Home » Modeling » Epsilon » [Eugenia] Adding options to a node
[Eugenia] Adding options to a node [message #759078] Fri, 25 November 2011 20:10 Go to next message
my question is how i add specific actions to a node.
For example i have the following node in my model :
class Claim {
    attr String path;
When i right click on an instance of that node in canvas, i got a drop down menu where i can "add note" for example.
Can i add new options to this drop down menu and execute my own java code when the action is clicked ?
For example can i open the file specified in path variable ?
Greetings
[Updated on: Fri, 25 November 2011 20:10] by Moderator
Re: [Eugenia] Adding options to a node [message #759099 is a reply to message #759078] Sat, 26 November 2011 06:15 Go to previous messageGo to next message
Eugenia does not support that, I'm afraid. You'll need to tweak the GMF code generation models and the generated code for that.
Have you tried asking over on the GMF forum? I'm sure they'll be able to provide more information on what you need to do Smile.
[Updated on: Sat, 26 November 2011 06:15] by Moderator
Re: [Eugenia] Adding options to a node [message #759126 is a reply to message #759099] Sat, 26 November 2011 10:59 Go to previous messageGo to next message
Is it possible to add that option like mentioned here ?
http://www.eclipse.org/articles/article.php?file=Article-action-contribution/index.html#example3
But i dont know the right expansion points etc.
[Updated on: Sat, 26 November 2011 17:53] by Moderator
Re: [Eugenia] Adding options to a node [message #759150 is a reply to message #759126] Sat, 26 November 2011 17:56 Go to previous messageGo to next message
@namespace(uri="trustcasemodel", prefix="trustcasemodel")
@gmf(foo="bar")
package trustCase;
@gmf.diagram(onefile="false")
class TrustCase {
val Claim[*] valclaims;
class Claim {
   attr String path;
How can i get the path property of the selected Claim in the editor when using javacode?
In another plugin for example ?
[Updated on: Sat, 26 November 2011 18:51] by Moderator
Re: [Eugenia] Adding options to a node [message #759155 is a reply to message #759150] Sat, 26 November 2011 20:08 Go to previous messageGo to next message
Common,
it must be possible to read the properties from a node in java in any way.
Re: [Eugenia] Adding options to a node [message #759484 is a reply to message #759155] Mon, 28 November 2011 14:33 Go to previous messageGo to next message
In your extension you need to specify org.eclipse.gmf.runtime.diagram.ui.editparts.IGraphicalEditPart as the objectClass. You can then get the EObject that underpins the graphical part using its resolveSemanticElement() method.
Dimitris
Re: [Eugenia] Adding options to a node [message #760154 is a reply to message #759484] Thu, 01 December 2011 08:47 Go to previous message
Thanks!
[Updated on: Thu, 01 December 2011 13:26] by Moderator
Previous Topic:[Eugenia] Containing Relation ? Bug ?
Next Topic:[GMF] Containment Problem
Current Time: Thu Jul 24 23:39:10 EDT 2025
Powered by FUDForum. Page generated in 0.74673 seconds
