Home » Archived » BIRT » reportContext.getLocale()(Get substring )
reportContext.getLocale() [message #759053] Fri, 25 November 2011 15:41 Go to next message
Hi all
I have a report variable that I can grab only the fisrt two charaters to the result of
reportContext.getLocale() function
This is what I'm doing
var locale=reportContext.getLocale().substr(1,2)
That expression gives me this error
"Type error : Can not find function string in object en_CA "
en_CA is the result of reportContext.getLocale() function
I'm using Birt 2.6.2
However if I do something like this
var locale="en.CA".substr(1,2) it works (it returns "en")
What is the difference? the first one is a variable, the second one is just a string
Kind of rookie on this
Thanks in advance for your help
Re: reportContext.getLocale() [message #759055 is a reply to message #759053] Fri, 25 November 2011 15:48 Go to previous messageGo to next message
you should try with reportContext.getLocale().toString()
Re: reportContext.getLocale() [message #759434 is a reply to message #759055] Mon, 28 November 2011 11:23 Go to previous message
dpardon wrote on Fri, 25 November 2011 15:48
Hi dpardon
Thanks a lot for your reply that worked like a charm
Previous Topic:How to display how much resources BiRT is using to generate a report?
Next Topic:Integration with Active Directory?
Current Time: Fri Jul 25 23:52:54 EDT 2025
Powered by FUDForum. Page generated in 0.03237 seconds
