Home » Newcomers » Newcomers » problem installing svn on Eclipse galileo
problem installing svn on Eclipse galileo [message #759516] Mon, 28 November 2011 16:41 Go to next message
Iam trying to install svn on Eclipse Galileo,
steps what i did:
Help - >install new software. selected
Galileo - site -download.eclipse.org/releases/galileo from dropdown named 'Work With'
Tried to add the site, www.polarion.org/projects/subversive/download/eclipse/2.0/update-site/
it gives same error , no repository found.
Not sure what the problem is.
I want to setup svn on my eclipse.
Not able to follow the steps which i find online, as i get these errors.
Please help.
Thanks.
Adithi
Re: problem installing svn on Eclipse galileo [message #759521 is a reply to message #759516] Mon, 28 November 2011 17:14 Go to previous messageGo to next message
> steps what i did:
> Help - >install new software. selected Galileo - site
> Please help.
> Thanks.
> Adithi
Originally (4 years ago), I used Subversive, but of late (the last
couple of years), I don't find it works and I shifted to Subclipse.
Here's what I'm doing:
http://www.javahotchocolate.com/tutorials/subclipse.html
Re: problem installing svn on Eclipse galileo [message #759541 is a reply to message #759521] Tue, 29 November 2011 00:40 Go to previous messageGo to next message
For any url I was giving, it gives me the same error: no repository found (either it is subversive or subclipse).
I tried several ways and have it installed in eclipse.
This is how i got :
Instead of adding this site in install updates option , subclipse.tigris.org/servlets/ProjectDocumentList?folderID=2240
I opened the url, downloaded a stable zip file (site-1.8.3.zip ) in my localmachine,
extracted zip folder- it extracts some folders and a plugins folder.
copied all folders into Eclipse-plugins directory and
the plugins(.jars) from extracted plugins folder are copied directly into Eclipse plugins folder.
Adithi.
Re: problem installing svn on Eclipse galileo [message #759669 is a reply to message #759541] Tue, 29 November 2011 09:59 Go to previous message
On 28-Nov-11 22:40, cooladithi4u wrote:
> This is how i got : Instead of adding this site in install updates
> localmachine,
> copied all folders into Eclipse-plugins directory and the plugins(.jars)
> folder.
> Adithi.
--not considered "best practice" for installing plug-ins to Eclipse,
should work, however.
If you're still having trouble at this point, I'd suggest you tell me in
terms of my article where things go south.
Previous Topic:Build Project grayed out when in editor
Next Topic:getenv works but getProperty does not
Current Time: Sun Jul 27 14:08:24 EDT 2025
Powered by FUDForum. Page generated in 0.08196 seconds
