Home » Language IDEs » Java Development Tools (JDT) » Java Development related questions.(Compiler questions.)
icon5.gif  Java Development related questions. [message #758640] Wed, 23 November 2011 22:47 Go to next message
-Does the eclipse project have it's own java compiler, independent of the gnu eclipse compiler?
-Is there such a compiler for Linux and Windows?
-Is there a 32 and 64 bit implementation of said compiler for Windows?
-Is there a java class compiler which makes multi-platform java class files less easy to visually read and interpret (unlike Sun/Oracle/GNU) class compilation efforts?
-Does the eclipse "indigo" java standard edition editor come with a
gui construction/widget graphical user interface construction palette
that allows for graphical/physical editing of a GUI that generates java source code behind the scenes?
[Updated on: Wed, 23 November 2011 23:32] by Moderator
Re: Java Development related questions. [message #758648 is a reply to message #758640] Thu, 24 November 2011 00:36 Go to previous messageGo to next message
Eclipse has its own Java compiler, see
http://blog.deepakazad.com/2010/05/ecj-eclipse-java-compiler.html
I think GNU uses the Eclipse compiler, see
http://gcc.gnu.org/java/index.html
The Eclipse compiler is available for all the platforms that Eclipse is
available on, i.e all the platforms mentioned on the download page
http://download.eclipse.org/eclipse/downloads/drops/R-3.7.1-201109091335/index.php
Deepak Azad
http://wiki.eclipse.org/JDT/FAQ
icon5.gif  Re: Java Development related questions. [message #758655 is a reply to message #758648] Thu, 24 November 2011 01:39 Go to previous messageGo to next message
- Is the eclipse compiler for java (ecj) part of the java development toolkit (jdt),
part of the eclipse jdk? Is the eclipse jdk the thing to download?
I have given that a go, and found the .class dead easy to read just by looking.
If I am compiling an enterprise java bean for a client I must have .class files.
I don't seem to be able to compile a non-main method classes or interfaces in gcj, since the following attempt fails (without any reference to some main method class):
gcj ClassFileA.java -o ClassFileA.bin
gcj ClassFileA.java -o ClassFileB.bin
gcj ClassFileA.java -o ClassFileC.bin
Say I am using java annotations, and a more recent version of JBoss to load the .ear ejb file and ejb. If the java bytecode compiles for my ejb must compile to a .class file, there isn't much security from client inspection for that. Can someone tell me what the advised .class approach is with EJB 3.0 (annotated) EJB's compiled to either class or binary files, with the following related files (3.0 includes some backwards compatability), particularly if I wish to use a non-commercial publicly available java compiler:
ClassFileA.java LocalHome implementing/annotated interface.
ClassFileB.java EJBObject Remote Object implementing/annotated interface.
ClassFileC.java SessionBean EJB core implementing, possibly annotated class.
[Updated on: Thu, 24 November 2011 03:38] by Moderator
Re: Java Development related questions. [message #758701 is a reply to message #758655] Thu, 24 November 2011 05:09 Go to previous messageGo to next message
> toolkit (jdt),
Yes
There is no such thing as 'Eclipse JDK'.
Eclipse uses ECJ, you can also download the batch compiler separately.
As mentioned on the blog look for 'JDT Core Batch Compiler' section on
the download page.
Deepak Azad
Re: Java Development related questions. [message #759246 is a reply to message #758701] Sun, 27 November 2011 22:00 Go to previous messageGo to next message
I don't seem to be able to compile a non-main method classes or interfaces in gcj.
Say I am using java annotations, and a more recent version of JBoss to load the .ear file and ejb. If the java bytecode compiler for my ejb.java must compile to a .class file, there isn't much security from client inspection of the .class file. Can someone tell me what the advised .class approach is with EJB 3.0 (annotated) EJB's compiled to either class or binary files, with the following related files (3.0 includes some backwards compatability), particularly if I wish to use a non-commercial publicly available java compiler:
Where should I look for a $0 for commercial use, publically available .java compiler to .class bytecode that can't be so easily inspected visually and interpreted?
Re: Java Development related questions. [message #759254 is a reply to message #759246] Mon, 28 November 2011 00:35 Go to previous messageGo to next message
> toolkit (jdt),
> looking.
Eclipse compiler is not much different from 'javac' in terms of being
able to visually inspect class files.
I think there are some commercial tools available which claim to do
this, but I don't recall any tool which does this in the open source world.
Deepak Azad
Re: Java Development related questions. [message #759255 is a reply to message #759246] Mon, 28 November 2011 00:37 Go to previous messageGo to next message
You can download the ecj (JDT Core Batch Compiler) from
naturally if you download e.g. the default Eclipse SDK you'll get the
ecj as well.
Am 28.11.11 04:00, schrieb Zachary1234:
> toolkit (jdt),
> looking.
> .class files.
> interfaces in gcj.
Now you are suddenly talking aboute gcj and not ecj.
> class.
Not sure what you are trying to say us here but anyways and why you
think you need to compile things your own setting up ecj because there
are builds tools, the IDEs export features, ...
See the link above.
Tom
Re: Java Development related questions. [message #759257 is a reply to message #759255] Mon, 28 November 2011 01:16 Go to previous messageGo to next message
Is there anyone else out there who can reply to me here with an example or such a java compiler
or a web URL to look at?
Re: Java Development related questions. [message #759350 is a reply to message #759257] Mon, 28 November 2011 08:18 Go to previous messageGo to next message
There are some class file obfuscators that you could try to use. You could even encrypt your class files and use your own class loader or decrypt and load the class file.
Re: Java Development related questions. [message #759371 is a reply to message #759257] Mon, 28 November 2011 08:49 Go to previous messageGo to next message
Am 28.11.11 07:16, schrieb Zachary1234:
http://proguard.sourceforge.net/
Tom
Re: Java Development related questions. [message #759523 is a reply to message #759371] Mon, 28 November 2011 17:54 Go to previous messageGo to next message
I have already used proguard obfuscation, and found that it isn't too
effective on small java classes.
or such a java compiler or a web URL to look at?
Re: Java Development related questions. [message #765981 is a reply to message #759523] Wed, 14 December 2011 21:53 Go to previous messageGo to next message
Good post and replies. They are help for me, as a java beginner. I wanna use java to write a java barcode generator, which I saw from Onbarcode. It is easy-use, I want to write one like it. Do you have any good suggestions?
Re: Java Development related questions. [message #1244330 is a reply to message #765981] Wed, 12 February 2014 02:13 Go to previous messageGo to next message
as for java programmer, i created www.keepautomation.com/products/java_barcode/barcodes/pdf_417.htmlpdf-417 barcodein java ,and here is the guide: www.keepautomation.com/guide/java_barcode_generator.html
[Updated on: Mon, 30 June 2014 09:46] by Moderator
Re: Java Development related questions. [message #1771851 is a reply to message #758640] Thu, 31 August 2017 08:04 Go to previous messageGo to next message
Hello , I have some problems with this project. My friend did this project and I can t understand what's going on with an error, after compilation: "Unable to find an Ant file" ... can someone help me or correct my project. Thank you a lot!
Re: Java Development related questions. [message #1772937 is a reply to message #1771851] Tue, 19 September 2017 02:05 Go to previous messageGo to next message
1. The Java compiler that comes with Eclipse is not the standard javac compiler you get with the Java SDK. Nope, it's a completely separate compiler.
3. Yes. Even on 32 bit machines the .NET Framework provides System.Int64, many C/C++ compilers provide long long/__int64. Obviously the operations on such types, on 32 bit machines, are somehow emulated . For this reason they are available, but are not used unless necessary.
Re: Java Development related questions. [message #1779223 is a reply to message #1772937] Thu, 04 January 2018 02:58 Go to previous message
Previous Topic:Java I/O and Argument Passing Inside Eclipse
Next Topic:Maven library not found when I test an Eclipse Plug-In
Current Time: Fri Jul 25 22:09:19 EDT 2025
Powered by FUDForum. Page generated in 0.07514 seconds
