Home » Archived » EGL Development Tools » Changes to the update site
Changes to the update site [message #756031] Thu, 10 November 2011 09:18 Go to next message
Hi all,
A change went into last night's build with regard to the update site. The features have been renamed, and the SDK feature has been removed. The SDK feature was just the regular feature plus the source feature, which was a bit redundant.
If you do not have the SDK feature installed then no action is needed on your part.
If you had the SDK feature installed, you will no longer see updates for it. You should uninstall it and then install both of the available EDT features:
EGL Web Developer Tools
EGL Web Developer Tools Source Code
-Justin
Re: Changes to the update site [message #756099 is a reply to message #756031] Thu, 10 November 2011 16:13 Go to previous messageGo to next message
Update: we decided to change some stuff around with the features so now, if you have "Group items by category" you will see:
[ ] EGL Development Tools 0.7.0
   [ ] EGL Web Developer Tools
   [ ] EGL Web Developer Tools with Source Code
If you uncheck "Group items by category" then you will additionally see:
[ ] EGL Web Developer Tools Source Code
The "EGL Web Developer Tools with Source Code" feature is the combination of the other two. It won't hurt anything to install all three, but it's not necessary.
-Justin
Re: Changes to the update site [message #756135 is a reply to message #756099] Fri, 11 November 2011 02:38 Go to previous messageGo to next message
For some reason, I failed to update my nightly build even if I only the Web Dev Tool feature. I finally re-installed nightly build on an new Eclipse instance.
Re: Changes to the update site [message #759236 is a reply to message #756031] Sun, 27 November 2011 18:25 Go to previous messageGo to next message
I'm confused (though that's hardly new). When I went to download EDT following the standard instructions for EDT 0.7 M3, I saw the three categories, EDT, EDT SDK and EDT Source Code. All have version 0.7.0.v201110251332-etcetc.
What got renamed? Did I just download an out of date version?
Re: Changes to the update site [message #759237 is a reply to message #759236] Sun, 27 November 2011 18:28 Go to previous message
Nevermind. I answered my own question. The nightly build is what was renamed. I am now downloading that build, v201111270901. I'm going to have to get a faster connection to keep up... Smile
Previous Topic:Explaining generation - Its different than RBD
Next Topic:Getting Started
Current Time: Sun Jul 27 14:32:57 EDT 2025
Powered by FUDForum. Page generated in 0.03137 seconds
