Error Duplicate aggregation name: COUNT [message #759110] |
Sat, 26 November 2011 08:44  |
Hello All,
I am using Birt Report Engine version 3.7.1. I have created a report with one Table and one Chart with a Stored Procedure in backend for the dataset. The Database is MySQL. The report works fine in Report Viewer but when I export to HTML using Birt Engine, I get the exception shown below. This error is only seen when I add the Chart element to the Report. If I only have the Table element, the report works fine both in Viewer as well as in the Engine.
Exception is as follows:
The following items have errors:
Chart (id = 105):
- Duplicate aggregation name: COUNT. (Element ID:105)
Duplicate aggregation name: COUNT. ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: Duplicate aggregation name: COUNT. (Element ID:105)
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1214)
at org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder$QueryBuilderVisitor.visitExtendedItem(ReportQueryBuilder.java:693)
at org.eclipse.birt.report.engine.ir.ExtendedItemDesign.accept(ExtendedItemDesign.java:45)
at org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder.build(ReportQueryBuilder.java:256)
at org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder$QueryBuilderVisitor.visitCell(ReportQueryBuilder.java:1241)
at org.eclipse.birt.report.engine.ir.CellDesign.accept(CellDesign.java:202)
at org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder$QueryBuilderVisitor.visitRow(ReportQueryBuilder.java:1207)
at org.eclipse.birt.report.engine.ir.RowDesign.accept(RowDesign.java:108)
at org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder$QueryBuilderVisitor.handleListingBand(ReportQueryBuilder.java:1097)
at org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder$QueryBuilderVisitor.visitTableItem(ReportQueryBuilder.java:934)
at org.eclipse.birt.report.engine.ir.TableItemDesign.accept(TableItemDesign.java:53)
at org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder.build(ReportQueryBuilder.java:237)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.prepare(AbstractDataEngine.java:180)
at org.eclipse.birt.report.engine.executor.ReportExecutor.execute(ReportExecutor.java:122)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportExecutor.execute(WrappedReportExecutor.java:60)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplciateReportExecutor.execute(SuppressDuplciateReportExecutor.java:42)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportExecutor.execute(LocalizedReportExecutor.java:61)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:178)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
at com.figr.retailer.reports.action.ExportOptions.ReportExportedWithOption(ExportOptions.java:129)
at com.figr.retailer.reports.action.RunBirt.runReport(RunBirt.java:108)
at com.figr.retailer.reports.action.BirtStruts.execute(BirtStruts.java:32)
at com.opensymphony.xwork2.DefaultActionInvocation.invokeAction(DefaultActionInvocation.java:452)
at com.opensymphony.xwork2.DefaultActionInvocation.invokeActionOnly(DefaultActionInvocation.java:291)
at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:254)
at com.opensymphony.xwork2.interceptor.DefaultWorkflowInterceptor.doIntercept(DefaultWorkflowInterceptor.java:176)
at com.opensymphony.xwork2.interceptor.MethodFilterInterceptor.intercept(MethodFilterInterceptor.java:98)
at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:248)
at com.opensymphony.xwork2.validator.ValidationInterceptor.doIntercept(ValidationInterceptor.java:263)
at org.apache.struts2.interceptor.validation.AnnotationValidationInterceptor.doIntercept(AnnotationValidationInterceptor.java:68)
at com.opensymphony.xwork2.interceptor.ConversionErrorInterceptor.intercept(ConversionErrorInterceptor.java:138)
at com.opensymphony.xwork2.interceptor.ParametersInterceptor.doIntercept(ParametersInterceptor.java:207)
at com.opensymphony.xwork2.interceptor.StaticParametersInterceptor.intercept(StaticParametersInterceptor.java:190)
at org.apache.struts2.interceptor.MultiselectInterceptor.intercept(MultiselectInterceptor.java:75)
at org.apache.struts2.interceptor.CheckboxInterceptor.intercept(CheckboxInterceptor.java:94)
at org.apache.struts2.interceptor.FileUploadInterceptor.intercept(FileUploadInterceptor.java:243)
at com.opensymphony.xwork2.interceptor.ModelDrivenInterceptor.intercept(ModelDrivenInterceptor.java:100)
at com.opensymphony.xwork2.interceptor.ScopedModelDrivenInterceptor.intercept(ScopedModelDrivenInterceptor.java:141)
at org.apache.struts2.interceptor.debugging.DebuggingInterceptor.intercept(DebuggingInterceptor.java:270)
at com.opensymphony.xwork2.interceptor.ChainingInterceptor.intercept(ChainingInterceptor.java:145)
at com.opensymphony.xwork2.interceptor.PrepareInterceptor.doIntercept(PrepareInterceptor.java:171)
at com.opensymphony.xwork2.interceptor.I18nInterceptor.intercept(I18nInterceptor.java:176)
at org.apache.struts2.interceptor.ServletConfigInterceptor.intercept(ServletConfigInterceptor.java:164)
at com.opensymphony.xwork2.interceptor.AliasInterceptor.intercept(AliasInterceptor.java:190)
at com.opensymphony.xwork2.interceptor.ExceptionMappingInterceptor.intercept(ExceptionMappingInterceptor.java:187)
at org.apache.struts2.impl.StrutsActionProxy.execute(StrutsActionProxy.java:52)
at org.apache.struts2.dispatcher.Dispatcher.serviceAction(Dispatcher.java:498)
at org.apache.struts2.dispatcher.ng.ExecuteOperations.executeAction(ExecuteOperations.java:77)
at org.apache.struts2.dispatcher.ng.filter.StrutsPrepareAndExecuteFilter.doFilter(StrutsPrepareAndExecuteFilter.java:91)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:859)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
Caused by: org.eclipse.birt.chart.exception.ChartException: Duplicate aggregation name: COUNT.
at org.eclipse.birt.chart.reportitem.AbstractChartBaseQueryGenerator.addValueSeriesAggregateBindingForGrouping(AbstractChartBaseQueryGenerator.java:247)
at org.eclipse.birt.chart.reportitem.AbstractChartBaseQueryGenerator.addAggregateBindings(AbstractChartBaseQueryGenerator.java:624)
at org.eclipse.birt.chart.reportitem.AbstractChartBaseQueryGenerator.generateExtraBindings(AbstractChartBaseQueryGenerator.java:347)
at org.eclipse.birt.chart.reportitem.ChartBaseQueryHelper.createBaseQuery(ChartBaseQueryHelper.java:106)
at org.eclipse.birt.chart.reportitem.ChartReportItemQueryImpl.createQuery(ChartReportItemQueryImpl.java:163)
at org.eclipse.birt.chart.reportitem.ChartReportItemQueryImpl.createReportQueries(ChartReportItemQueryImpl.java:106)
at org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder$QueryBuilderVisitor.visitExtendedItem(ReportQueryBuilder.java:689)
... 89 more
Caused by: org.eclipse.birt.data.engine.core.DataException: Duplicate aggregation name: COUNT.
at org.eclipse.birt.data.engine.api.aggregation.AggregationManager.populateFactoryAggregations(AggregationManager.java:183)
at org.eclipse.birt.data.engine.api.aggregation.AggregationManager.populateAggregations(AggregationManager.java:153)
at org.eclipse.birt.data.engine.api.aggregation.AggregationManager.<init>(AggregationManager.java:123)
at org.eclipse.birt.data.engine.api.aggregation.AggregationManager.getInstance(AggregationManager.java:110)
at org.eclipse.birt.chart.reportitem.AbstractChartBaseQueryGenerator.setBindingExpressionDueToAggregation(AbstractChartBaseQueryGenerator.java:1050)
at org.eclipse.birt.chart.reportitem.AbstractChartBaseQueryGenerator.addValueSeriesAggregateBindingForGrouping(AbstractChartBaseQueryGenerator.java:207)
... 95 more
[Updated on: Sun, 27 November 2011 03:20] by Moderator
Re: Error Duplicate aggregation name: COUNT [message #808516 is a reply to message #808132] |
Mon, 27 February 2012 16:41   |
I modified the attached sample to use the derby sample db. Can you run
it and see if you get the same issue?
Jason
On 2/27/2012 7:45 AM, Risto Urb wrote:
> Hello,
> I have the exact same problem with charts. Everything is totally cool in Eclipse, but in tomcat I get the "Duplicate aggregation name: COUNT" error for chart (not much more to go on by). For viewing a Table everything is ok. I'm adding screenshots, the report created from sample db, as well as my servlet code that I created to use the Engine in my project.
> Call for servlet is as follows:
> <birt:viewer id="birtViewer" reportDesign="countryview.rptdesign"
> pattern="frameset"
> height="750"
> width="500"
> format="html">
> </birt:viewer>
> I am not sure if this is a BIRT problem at all, hopefully my own misusage of the tool, but I would really appreciate any help pointing out, where my mistake is.
> Thanks to everyone in advance.
Attachment: sample.zip
(Size: 5.20KB, Downloaded 215 times)
FUDForum. Page generated in 0.04396 seconds
