Home » Modeling » GMF (Graphical Modeling Framework) » Retain diagram when double clicked on xxx.xxx_diagram on navigator windowvigator (Retain diagram when double clicked on xxx.xxx_diagram on navigator windowvigator )
Retain diagram when double clicked on xxx.xxx_diagram on navigator windowvigator [message #759437] Mon, 28 November 2011 11:32 Go to next message
In my RCP Application, when I double click on xxx.xxx_diagram file which is on the navigator window, the editor crashes. Like I am not able to retain the gmf diagram. Anyone has the idea ?
Vinay
Re: Retain diagram when double clicked on xxx.xxx_diagram on navigator windowvigator [message #759497 is a reply to message #759437] Mon, 28 November 2011 14:45 Go to previous messageGo to next message
Vinay,
You're like a question generator. :-(
In this post you've not provided a single iota of useful information;
there's not even a stack trace. How can you possibly expect anyone to
provide a useful answer?
Surely the debugger is your best resource to track down this type of
problem.
On 28/11/2011 5:32 PM, vinny503 wrote:
> Regards,
> Vinay
Re: Retain diagram when double clicked on xxx.xxx_diagram on navigator windowvigator [message #759537 is a reply to message #759497] Mon, 28 November 2011 23:39 Go to previous messageGo to next message
Actually I might have committed some mistakes while adding *.xxx_diagram file to the navigator content in plugin.xml of xxx.diagram project. plugin used for this would be org.eclipse.ui.navigator.navigatorContent but I am not sure the exact procedure to do this that is why I might be facing problem here. If you could provide me the way to do this it would be really helpful. I am sure there is some more thing to be done in Extension tab.
Vinay
[Updated on: Tue, 29 November 2011 00:01] by Moderator
Re: Retain diagram when double clicked on xxx.xxx_diagram on navigator windowvigator [message #759558 is a reply to message #759537] Tue, 29 November 2011 02:44 Go to previous message
Vinay,
At some point I'll just give up answering any of your question. You
made some mistakes you say, but what mistakes are anyone's guess so you
might as well omit that information because it's useless. Your question
about navigatorContent isn't a GMF question. Best you find
documentation for that extension point and look at examples.
On 29/11/2011 5:39 AM, vinny503 wrote:
> xxx.diagram project. plugin used for this, would be
> Regards,
> Vinay
Previous Topic:Create Request (CreationEditPolicy)
Next Topic:Handling error in gmf
Current Time: Sun Jul 27 14:08:55 EDT 2025
Powered by FUDForum. Page generated in 0.23511 seconds
