Home » Modeling » TMF (Xtext) » Unary Minus in Expressions(-1 - - -1)
Unary Minus in Expressions [message #759297] |
Mon, 28 November 2011 04:55  |
My grammar shall parse expressions of the form "a * -b ---3", similar to arithmetic expressions in java.
The binary operators and their precedence work pretty good already, but I can't find a way to implement the unary minus properly. This minimal example is the closest I could come:
AdditiveExpression returns BExpression :
UnaryOrPrimaryExpression
({BBinaryOpExpression.leftExpr=current} functionName=("+" | "-") rightExpr=UnaryOrPrimaryExpression)*
UnaryOrPrimaryExpression returns BExpression
: PostopExpression
| UnaryExpression
UnaryExpression returns BExpression : {BUnaryOpExpression}
functionName="-" expr=PrimaryExpression
PostopExpression returns BExpression :
PrimaryExpression ({BUnaryPostOpExpression.expr=current} functionName = ("++"))?
: ValueLiteral
ValueLiteral :
value = INT
This already parses "-1--1" to "(-1)-(-1)", which is quite good, but not good enough:
The input can contain strings with multiple minuses as "-1-----1". This is possible because I have no Pre- or Postoperators like -- and ++.
The second problem with this grammar is, that I currently need to keep the PostopExpression to be able to parse the minus sign correctly at all.
The shown solution was proposed in older posts, but I just can't get them to run anymore (using Xtext 2.1)! I also strapped down the Expression part of the B3 Grammar (nice sample!), but also this grammar can't be build by a standard MWE2 file.
Do you have any hints on how to solve this? Let's say all I want is an expression with +, - and unary minus(es).
Thank you,
Moritz
Re: Unary Minus in Expressions [message #759331 is a reply to message #759297] |
Mon, 28 November 2011 07:09   |
Quote:My grammar shall parse expressions...
That's the spirit!
The essence of these older posts was to take care of the consequences of the differences between datatype and parser rules (which are called during parsing, after lexing, and therefore have some context) and terminals/lexing (which happens context-free, before the actual parsing, and just 'gobbles up' the input as greedily as it can). You left out the precise terminals, but I guess you re-use common.Terminals. In that case, "-1-----1" is lexed as: '-', INT(1), '-' (x5), INT(1).
Rewriting as follows should do the trick:
: PrimaryExpression // call next precedence level
| UnaryExpression
functionName="-" expr=UnaryExpression // call itself, making unitary minus left-associative (instead of non-associative)
See http://dslmeinte.wordpress.com/2011/03/21/pre-and-postfix-operators-in-xtext/ for more explanation.
Re: Unary Minus in Expressions [message #759333 is a reply to message #759297] |
Mon, 28 November 2011 07:14   |
Hi Moritz,
this should do the trick:
functionName="-" expr=UnaryOrPrimaryExpression // <- see here
Sebastian
Am 28.11.11 10:55, schrieb Moritz:
> : PostopExpression | UnaryExpression
> : ValueLiteral
> ValueLiteral :
> value = INT
> good enough:
> http://www.eclipse.org/forums/index.php/mv/msg/202744/673403/#msg_673403
> http://www.eclipse.org/forums/index.php/mv/msg/202027/645570/#msg_645570, but
> http://git.eclipse.org/c/b3/b3.git/tree/org.eclipse.b3.beelang/src/org/eclipse/b3/BeeLang.xtext
> file.
> Thank you,
> Moritz
Re: Unary Minus in Expressions [message #759336 is a reply to message #759331] |
Mon, 28 November 2011 07:18   |
Meinte,
this won't work since
will recurse endlessly and finally fail when all leading '-' were consumed.
Sebastian
Am 28.11.11 13:09, schrieb Meinte Boersma:
> Quote:
> That's the spirit! :)
> | UnaryExpression
> See
Re: Unary Minus in Expressions [message #759339 is a reply to message #759297] |
Mon, 28 November 2011 07:20   |
What happens if you use:
: PrimaryExpression | UnaryExpression
: ValueLiteral
Don't see why you would need the PostOp Rule.
The reason multipe '-' does not work is probably because the UnaryOp
only accepts a PrimaryExpression as the RHS. Did you try something like:
- henrik
On 2011-28-11 10:55, Moritz wrote:
> : ValueLiteral
> ValueLiteral :
> value = INT
> good enough:
> file.
> Thank you,
> Moritz
Current Time: Mon Jul 28 17:10:32 EDT 2025
Powered by FUDForum. Page generated in 0.03746 seconds
