Home » Modeling » TMF (Xtext) » testing with ValidationTestHelper
testing with ValidationTestHelper [message #758810] Thu, 24 November 2011 10:48 Go to next message
I was doing some junit tests in an xtend2 class and I'm using
@Inject
ParseHelper<XtypesTypeSystem> parser
@Inject extension ValidationTestHelper
however, the ValidationTestHelper does not seem to find all the errors
in the source file, in particular it does not run
org.eclipse.xtext.validation.NamesAreUniqueValidator (which I enabled,
and works in the new runtime eclipse instance)
is it the expected behavior?
thanks in advance
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: testing with ValidationTestHelper [message #758829 is a reply to message #758810] Thu, 24 November 2011 11:24 Go to previous messageGo to next message
i cannot reproduce this
@ComposedChecks(validators = { NamesAreUniqueValidator.class })
public class MyDslJavaValidator extends AbstractMyDslJavaValidator {
@RunWith(XtextRunner.class)
@InjectWith(MyDslInjectorProvider.class)
public class Test extends AbstractXtextTests {
	@Inject
	MyDslJavaValidator validator;
	@Inject
	Injector injector;
	@Inject
	ParseHelper<Model> parser;
	@org.junit.Test
	public void TestIt() throws Exception {
		ValidatorTester<MyDslJavaValidator> tester = new ValidatorTester<MyDslJavaValidator>(validator, injector);
		System.out.println(tester.validate(parser.parse("Hello You! Hello You!")));
~Christian
Re: testing with ValidationTestHelper [message #758853 is a reply to message #758829] Thu, 24 November 2011 13:07 Go to previous messageGo to next message
Christian, normally the @ComposedChecks annotation is on the AbstractMyDslJavaValidator and that makes a difference. If you want to be sure to catch all errors and warnings in precisely the same manner as in the actual plug-in, use org.eclipse.emf.ecore.util.Diagnostician which makes use of the EMF Validator framework while the ValidatorTester doesn't necessarily.
Re: testing with ValidationTestHelper [message #758938 is a reply to message #758829] Fri, 25 November 2011 06:00 Go to previous message
Thanks! Then I need to use ValidatorTester (which I've already used in
the past); I thought I could do the same with ValidationTestHelper :)
On 11/24/2011 05:24 PM, Christian Dietrich wrote:
> @Inject
> @Inject
> Injector injector;
> @Inject
> @org.junit.Test
> ~Christian
Previous Topic:Xtend function definition syntax
Next Topic:[Xtext 2.1] Implementing a custom post build step
Current Time: Thu Jul 24 23:30:17 EDT 2025
Powered by FUDForum. Page generated in 0.06872 seconds
