[xtend] typeSelect() [message #759347] |
Mon, 28 November 2011 08:06  |
i have a simple transformation in which i only want to do example given typeSelect(uml::Property).
First the workflow file :
<workflow>
<!-- Properties -->
<!-- Initialize CompoSE workflow components -->
<bean class="org.eclipse.xtend.typesystem.uml2.Setup" standardUML2Setup="true"/>
<!-- Parse Model -->
<component id="xmiParser" class="org.eclipse.xtend.typesystem.emf.XmiReader">
<modelFile value="scenarios/indicators/model/test.uml"/>
<outputSlot value="test"/>
</component>
<!-- Run indicator -->
<component class="org.eclipse.xtend.XtendComponent">
<metaModel id='umlMetaModel' class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel"/>
<metaModel id='indicatorCollectionResult' class="org.eclipse.xtend.typesystem.emf.EmfMetaModel">
<metaModelFile value="scenarios/indicators/indicatorOutput/CollectionResult.ecore" />
</metaModel>
<invoke value="scenarios::indicators::stepbystepIndicator::typeSelect::run(test)"/>
<outputSlot value="values"/>
</component>
<!-- Output result -->
<component class="org.eclipse.xtend.typesystem.emf.XmiWriter">
<modelFile value="scenarios/indicators/output/outputModel.xml"/>
<inputSlot value="values"/>
</component>
</workflow>
and here the extend file typeSelect
create result::CollectionResult run(result::CollectionResult in) :
result.addAll(in.result.typeSelect(uml::Property))->
Now my question. Is there any possibility to give the type from the workflow to the extend file. Something like
value="scenarios::indicators::stepbystepIndicator::typeSelect::run(test, uml::Property)"/>
create result::CollectionResult run(result::CollectionResult in, Type t)
To give a string its no problem, but i dont know how to do it with a type. Thanks in advance!
Re: [xtend] typeSelect() [message #759475 is a reply to message #759446] |
Mon, 28 November 2011 14:13   |
indeed, the xtend component does not seem to like this notation, the xpand component does
here a workaround. please file a ticket into bugzilla
package workflow;
import java.io.BufferedOutputStream;
import java.io.FileOutputStream;
import java.io.IOException;
import java.io.InputStream;
import java.io.OutputStream;
import java.util.ArrayList;
import java.util.List;
import org.apache.commons.logging.Log;
import org.apache.commons.logging.LogFactory;
import org.eclipse.emf.mwe.core.WorkflowContext;
import org.eclipse.emf.mwe.core.issues.Issues;
import org.eclipse.emf.mwe.core.monitor.ProgressMonitor;
import org.eclipse.emf.mwe.core.resources.ResourceLoaderFactory;
import org.eclipse.internal.xtend.util.ProfileCollector;
import org.eclipse.xtend.XtendComponent;
import org.eclipse.xtend.expression.AbstractExpressionsUsingWorkflowComponent;
import org.eclipse.xtend.expression.ExecutionContextImpl;
import org.eclipse.xtend.expression.ExpressionFacade;
import org.eclipse.xtend.expression.Resource;
import org.eclipse.xtend.expression.Variable;
public class FixedXtendComponent extends AbstractExpressionsUsingWorkflowComponent {
private static final String COMPONENT_NAME = "Xtend Component";
private final Log log = LogFactory.getLog(getClass());
String extensionFile = null;
private final List<String> extensionAdvices = new ArrayList<String>();
/** Stores the value of the 'invoke' property. Needed for error analysis. */
private String invokeExpression;
private String expression = null;
private String collectProfileSummary = null;
private String verboseProfileFilename = null;
private String outputSlot = WorkflowContext.DEFAULT_SLOT;
* Adds an extension advice.
* @param extensionAdvice
* the advice
public void addExtensionAdvice(final String extensionAdvice) {
if (!extensionAdvices.contains(extensionAdvice)) {
extensionAdvices.add(extensionAdvice);
* @see org.eclipse.xtend.expression.AbstractExpressionsUsingWorkflowComponent#checkConfigurationInternal(org.eclipse.emf.mwe.core.issues.Issues)
public void checkConfigurationInternal(final Issues issues) {
super.checkConfigurationInternal(issues);
// Try to create detailed error message (see Bug#172567)
final String compPrefix = getId() != null ? getId() + ": " : "";
if (invokeExpression == null || invokeExpression.trim().length() == 0) {
issues.addError(compPrefix + "Property 'invoke' not specified.");
return;
if (extensionFile == null) {
+ "Error parsing property 'invoke': Could not extract name of the extension file.");
return;
final InputStream in = getExtFileIS();
if (in == null || expression == null) {
issues.addError(compPrefix + "Property 'invoke' not specified properly. AbstractExtension file '"
+ extensionFile + "' not found.");
return;
try {
in.close();
catch (final IOException e) {
log.error("I/O exception", e);
if (expression == null) {
+ "Error parsing property 'invoke': Could not extract the expression to invoke in extension file '"
+ extensionFile + "'.");
return;
* @see org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent#getLogMessage()
public String getLogMessage() {
return "executing '" + extensionFile + "'";
* @see org.eclipse.xtend.expression.AbstractExpressionsUsingWorkflowComponent#invokeInternal2(org.eclipse.emf.mwe.core.WorkflowContext,
* org.eclipse.emf.mwe.core.monitor.ProgressMonitor,
* org.eclipse.emf.mwe.core.issues.Issues)
public void invokeInternal2(final WorkflowContext ctx, final ProgressMonitor monitor, final Issues issues) {
if (in == null) {
issues.addError("Cannot find extension file: " + extensionFile);
return;
else {
try {
in.close();
OutputStream verboseProfileOutputStream = null;
if (verboseProfileFilename != null) {
try {
verboseProfileOutputStream = new BufferedOutputStream(new FileOutputStream(verboseProfileFilename));
ProfileCollector.getInstance().setDetailedLoggingWriter(verboseProfileOutputStream);
catch (final IOException exc) {
log.warn("could not open profiling log file", exc);
ExecutionContextImpl ec = getExecutionContext(ctx);
for (final String advice : extensionAdvices) {
final String[] allAdvices = advice.split(",");
for (final String string : allAdvices) {
ec.registerExtensionAdvices(string.trim());
ec = (ExecutionContextImpl) ec.cloneWithResource(new Resource() {
private String name = "noName";
public String getFullyQualifiedName() {
return name;
public String[] getImportedExtensions() {
return new String[] { extensionFile };
public String[] getImportedNamespaces() {
return new String[0];
public void setFullyQualifiedName(final String fqn) {
name = fqn;
final String[] slots = ctx.getSlotNames();
for (final String slot : slots) {
ec = (ExecutionContextImpl) ec.cloneWithVariable(new Variable(slot, ctx.get(slot)));
if (monitor != null) {
ec.setMonitor(monitor);
final Object result = new ExpressionFacade(ec).evaluate(expression);
ctx.set(outputSlot, result);
ProfileCollector.getInstance().finish();
if ("true".equalsIgnoreCase(this.collectProfileSummary)) {
log.info("profiling info: \n" + ProfileCollector.getInstance().toString());
if (verboseProfileOutputStream != null) {
try {
verboseProfileOutputStream.close();
log.warn("problem closing profile log file", exc);
* Sets the collect profile summary.
* @param summary
* the summary
public void setCollectProfileSummary(final String summary) {
collectProfileSummary = summary;
* Sets the invoke expression.
* @param invokeExpr
* the invoke expression
public void setInvoke(final String invokeExpr) {
invokeExpression = invokeExpr;
final int i = invokeExpr.substring(0, invokeExpr.indexOf('(')).lastIndexOf("::");
if (i != -1) {
extensionFile = invokeExpr.substring(0, i);
expression = invokeExpr.substring(i + 2);
else {
expression = invokeExpr;
* Sets the output slot.
* @param outputSlot
* the output slot
public void setOutputSlot(final String outputSlot) {
this.outputSlot = outputSlot;
* Sets the filename for the verbose profile.
* @param fileName
* the filename
public void setVerboseProfileFilename(final String fileName) {
verboseProfileFilename = fileName;
public String getComponentName() {
return COMPONENT_NAME;
private InputStream getExtFileIS() {
final InputStream in = ResourceLoaderFactory.createResourceLoader().getResourceAsStream(
extensionFile.replace("::", "/") + ".ext");
return in;
~Christian
FUDForum. Page generated in 0.04377 seconds
