How to display how much resources BiRT is using to generate a report? [message #757788] |
Mon, 21 November 2011 12:08  |
Hello All,
I'm hoping someone has seen this before.
I am currently writing reports that use very large >10MB flatfiles as their source file.
Depending on the amount of data used, specifically too much, and BiRT will either crash with a java heap error (my xmxx settings are already close to system capacity in eclipse.ini) or the reports will not finish, HTML just hangs at a certain point.
I used to have an icon in BiRT that would display the amount of memory used by the report, but I am unable to find it.
Is there any other way to find out what resources are consumed by BiRT from inside Eclipse? I am trying to use something more accurate than the OS tools.
I have found a work around solution by throwing bigger,faster hardware at the reports, but that isn't a solution a can always use.
Any suggestions would be great.
H
Re: How to display how much resources BiRT is using to generate a report? [message #758101 is a reply to message #757788] |
Mon, 21 November 2011 16:28   |
Download this zip file:
http://www.birt-exchange.org/org/devshare/deploying-birt-reports/1344-eclipsecon-2011-api-examples/
extract the birt metal ppt and look at slide 21 which contains memory
configuration options for the data engine. You can set them in script like:
importPackage(Packages.org.eclipse.birt.data.engine.api);
importPackage(Packages.java.lang);
//lower memory used before disk writing from 10mb to 2mb per query
reportContext.getAppContext().put( DataEngine.MEMORY_BUFFER_SIZE, new
Integer(2) );
Jason
On 11/21/2011 12:08 PM, henry.golas wrote:
> Hello All,
> their source file.
> OS tools.
> H
Re: How to display how much resources BiRT is using to generate a report? [message #758102 is a reply to message #758101] |
BTW put the script in the beforeFactory.
> Integer(2) );
> Jason
>> Hello All,
>> their source file.
>> OS tools.
>> Thanks,
>> H
FUDForum. Page generated in 0.06836 seconds
