Home » Archived » BIRT » IncompatibleClassChangeError when running in JBOSS
IncompatibleClassChangeError when running in JBOSS [message #758143] Tue, 22 November 2011 00:17 Go to next message
I am getting a IncompatibleClassChangeError when I try to render a report after porting the content over from WebLogic 10 to JBOSS 4.22
I am aware that the topic is similar in title to another one http://www.eclipse.org/forums/index.php/m/657930/?srch=Expecting+non-static+method+org.eclipse.birt.report.model.metadata.MetaDataDictionary#msg_657930 but it's a little different as I didn't upgrade the engine. It's still using version 2.5.2
A few things to point out:
1. Since JBOSS doesn't take directories as servlet like Weblogic do, I had to build a war file containing code, libraries and plugins. The resource directories have been separated out into another folder outside. (for easy report file management, replacement etc..)
2. For JBOSS, I have substituted the argument used for the openDesign method in WebReport.java. Originally, for WebLogic, I am able to use sc.getRealPath with ease, instead now I would use like:
birtReportEngine.openReportDesign(birtReportEngine.getResourcePath()+File.separator+reportName)
One of the solutions that was mentioned previously was to set the BIRT_HOME variable. Unfortunately this doesn't work. And right now, I am little stuck.
Any ideas? Thanks.
Melvin
Re: IncompatibleClassChangeError when running in JBOSS [message #758315 is a reply to message #758143] Tue, 22 November 2011 12:13 Go to previous messageGo to next message
Melvin
Are both machines using the same jvm version? BTW I think JBoss can use
a directory structure if you name the directory with a .war for example
BirtViewer.war.
Jason
On 11/22/2011 12:17 AM, Melvin Mah wrote:
> using version 2.5.2
> little stuck.
> Any ideas? Thanks.
> Melvin
Re: IncompatibleClassChangeError when running in JBOSS [message #758399 is a reply to message #758315] Wed, 23 November 2011 01:38 Go to previous messageGo to next message
Hi Jason,
Thanks very much for the reply:
1. I might try out your suggestion to rename the directory and deploy it. But we all know that the .war files are usually deployed in the "deploy" sub directory. It's still not as flexible as in Weblogic where you can browse to any directory where a war file / servlet directory is placed and selecting before deploying.
2. The problem I encountered after experimentation was actually due to the mismatch version of the plugin directories / jars (those in plugin folders, not libs). I built the war file with an older version (version 2.50, June 2009 release) whereas I have forgotten that the runtime engine in Weblogic was upgraded to 2.5.2 late last year. At first I thought there was an error in the argument that I passed for openReportDesign method.
Melvin
Re: IncompatibleClassChangeError when running in JBOSS [message #758532 is a reply to message #758399] Wed, 23 November 2011 10:26 Go to previous messageGo to next message
Melvin,
So it is working now?
Jason
Re: IncompatibleClassChangeError when running in JBOSS [message #758534 is a reply to message #758532] Wed, 23 November 2011 10:29 Go to previous message
Jason,
Yes. It's working now.
I might want to test out the 3.7 runtime later.
Melvin
Previous Topic:BIRT header and footer
Next Topic:How to display how much resources BiRT is using to generate a report?
Current Time: Wed Jul 23 11:37:57 EDT 2025
Powered by FUDForum. Page generated in 0.25243 seconds
