Home » Archived » BIRT » Crosstabs in RAP application(Script engine reference error in osgi/Equinox environment)
Crosstabs in RAP application [message #759605] Tue, 29 November 2011 05:33 Go to next message
Hello everyone,
I'm new in BIRT but I have to create some crosstabs in our RAP application. We are using BIRT 2.6.1. I can design the crosstab reports in Eclipse and they can be seen as HTML but in the RAP app I got the following error.
Do you have any idea why?
Gábor
2011.11.29. 10:03:54 org.eclipse.birt.report.engine.executor.ExtendedGenerateExecutor execute
SEVERE: A BIRT exception occurred: Error evaluating Javascript expression. Script engine error: ReferenceError: "dimension" is not defined.
Script source: , line: 0, text:
dimension["MatchColumnGroup"]["folder"]. See next exception for more information.
org.eclipse.birt.data.engine.core.DataException: A BIRT exception occurred: Error evaluating Javascript expression. Script engine error: ReferenceError: "dimension" is not defined.
at org.eclipse.birt.data.engine.core.DataException.wrap(DataException.java:118)
at org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJSAsExpr(ScriptEvalUtil.java:1005)
at org.eclipse.birt.data.engine.expression.ExprEvaluateUtil.doEvaluateRawExpression(ExprEvaluateUtil.java:281)
at org.eclipse.birt.data.engine.expression.ExprEvaluateUtil.evaluateRawExpression(ExprEvaluateUtil.java:236)
at org.eclipse.birt.data.engine.impl.PreparedDummyQuery$ResultIterator.<init>(PreparedDummyQuery.java:532)
at org.eclipse.birt.data.engine.impl.PreparedDummyQuery$ResultIterator.<init>(PreparedDummyQuery.java:509)
at org.eclipse.birt.data.engine.impl.PreparedDummyQuery$QueryResults.getResultIterator(PreparedDummyQuery.java:368)
at org.eclipse.birt.report.engine.data.dte.QueryResultSet.<init>(QueryResultSet.java:98)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteQuery(DteDataEngine.java:168)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:265)
at org.eclipse.birt.report.engine.executor.ExtendedGenerateExecutor.executeQueries(ExtendedGenerateExecutor.java:205)
at org.eclipse.birt.report.engine.executor.ExtendedGenerateExecutor.execute(ExtendedGenerateExecutor.java:65)
at org.eclipse.birt.report.engine.executor.ExtendedItemExecutor.execute(ExtendedItemExecutor.java:62)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:34)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:90)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:99)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:180)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
at com.lhsystems.cp.ri3.gui.rap.reportingpage.ReportingPage.createBrowserSection(ReportingPage.java:134)
at com.lhsystems.cp.ri3.gui.rap.reportingpage.ReportingPage.createFormContent(ReportingPage.java:158)
at org.eclipse.ui.forms.editor.FormPage$1.run(FormPage.java:152)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:66)
at org.eclipse.ui.forms.editor.FormPage.createPartControl(FormPage.java:150)
at org.eclipse.ui.forms.editor.FormEditor.pageChange(FormEditor.java:477)
at org.eclipse.ui.part.MultiPageEditorPart.setActivePage(MultiPageEditorPart.java:962)
at org.eclipse.ui.forms.editor.FormEditor.setActivePage(FormEditor.java:616)
at org.eclipse.ui.forms.editor.SharedHeaderFormEditor.createPages(SharedHeaderFormEditor.java:103)
at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:310)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:658)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:429)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:594)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:312)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:185)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:265)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:64)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:479)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1267)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1220)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1619)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:508)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:106)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:494)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:115)
at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:65)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:217)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:207)
at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:782)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:680)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:640)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2716)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2630)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2622)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2573)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2569)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2553)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2536)
at com.lhsystems.cp.ri3.gui.rap.common.AbstractEditorHandler.openEditor(AbstractEditorHandler.java:14)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:309)
at org.springframework.osgi.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:58)
at org.springframework.osgi.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:62)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:131)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:119)
at org.springframework.osgi.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.java:56)
at org.springframework.osgi.service.util.internal.aop.ServiceTCCLInterceptor.invoke(ServiceTCCLInterceptor.java:39)
at org.springframework.osgi.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:59)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at $Proxy105.openEditor(Unknown Source)
at com.lhsystems.cp.ri3.gui.rap.common.internal.EditorOpener.openEditor(EditorOpener.java:22)
at $Proxy359.openEditor(Unknown Source)
at com.lhsystems.cp.ri3.gui.rap.dashboardpage.DashboardPageModel.openReportEditor(DashboardPageModel.java:98)
at com.lhsystems.cp.ri3.gui.rap.dashboardpage.DashboardPageController.actionPerformed(DashboardPageController.java:68)
at com.lhsystems.cp.ri3.gui.rap.common.mediator.AbstractMediator.fireAction(AbstractMediator.java:60)
at com.lhsystems.cp.ri3.gui.rap.common.mediator.AbstractMediator.fireCommandAction(AbstractMediator.java:77)
at com.lhsystems.cp.ri3.gui.rap.dashboardpage.DashboardPageMediator$9.widgetSelected(DashboardPageMediator.java:80)
at org.eclipse.swt.events.SelectionEvent.dispatchToObserver(SelectionEvent.java:194)
at org.eclipse.rwt.internal.events.Event.processEvent(Event.java:44)
at org.eclipse.swt.events.TypedEvent.processEvent(TypedEvent.java:161)
at org.eclipse.swt.events.TypedEvent.executeNext(TypedEvent.java:201)
at org.eclipse.swt.widgets.Display.runPendingMessages(Display.java:1100)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:1090)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2390)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2351)
at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:2206)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:424)
at org.eclipse.jface.internal.databinding.realmadapter.RealmAdapter.run(RealmAdapter.java:44)
at org.eclipse.rap.ui.internal.RealmAdapterHook.runWithDefault(RealmAdapterHook.java:48)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:427)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:157)
at com.lhsystems.cp.ri3.gui.rap.Application.createUI(Application.java:15)
at org.eclipse.rwt.internal.lifecycle.EntryPointManager.createUI(EntryPointManager.java:92)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWTLifeCycle.java:245)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadController.run(RWTLifeCycle.java:114)
at java.lang.Thread.run(Thread.java:662)
at org.eclipse.rwt.internal.lifecycle.UIThread.run(UIThread.java:102)
Re: Crosstabs in RAP application [message #782726 is a reply to message #759605] Tue, 24 January 2012 04:56 Go to previous message
The problem was that the running environment was not complete. Some bundles were missing from the running target platform Confused
Previous Topic:Data set in dynamic text
Next Topic:"Processing Please Wait" on Preview lasts too long
Current Time: Sat Jul 26 03:00:42 EDT 2025
Powered by FUDForum. Page generated in 0.03828 seconds
