Home » Modeling » TMF (Xtext) » Duplicate JvmAnnotationTarget '<unnamed>' when using a AbstractModelInferrer
Duplicate JvmAnnotationTarget '<unnamed>' when using a AbstractModelInferrer [message #759018] Fri, 25 November 2011 10:30 Go to next message
I just started using AbstractModelInferrer (actually
MyDslJvmModelInferrer), with a very basic infer method:
def dispatch void infer(Rule rule, IAcceptor<JvmDeclaredType> acceptor,
boolean isPrelinkingPhase) {
acceptor.accept(
rule.toClass(rule.fullyQualifiedName) [
documentation = rule.documentation
the problem is that when I run the second eclipse instance I get errors
of this shape in the Problem view (and attached to the file, none in the
editor):
I'm trying it with a dsl file with only one Rule element so there's no
other element with that name...
the problems goes away if I comment out from my mwe2 file
composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
any clue please?
thanks in advance
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: Duplicate JvmAnnotationTarget '&lt;unnamed&gt;' when using a AbstractModelInferrer [message #759022 is a reply to message #759018] Fri, 25 November 2011 11:03 Go to previous messageGo to next message
On 11/25/2011 04:30 PM, Lorenzo Bettini wrote:
> Hi
> acceptor.accept(
> editor):
> any clue please?
> thanks in advance
> Lorenzo
By the way, this is reproducible by implementing "The Five Simple Steps
to your JVM Language" and then enabling in the workflow the
Re: Duplicate JvmAnnotationTarget '&lt;unnamed&gt;' when using a AbstractModelInferrer [message #759047 is a reply to message #759022] Fri, 25 November 2011 15:29 Go to previous messageGo to next message
The Problem is that the inferred class and its constructor have the same name - both are annotation targets
=> the check will fail. id try to bind a customized NamesAreUniqueValidationHelper
~Christian
Re: Duplicate JvmAnnotationTarget '&amp;lt;unnamed&amp;gt;' when using a AbstractModelInferr [message #759089 is a reply to message #759047] Sat, 26 November 2011 03:50 Go to previous messageGo to next message
but then why does it say <unnamed>?
you mean then to have a NamesAreUniqueValidationHelper which simply
checks the class of the object to check? For instance this method?
protected void checkDescriptionForDuplicatedName(
IEObjectDescription description,
Map<EClass, Map<QualifiedName, IEObjectDescription>> clusterTypeToName,
ValidationMessageAcceptor acceptor)
cheers
Lorenzo
Re: Duplicate JvmAnnotationTarget '&amp;lt;unnamed&amp;gt;' when using a AbstractModelInferr [message #759091 is a reply to message #759089] Sat, 26 November 2011 04:21 Go to previous messageGo to next message
so I tried overriding getClusterTypes() by inserting only the EClasses
of my DSL package, but the problem with JvmAnnotationTarget shows up
again...
thus, I tried to override this method as follows:
ValidationMessageAcceptor acceptor) {
//super.checkDescriptionForDuplicatedName(description,
clusterTypeToName, acceptor);
EObject object = description.getEObjectOrProxy();
EClass eClass = object.eClass();
if (TypesPackage.Literals.JVM_ANNOTATION_TARGET.equals(eClass))
return;
this makes the Duplicate error go away, but now I miss all the other
checks (for instance two jvm parameters with the same name is not
detected as an error)...
now I'm kind of lost...
cheers
Lorenzo
Re: Duplicate JvmAnnotationTarget '&amp;lt;unnamed&amp;gt;' when using a AbstractModelInferr [message #759093 is a reply to message #759091] Sat, 26 November 2011 04:59 Go to previous messageGo to next message
i actually meant something like
	protected ImmutableSet<EClass> getClusterTypes() {
		return ImmutableSet.of(DomainmodelPackage.Literals.ENTITY, DomainmodelPackage.Literals.OPERATION, DomainmodelPackage.Literals.PROPERTY, TypesPackage.Literals.JVM_GENERIC_TYPE);
~Christian
Re: Duplicate JvmAnnotationTarget '&amp;lt;unnamed&amp;gt;' when using a AbstractModelInferr [message #759094 is a reply to message #759093] Sat, 26 November 2011 05:05 Go to previous messageGo to next message
sorry here the right version: i actually meant something like
		return ImmutableSet.of(DomainmodelPackage.Literals.ENTITY, DomainmodelPackage.Literals.OPERATION, DomainmodelPackage.Literals.PROPERTY);
~Christian
Re: Duplicate JvmAnnotationTarget '&amp;lt;unnamed&amp;gt;' when using a AbstractModelInferr [message #759095 is a reply to message #759094] Sat, 26 November 2011 05:23 Go to previous messageGo to next message
P.S: you have to fix this one too
protected EClass getAssociatedClusterType(EClass eClass) {
		if (clusterTypes.contains(eClass))
			return eClass;
		EList<EClass> superTypes = eClass.getESuperTypes();
		if (superTypes.isEmpty())
			return eClass;
		return getAssociatedClusterType(superTypes.get(0));
[Updated on: Sat, 26 November 2011 05:24] by Moderator
Re: Duplicate JvmAnnotationTarget '&amp;amp;lt;unnamed&amp;amp;gt;' when using a AbstractMod [message #759103 is a reply to message #759095] Sat, 26 November 2011 06:37 Go to previous messageGo to next message
On 11/26/2011 11:24 AM, Christian Dietrich wrote:
> P.S: you have to fix this one too protected EClass
> return eClass;
> return eClass;
however, even if I do this I'll lose name checks for other xbase
elements (see my last post before this one)... I guess Names unique
checks cannot coexist at the moment with model inferrer?
Re: Duplicate JvmAnnotationTarget '&amp;amp;lt;unnamed&amp;amp;gt;' when using a AbstractMod [message #759104 is a reply to message #759103] Sat, 26 November 2011 06:50 Go to previous messageGo to next message
at least with the current implementation
~Christian
Re: Duplicate JvmAnnotationTarget '&amp;amp;amp;lt;unnamed&amp;amp;amp;gt;' when using a Abs [message #759131 is a reply to message #759104] Sat, 26 November 2011 11:23 Go to previous messageGo to next message
OK; do you think it's worth to file a bug?
cheers
Lorenzo
Re: Duplicate JvmAnnotationTarget '&amp;amp;amp;lt;unnamed&amp;amp;amp;gt;' when using a Abs [message #759132 is a reply to message #759131] Sat, 26 November 2011 11:26 Go to previous messageGo to next message
feel free to do so
Re: Duplicate JvmAnnotationTarget '&amp;amp;amp;amp;lt;unnamed&amp;amp;amp;amp;gt;' when usi [message #759200 is a reply to message #759132] Sun, 27 November 2011 10:26 Go to previous message
On 11/26/2011 05:26 PM, Christian Dietrich wrote:
> feel free to do so
done
https://bugs.eclipse.org/bugs/show_bug.cgi?id=364910
cheers
Lorenzo
Previous Topic:Can't get All sub-entities defined in different files(Xtext2.1.1)
Next Topic:[Xtend 2] == != ==
Current Time: Thu Jul 24 22:28:41 EDT 2025
Powered by FUDForum. Page generated in 0.25845 seconds
