE Bundle org.eclipse.equinox.simpleconfigurator_1.0.200.v20110502-1955 [1] is not active.
!ENTRY org.eclipse.osgi 4 0 2011-12-01 18:06:51.796
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:74)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
An error has occurred. See the log file
D:\eclipse-SDK-3.7.1-win32\eclipse\.metadata\.plugins\org.eclipse.pde.core\CDO_Server\1322743010890.log.
Vinay
[Updated on: Thu, 01 December 2011 10:39] by Moderator
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #760204 is a reply to message #760198] Thu, 01 December 2011 10:35 Go to previous messageGo to next message
Vinay,
to get Dawn working with your GMF editor you need to generate a Dawn UI
Extension. This is an OSGI fragment which has to be deployed with your
GMF bundles.
This tutorial describes how to use the generator.
http://wiki.eclipse.org/Dawn_Codegen
Martin
Am 01.12.2011 16:16, schrieb vinny503:
> Simon,
> Regards,
> Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #760363 is a reply to message #760204] Fri, 02 December 2011 02:41 Go to previous messageGo to next message
I was following the steps provided in Dawn CodeGen site but when I reached the step to install CDO Dawn CodeGen GMF mentioned in the site https://hudson.eclipse.org/hudson/job/emf-cdo-integration/lastStableBuild/artifact/result/site.p2/, but founds error in this site, I am not able to proceed, Is this plugin really required ?
vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #760423 is a reply to message #760363] Fri, 02 December 2011 05:40 Go to previous messageGo to next message
I am able to find the CDO Dawn Codegen GMF from the Available Software Sites, But though half an hour completed but still it is showing 0% installed, what could be the reason ?
Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #760429 is a reply to message #760423] Fri, 02 December 2011 05:52 Go to previous messageGo to next message
Vinay,
Networks can be very slow.
On 02/12/2011 11:40 AM, vinny503 wrote:
> Regards,
> Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #760452 is a reply to message #760429] Fri, 02 December 2011 07:40 Go to previous messageGo to next message
Now CDO Dawn Codegen GMF is installed, After that when I try to generate the GMF diagram plug-in, I get the error saying that java.lang.NullPointer Exception, And also I noticed that acore.gmfgen, acore.genmodel,acore.ecore and so on... has not changed to acore.gmfgen 1.1, acore.genmodel 1.1,acore.ecore 1.1 and so on....
Vinay
[Updated on: Fri, 02 December 2011 08:12] by Moderator
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #760453 is a reply to message #760363] Fri, 02 December 2011 07:38 Go to previous messageGo to next message
Vinay,
comments below...
Am 02.12.2011 08:41, schrieb vinny503:
The update site was indeed outdated. I fixed it.
> Is this plugin
> really required ?
If you want to generate an extension for GMF, then "CDO Dawn CodeGen
*GMF*" is needed.
Martin
> Regards,
> vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #760463 is a reply to message #760452] Fri, 02 December 2011 08:17 Go to previous messageGo to next message
Am 02.12.2011 13:40, schrieb vinny503:
> Now CDO Codegen GMF is installed, After that when I try to generate the
> Exception,
Could you paste the whole exception?
Why should they?
> Regards,
> Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #760470 is a reply to message #760463] Fri, 02 December 2011 08:51 Go to previous messageGo to next message
Please find the Generate Diagram code error image attached..
Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #760586 is a reply to message #760470] Sat, 03 December 2011 03:31 Go to previous messageGo to next message
Am 02.12.2011 14:51, schrieb vinny503:
One of the few cases where an image does not say more than text :P
Please check your Error Log view or the .metadata/.log file for the exact stack trace and paste it here as text.
Cheers
/Eike
http://www.esc-net.de
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #760588 is a reply to message #760470] Sat, 03 December 2011 04:02 Go to previous messageGo to next message
From you picture I can see that the first step of the generation worked
properly since the *.dawngenmodel and the generator models for EMF and
GMF are generated.
You also already succeeded in generating the EMF extension. I guess that
the exception occurs when you try to regenerate GMF diagram plug-in.
This is actually something you need to ask the GMF guys. Why do you
regenerate the GMF plugin?
What happens when you generate the Dawn Extension for GMF (context menu
on the acore-dawngenmodel_gmf)?
Martin
> Regards,
> Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #760756 is a reply to message #760588] Mon, 05 December 2011 01:16 Go to previous messageGo to next message
when I try to generate Dawn Extension of GMF, I can see only 4 packages-- org.eclipse.emf.cdo.dawn.examples.acore.diagram.edit.parts, org.eclipse.emf.cdo.dawn.examples.acore.diagram.edit.policies, org.eclipse.emf.cdo.dawn.examples.acore.diagram.part, org.eclipse.emf.cdo.dawn.examples.acore.diagram.providers...And when I launch an Eclipse Application in Fragment.xml, I get error which I have attached with this.
Vinay
[Updated on: Mon, 05 December 2011 01:17] by Moderator
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #760764 is a reply to message #760756] Mon, 05 December 2011 02:21 Go to previous messageGo to next message
Hi Martin,
One more thing is that I have already created GMF Editor Application and the projects are omsbuilder, omsbuilder.diagram, omsbuilder.edit. In omsbuilder project there is omsbuilder.gmfgen model when I do a right click on it and when I try to Generate Dawn Genmodel nothing happens what could be the reason ?
Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #760768 is a reply to message #760756] Mon, 05 December 2011 03:31 Go to previous messageGo to next message
Vinay,
"The System Bundle was updated. The framework must be restarted to finalize the configuration change"
This error can occur if you somehow mixed different versions of the system bundles in your target platform. Try to update your target platform.
4 bundles are o.k. in the Dawn fragment. Dawn only changes those.
Martin
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #760780 is a reply to message #760768] Mon, 05 December 2011 04:14 Go to previous messageGo to next message
Hi Martin,
I updated Target Platform, Now I could run Fragment.xml and can create diagram.
Since I am developing an RCP Application, Is it possible to generate RCP for org.eclipse.emf.cdo.dawn.examples.acore.diagram.dawn plugin.
And My Aim was to retain all GMF Diagrams. What is the difference between running plugin.xml from xxx.diagram project and running fragment.xml from xxx.diagram.dawn project.
Vinay
[Updated on: Mon, 05 December 2011 04:19] by Moderator
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #760787 is a reply to message #760780] Mon, 05 December 2011 04:44 Go to previous messageGo to next message
Great! Smile
I am not sure what you means. You only need to deploy teh generated fragment and the CDO/Dawn bundles in your RCP.
Does this mean that you have alreasy existing diagrams stored as XMI and youo want to store these in CDO?
> project.
Again, I am not sure what you mean. If you choose "Run as Eclipse Application" the specific runtime will be started. Actually you cannot "run" a fragment.
Martin
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #760805 is a reply to message #760787] Mon, 05 December 2011 05:35 Go to previous messageGo to next message
Hi Martin,
Like I have told before, I have developed an RCP application and Everytime I draw Diagrams On GMF Editor, I want that to be stored so that can be retained back and can do necessary changes.
And you said deploying fragment to my RCP Application, I want to know which fragment ?
How can I deploy those ? Is it adding those plugins in the Dependency tab of plugin.xml of xxx.diagram project
regards,
vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #761288 is a reply to message #760787] Tue, 06 December 2011 03:47 Go to previous messageGo to next message
Hi Martin,
Though I followed thw Dawn Codegen Tutorial but still it is not clear that how GMF Diagrams can be stored and how it can be retained.
I am stuck at this point of time, Looking forward to your reply.
Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #761297 is a reply to message #761288] Tue, 06 December 2011 03:53 Go to previous messageGo to next message
Am 06.12.2011 09:47, schrieb vinny503:
> Hi Martin,
> can be retained. I am stuck at this point of time, Looking forward to your reply.
Have you read/followed http://wiki.eclipse.org/Getting_Started_with_Dawn ? If there are problems with it please report
here exactly what you've done/not done and which of the described steps do not lead to the expected results.
Cheers
/Eike
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #761309 is a reply to message #761297] Tue, 06 December 2011 04:20 Go to previous messageGo to next message
In Getting started to Dawn Tutorial, Beginning they say that we need CDO running. when I followed the tutorial that tells to start CDO server, I had a problem in adding the following entry to the VM Arguments:
-Dnet4j.config=${resource_loc:<path>}, It was not finding the resource.
cdo-server.xml file is in D:\eclipse-SDK-3.7.1-win32\eclipse\configuration directory. And Workspace location is D:\eclipse-SDK-3.7.1-win32\eclipse\.
what am I suposed to enter it to VM Arguments
Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #761342 is a reply to message #761309] Tue, 06 December 2011 05:25 Go to previous messageGo to next message
Am 06.12.2011 10:20, schrieb vinny503:
Well, where is your cdo-server.xml located? Let net4j.config point to the *folder* of that file.
Cheers
/Eike
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #761356 is a reply to message #761342] Tue, 06 December 2011 05:41 Go to previous messageGo to next message
Hi Vinny,
the default location is eclipse/config and not eclipse/configuration.
If you don't change the location via VM arguments, you need to put the cdo-server.xml
in the "config" folder in your eclipse directory. It might not exist so you have to create it.
Tim
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #761360 is a reply to message #761342] Tue, 06 December 2011 05:51 Go to previous messageGo to next message
cdo-server.xml is located in configuration folder D:/eclipse-SDK-3.7.1-win32/eclipse/configuration/, So is it the following mentioned VM arguments is correct ?
-Dnet4j.config=D:/eclipse-SDK-3.7.1-win32/eclipse/configuration/
Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #761376 is a reply to message #761360] Tue, 06 December 2011 06:31 Go to previous messageGo to next message
Am 06.12.2011 11:51, schrieb vinny503:
Most probably. Try it and you'll see it.
Cheers
/Eike
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #761434 is a reply to message #761376] Tue, 06 December 2011 08:26 Go to previous messageGo to next message
I tried and it is working, Now CDO server started.
Then I followed "Getting Started with Dawn" tutorial. In this is it Dawn Explorer will hold all the GMF Diagrams ?
Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #761454 is a reply to message #761434] Tue, 06 December 2011 08:47 Go to previous messageGo to next message
Am 06.12.2011 14:26, schrieb vinny503:
I think so.
Cheers
/Eike
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #761466 is a reply to message #761454] Tue, 06 December 2011 09:09 Go to previous messageGo to next message
How do I get Dawn Explorer window and CDO Session window in my RCP Application ?
Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #761619 is a reply to message #761466] Tue, 06 December 2011 13:53 Go to previous messageGo to next message
Am 06.12.2011 15:09, schrieb vinny503:
What have you tried so far? Look for these classes:
org.eclipse.emf.cdo.internal.ui.views.CDOSessionsView
org.eclipse.emf.cdo.dawn.ui.views.DawnExplorer
Include the containing plugins into your deployment.
Cheers
/Eike
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #761868 is a reply to message #761619] Wed, 07 December 2011 02:54 Go to previous messageGo to next message
Hi Eike,
I have deployed those plugins but when I try to Launch an Eclipse Application, I get the runtime Exception. Please find the attached log file.
Actually these projects were created in Eclipse 3.6.1 version, since CDO and Dawn plugins are in Eclipse 3.7.1 version, So I imported those projects. Is it the version is creating problem ?
Vinay
[Updated on: Wed, 07 December 2011 03:38] by Moderator
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #761881 is a reply to message #761868] Wed, 07 December 2011 03:13 Go to previous messageGo to next message
Am 07.12.2011 08:54, schrieb vinny503:
> Hi Eike,
There's nothing attached.
Cheers
/Eike
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #761890 is a reply to message #761881] Wed, 07 December 2011 03:40 Go to previous messageGo to next message
Hi Eike,
Sorry I forgot to attach. Please find it now.
Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #761896 is a reply to message #761890] Wed, 07 December 2011 03:49 Go to previous messageGo to next message
Am 07.12.2011 09:40, schrieb vinny503:
> Hi Eike,
That looks like a fundamental problem with your RCP application. Please ask for advice in the platform or RCP forums.
Cheers
/Eike
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #761963 is a reply to message #761896] Wed, 07 December 2011 06:01 Go to previous messageGo to next message
Hi Eike,
I resolved that problem. Now after launching I see error on the DawnExplorer window, shown below...And also please find the Image that shows the plugin.xml attached, which has Extension tab for adding DawnExplorer view shown.
java.lang.ClassNotFoundException: org.eclipse.emf.cdo.dawn.ui.views.DawnExplorer
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:513)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:345)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1207)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:260)
at org.eclipse.ui.internal.registry.ViewDescriptor.createView(ViewDescriptor.java:63)
at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewReference.java:327)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:229)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:534)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1245)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.java:662)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.java:570)
at org.eclipse.ui.internal.PartSashContainer.createControl(PartSashContainer.java:568)
at org.eclipse.ui.internal.PerspectiveHelper.activate(PerspectiveHelper.java:272)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.java:981)
at org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPage.java:2714)
at org.eclipse.ui.internal.WorkbenchWindow$27.run(WorkbenchWindow.java:3023)
at org.eclipse.ui.internal.WorkbenchWindow.setActivePage(WorkbenchWindow.java:3004)
at org.eclipse.ui.internal.WorkbenchWindow$20.runWithException(WorkbenchWindow.java:2290)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java:1595)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at omsbuilder.diagram.application.OmsbuilderApplication.start(OmsbuilderApplication.java:22)
Vinay
[Updated on: Wed, 07 December 2011 06:19] by Moderator
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #762130 is a reply to message #761896] Wed, 07 December 2011 10:37 Go to previous messageGo to next message
Hi Eike,
DawnExplorer class not found Problem is resolved.
Now I was trying to generate Dawn GMF Fragment i.e xxx.diagram.dawn. After the generation I see error in MANIFEST.MF file, says that unsatisfied version constraint. Please find the image showing MANIFEST.MF file with error.
Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #762157 is a reply to message #762130] Wed, 07 December 2011 11:16 Go to previous messageGo to next message
Hi Vinay,
We used GMF with CDO, but found that with decent sized repositories
(80.000 object) it was just too slow. I think someone said that GMF is
not optimised to use the lazy loading that CDO provides. We ended up
having to re write everything in GEF, which worked a treat and we could
take advantage of CDO 4.0's performance.
Worth looking into before you go too far.
David
On 07/12/11 15:37, vinny503 wrote:
> Hi Eike,
> Regards,
> Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #762173 is a reply to message #762157] Wed, 07 December 2011 11:40 Go to previous messageGo to next message
Am 07.12.2011 17:16, schrieb David Wynter:
> Hi Vinay,
> We used GMF with CDO, but found that with decent sized repositories (80.000 object) it was just too slow.
The diagram resources could be prefetched with infinite depth. That's helped a lot in other cases.
> I think someone said that GMF is not optimised to use the lazy loading that CDO provides.
Well, that doesn't hit the point so well. To participate in CDO's advanced loading and unloading mechanisms a model must
be generated in CDO "native" format (as opposed to the normal "legacy" format). That's been problematic with GMF's
notation model in the past.
I remember that Obeo has started an effort to come up with a CDO native version of the notation model:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=336709
I've not had the chance to play with it, though.
> We ended up having to re write everything in GEF, which worked a treat and we could take advantage of CDO 4.0's
> performance.
Great ;-)
Cheers
/Eike
> Regards,
> David
>> Hi Eike,
>> Regards,
>> Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #762507 is a reply to message #762173] Thu, 08 December 2011 03:02 Go to previous messageGo to next message
Hi Eike,
Is it possible to generate RCP for Dawn GMF Fragment i.e xxx.diagram.dawn ?
Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #762523 is a reply to message #762507] Thu, 08 December 2011 03:43 Go to previous messageGo to next message
Am 08.12.2011 09:02, schrieb vinny503:
> Hi Eike,
Please ask the RCP forum on how to generate RCP applications.
Cheers
/Eike
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #762566 is a reply to message #762523] Thu, 08 December 2011 05:08 Go to previous messageGo to next message
Hi Eike,
I am able to generate Dawn GMF Fragment but when I Launch an Eclipse Application in Fragment.xml, In the runtime workbench I tried opening GMF Editor but I find the CDO Session Protocol Problem. Please find the Image attached.
Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #762579 is a reply to message #762566] Thu, 08 December 2011 05:33 Go to previous messageGo to next message
Am 08.12.2011 11:08, schrieb vinny503:
> Hi Eike,
Seems you did not deploy your generated model plugin.
Cheers
/Eike
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #762581 is a reply to message #762566] Thu, 08 December 2011 05:37 Go to previous messageGo to next message
Hi Eike,
If I click on abort button, shown in previous image, I get Resource$IOwrappedException.
Please find the image that shows the Exception.
Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #762593 is a reply to message #762581] Thu, 08 December 2011 05:55 Go to previous messageGo to next message
Am 08.12.2011 11:37, schrieb vinny503:
> Hi Eike,
You must have done something wrong.
Cheers
/Eike
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #762606 is a reply to message #762593] Thu, 08 December 2011 06:28 Go to previous messageGo to next message
Hi Eike,
I find 1 error in the DawnOmsBuilderDiagramEditorUtil.java which I am not able to rectify since it is a generated one. Probably this could be the reason why i am not able to open the GMF Editor. Please find the image attached.
Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #762617 is a reply to message #762606] Thu, 08 December 2011 06:53 Go to previous messageGo to next message
Hi Eike,
I resolved that error but still the same thing !
Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #762634 is a reply to message #762617] Thu, 08 December 2011 07:26 Go to previous messageGo to next message
Hi Eike,
Can you tell me where it is expecting omsbuilder.OmsBuilderPackage Class from that image which I already sent you.
Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #762789 is a reply to message #762634] Thu, 08 December 2011 11:16 Go to previous messageGo to next message
Set a breakpoint.
On 08/12/2011 4:26 AM, vinny503 wrote:
> Hi Eike,
> Regards,
> Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #763187 is a reply to message #762789] Fri, 09 December 2011 05:10 Go to previous messageGo to next message
As I came across the following mentioned line on the console, but I did not get a clear idea on this, Can You tell what it is expecting
No file system is defined for scheme: cdo
Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #763209 is a reply to message #763187] Fri, 09 December 2011 06:02 Go to previous messageGo to next message
Am 09.12.2011 11:10, schrieb vinny503:
Google is your best friend:
http://www.google.de/search?hl=de&site=&q=%22No+file+system+is+defined+for+scheme%3A+cdo+%22&oq=%22No+file+system+is+defined+for+scheme%3A+cdo+%22&aq=f&aqi=&aql=&gs_sm=e&gs_upl=2566l4960l0l5149l3l3l0l1l0l0l100l193l1.1l2l0
Cheers
/Eike
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #764478 is a reply to message #763209] Mon, 12 December 2011 04:11 Go to previous messageGo to next message
Hi Eike,
I tried but still not able to solve. Please find the text file attached which shows the list of errors.
Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #764553 is a reply to message #764478] Mon, 12 December 2011 07:21 Go to previous messageGo to next message
Am 12.12.2011 10:11, schrieb vinny503:
> Hi Eike,
Martin (cc'ed) may want to comment on problems in Dawn.
Cheers
/Eike
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #764557 is a reply to message #764553] Mon, 12 December 2011 07:30 Go to previous messageGo to next message
Vinay,
could you please tell me which versions you are using for:
- Eclipse Core
- EMF
- GMF
- CDO
- Dawn
Martin
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #764592 is a reply to message #764557] Mon, 12 December 2011 08:47 Go to previous messageGo to next message
Hi Martin,
Please find the versions mentioned below
Eclipse Core - 3.7.1
GMF - 2.3
EMF - 2.7
CDO - 4.0
Dawn - 1.0
Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #764602 is a reply to message #764592] Mon, 12 December 2011 09:06 Go to previous messageGo to next message
The root cause seems to be the following line in your traces:
java.lang.ClassCastException: omsbuilder.impl.OmsbuilderFactoryImpl cannot be cast to omsbuilder.OmsbuilderFactory
It seems that there is somthing wrong with your generated EMF code. Please re-generate. If the error persists, although the ClassCastException disappeared, please file a bugzilla against Dawn 1.0.
Martin
[Updated on: Mon, 12 December 2011 09:07] by Moderator
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #765131 is a reply to message #764602] Tue, 13 December 2011 08:26 Go to previous messageGo to next message
Hi Eike,
In some previous conversation, David said that gef with CDO 4.0 would be feasible in storing the diagrams, Is it possible to convert gmf to gef ?
Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #765135 is a reply to message #765131] Tue, 13 December 2011 08:37 Go to previous messageGo to next message
Vinay,
Why do you keep asking the same question over and over and over
endlessly? GEF is a framework for creating graphical displays. It
offers nothing in terms of persistent storage of diagrams. GMF uses
GEF and only GMF with its EMF Notation models supports persistence.
On 13/12/2011 2:26 PM, vinny503 wrote:
> Hi Eike,
> gef ?
> Regards,
> Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #765642 is a reply to message #765135] Wed, 14 December 2011 07:51 Go to previous messageGo to next message
May I know where does all GMF Diagrams are persisted ?
Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #765652 is a reply to message #765642] Wed, 14 December 2011 08:09 Go to previous messageGo to next message
In files, or a CDO repository, if you use Dawn.
On 14/12/2011 1:51 PM, vinny503 wrote:
> Regards,
> Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #765669 is a reply to message #765652] Wed, 14 December 2011 08:44 Go to previous messageGo to next message
If it is stored in files, then when I browse for diagrams in the file where it is being stored, I cannot open it, It says
Cannot open an input element
Reason: Text Editor does not have a document provider.
Vinay
[Updated on: Wed, 14 December 2011 08:46] by Moderator
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #765681 is a reply to message #765669] Wed, 14 December 2011 09:15 Go to previous messageGo to next message
Are you using CDO? A CDO resource isn't a text file and can't be opened
in a text editor.
On 14/12/2011 2:44 PM, vinny503 wrote:
> where it is being stored, I cannot open it, It says Cannot open an
> input element Reason: Text Editor does not have a document provider.
> Regards,
> Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #765695 is a reply to message #765681] Wed, 14 December 2011 09:42 Go to previous messageGo to next message
No, this is with out CDO.
Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #765829 is a reply to message #765695] Wed, 14 December 2011 13:37 Go to previous messageGo to next message
What's "It" in "It says..."?
On 14/12/2011 3:42 PM, vinny503 wrote:
> Regards,
> Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #766028 is a reply to message #765829] Thu, 15 December 2011 00:21 Go to previous messageGo to next message
When I open a runtime workbench and try to open the GMF Diagrams that are saved in the disk, I get that problem. Please find the image attached.
Vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #766034 is a reply to message #766028] Thu, 15 December 2011 00:33 Go to previous messageGo to next message
Am 15.12.2011 06:21, schrieb vinny503:
What would you think if you'd receive a screenshot like this? Does it carry enough information for you to understand the
problem? Sure, you could complain that the error dialog does not contain sufficient technical information, you'd
probably be right. What it's probably missing is the sentence that the Error Log (view) contains more information about
this error. Usually you can find it there, most of the times even with stack traces. And you can easily copy all that
information *as text*. That could help to help you.
Cheers
/Eike
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #766059 is a reply to message #766034] Thu, 15 December 2011 01:42 Go to previous messageGo to next message
The error log view shown below
Could not open the editor: Editor could not be initialized.
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.DiagramDocumentEditor$1.run(DiagramDocumentEditor.java:130)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.jface.window.ApplicationWindow$1.run(ApplicationWindow.java:759)
at org.eclipse.jface.window.ApplicationWindow.run(ApplicationWindow.java:756)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow.java:2600)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.DiagramDocumentEditor.init(DiagramDocumentEditor.java:139)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManager.java:798)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:647)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1254)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1207)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1606)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:497)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:483)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:778)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:677)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:638)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2860)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2768)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2760)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2711)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2707)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2691)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2674)
at org.eclipse.ui.ide.IDE.openEditorOnFileStore(IDE.java:1155)
at org.eclipse.ui.internal.ide.actions.OpenLocalFileAction.run(OpenLocalFileAction.java:107)
at org.eclipse.ui.internal.ide.actions.OpenLocalFileAction.run(OpenLocalFileAction.java:76)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:229)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
regards,
vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #766086 is a reply to message #766059] Thu, 15 December 2011 03:01 Go to previous messageGo to next message
You've set a breakpoint? What does the resource you're opening contain?
On 15/12/2011 7:43 AM, vinny503 wrote:
> at
> at
> at
> at
> at
> org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> regards,
> vinay
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #766093 is a reply to message #766059] Thu, 15 December 2011 03:19 Go to previous messageGo to next message
Vinay,
if you set a breakpoint I am sure that you'll find the cause for the null pointer exception.
I guess your documentprovider is not initialized. May this has something to do with the various errors (likely compile errors) in your workspace. Could you make sure that all your GMF artifacts are generated correctly?
Martin
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #780918 is a reply to message #766093] Thu, 19 January 2012 17:28 Go to previous messageGo to next message
Hi Martin,
I face the same problem, while creating a Dawn Editor. I am sure, that there are no compile errors. The name of my model is School.ecore and when I create a new SchoolModel(.school metamodel), it works fine. But it gives me such problem, only when I am trying to creating a new DawnSchoolModel. I have given the stack trace here.....
I hope that the stack trace given here could be a good hint.
Could you please help?
Caused by: org.h2.jdbc.JdbcSQLException: Table DIAGRAM not found; SQL statement:
INSERT INTO Diagram(cdo_id, cdo_version, cdo_created, cdo_revised, cdo_resource, cdo_container, cdo_feature, school) VALUES (?, ?, ?, ?, ?, ?, ?, ?) [42102-117]
at org.h2.message.Message.getSQLException(Message.java:105)
at org.h2.message.Message.getSQLException(Message.java:116)
at org.h2.message.Message.getSQLException(Message.java:75)
at org.h2.command.Parser.readTableOrView(Parser.java:4265)
at org.h2.command.Parser.readTableOrView(Parser.java:4245)
at org.h2.command.Parser.parseInsert(Parser.java:888)
at org.h2.command.Parser.parsePrepared(Parser.java:368)
at org.h2.command.Parser.parse(Parser.java:290)
at org.h2.command.Parser.parse(Parser.java:262)
at org.h2.command.Parser.prepareCommand(Parser.java:234)
at org.h2.engine.Session.prepareLocal(Session.java:415)
at org.h2.engine.Session.prepareCommand(Session.java:376)
at org.h2.jdbc.JdbcConnection.prepareCommand(JdbcConnection.java:1049)
at org.h2.jdbc.JdbcPreparedStatement.<init>(JdbcPreparedStatement.java:74)
at org.h2.jdbc.JdbcConnection.prepareStatement(JdbcConnection.java:233)
at org.eclipse.emf.cdo.server.internal.db.SmartPreparedStatementCache.createCachedPreparedStatement(SmartPreparedStatementCache.java:79)
... 24 more
at org.eclipse.emf.internal.cdo.transaction.CDOSingleTransactionStrategyImpl.commit(CDOSingleTransactionStrategyImpl.java:85)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1109)
at org.eclipse.emf.cdo.eresource.impl.CDOResourceImpl.save(CDOResourceImpl.java:1033)
[Updated on: Thu, 19 January 2012 19:08] by Moderator
Re: How to store gmf diagrams in CDO (Connected Data Objects) server ? [message #780919 is a reply to message #780918] Thu, 19 January 2012 17:32 Go to previous message
[Updated on: Thu, 19 January 2012 17:57] by Moderator
Previous Topic:EMF with Teneo primary key problem with superclasses
Next Topic:Some thoughts on EMF intrefaces
Current Time: Mon Nov 10 05:03:09 EST 2025
Powered by FUDForum. Page generated in 0.15720 seconds
