how to get the saved gmf diagram in Project Explorer [message #758904] |
Fri, 25 November 2011 02:46  |
Hi All,
I am creating a gmf diagram once I save it, how can I view the saved gmf diagram in my Project Explorer, So that I should be able to open it by double clicking on the gmf diagram file in project explorer.Please let me know if anyone has worked on this.
Vinay
Re: how to get the saved gmf diagram in Project Explorer [message #759114 is a reply to message #758985] |
Sat, 26 November 2011 09:06  |
Hi Viney,
I was thinking about this question and the other that you posted, I thought that your problem might be you stop the host Eclipse using the Stop button, then the running Eclipse workspace will not have the chance to save the diagram and all other project files you created.
Try to do the following way: After you created your diagram, save it and quit the running Eclipse workspace using the menu Quit. The next time you run your Eclipse, the workspace with projects and diagrams will be there.
I hope this helps.
Hoang
FUDForum. Page generated in 0.14860 seconds
