Home » Eclipse Projects » Target Management » programmatically use RSE(How to open a remote file from within an RCP application?)
programmatically use RSE [message #756714] Mon, 14 November 2011 14:04 Go to next message
I'm not quite sure if I'm submitting this question in the right forum, but what I would like to do and don't know how is the following:
From within the RCP application I am develloping I want to access a remote file and use the default system editor to open it. The code may look like this:
IFileStore fileStore = EFS.getFileSystem(scheme).getStore(fileNameURI);
IEditorInput editorInput = new FileStoreEditorInput(fileStore);
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage().openEditor(editorInput, IEditorRegistry.SYSTEM_EXTERNAL_EDITOR_ID);
The scheme is either 'file' if the file is local (which works), or it is ftp if the file is remote, which does not work because there is no scheme defined for ftp.
I would need to implement a filesystem extension for the ftp scheme, but I guess there is already some implementation in the RSE/TM for that. Is it possible to use it like this?
Thanx!
Julia
[Updated on: Mon, 14 November 2011 14:05] by Moderator
Re: programmatically use RSE [message #757773 is a reply to message #756714] Mon, 21 November 2011 10:32 Go to previous messageGo to next message
I have pretty much the same problem. I want to add EFS implementations for schemes other than the Eclipse-built-in scheme for the local filesystem 'file' (e.g. 'ftp' or 'ssh') to my RCP application in order to reuse code I already wrote to access the local filesystem. Information to that topic is quite sparse or at least I wasn't able to find it. This link is referenced quite often:
wiki.eclipse.org/EFS
But the EFS implementation for FTP and SSH (2. item under 'known implementations') seems not to be accessible. Maybe the link is outdated?
So I have two questions:
1. Are the EFS implementations of RSE intended to be used that way?
2. What is the general mechanism to hook up additional EFS implementations to RCP applications?
Thanks in advance,
Mat41
Re: programmatically use RSE [message #758026 is a reply to message #756714] Wed, 16 November 2011 09:55 Go to previous messageGo to next message
Hi Julia,
The "rse" scheme serves files in a protocol-agnostic way. If you want to
use RSE as the FTP EFS provider, one thing you could do is create an FTP
Only connection in RSE and then write some code like the following:
URI fileNameURI = new URI("rse", host, path, null);
IEditorDescriptor descriptor = IDE.getEditorDescriptor(name);
descriptor.getId());
Dave
"julia.kurde" <forums-noreply@eclipse.org> wrote in message
news:j9rnvo$s5n$1@news.eclipse.org...
> this:
> defined for ftp.
> Thanx!
> Julia
Re: programmatically use RSE [message #758063 is a reply to message #758026] Mon, 21 November 2011 15:28 Go to previous messageGo to next message
Hi Dave,
When trying
'URI fileNameURI = new URI(scheme, host, path, null)'
with
scheme: rse
host: 172.31.10.10
path: /EDS/bref_gebaeude.jpg
Unfortunatelly I'm getting
org.eclipse.ui.PartInitException: System editor can only open file base resources.
What can be the problem?
Thanx,
Julia
Re: programmatically use RSE [message #758260 is a reply to message #758063] Tue, 22 November 2011 08:29 Go to previous messageGo to next message
Hi Dave,
I had a closer look to it and it seems the problem is that
FileStoreEditorInput does not implement org.eclipse.ui.IPathEditorInput
as it is required for an external editor (see the javadoc of IEditorRegistry.SYSTEM_EXTERNAL_EDITOR_ID).
On the other hand for the local file system there is no problem. In the class IURIEditorInputAdapterFactory an Adapter is created: PathEditorInputAdapter.
But if the file system is different from EFS.getLocalFileSystem(), no adapter is created and the editor will not open.
How can I deal with this?
Thanx again!
Julia
[Updated on: Tue, 22 November 2011 09:21] by Moderator
Re: programmatically use RSE [message #758295 is a reply to message #758260] Tue, 22 November 2011 10:31 Go to previous messageGo to next message
Hi Julia,
I'm not sure whether this helps your scenario but one alternative to using
EFS is to use RSE directly like this:
ISystemRegistry sr = RSECorePlugin.getTheSystemRegistry();
IHost rseHost = sr.getHost(sr.getActiveSystemProfiles()[0], host);
IRemoteFileSubSystem ss = RemoteFileUtility.getFileSubSystem(rseHost);
IRemoteFile remoteFile = ss.getRemoteFileObject(path, monitor);
IFile file =
(IFile)UniversalFileTransferUtility.downloadResourceToWorkspace(remoteFile,
monitor);
IEditorInput editorInput = new FileEditorInput(file);
"jule" <forums-noreply@eclipse.org> wrote in message
news:jag83k$v4v$1@news.eclipse.org...
> Hi Dave,
> FileStoreEditorInput does not implement org.eclipse.ui.IPathEditorInput as
> There are some implementations of IPathEditorInput, e.g.
> org.eclipse.ui.part.FileEditorInput. But this one needs an IFile Object,
> which I dont't know how to get from the IFileStore object.
> Another one is
> org.eclipse.ui.internal.ide.IURIEditorInputAdapterFactory.PathEditorInputAdapter,
> which wants an IFileStore object, but is internal.
> Thanx again!
> Julia
Re: programmatically use RSE [message #758472 is a reply to message #758295] Wed, 23 November 2011 07:01 Go to previous messageGo to next message
Hi Dave,
The method
returns an array of length zero in my case.
Seems I don't have any active system profile. How can I get one? (What is that actually?)
Julia
Re: programmatically use RSE [message #758512 is a reply to message #758472] Wed, 23 November 2011 09:13 Go to previous messageGo to next message
Hi Julia,
It may be that there are no profiles at the time you make this call because
RSE has not get completed it's initialization. To ensure the initialization
is complete, make this call first:
RSECorePlugin.waitForInitCompletion()
Hope that helps,
Dave
news:jainbm$ue9$1@news.eclipse.org...
> Hi Dave,
> The method
> returns an array of length zero in my case. Seems I don't have any active
> Julia
Re: programmatically use RSE [message #758569 is a reply to message #758512] Wed, 23 November 2011 12:46 Go to previous messageGo to next message
OK... we are one step further!
Now, I'm getting my profile, which looks like this:
SystemProfile:
	_isDirty	true
	_isTainted	true
	_propertySets	LinkedHashMap<K,V> /* empty */
	_wasRestored	false
	defaultPrivate	true
	isActive	true
	mgr		SystemProfileManager
	name		"juliasrechner"
	provider	null
	suspended	false
But then I don't get the rseHost. The method
sr.getHost(profiles[0], host);
returns null. The host is a valid IP address, profiles are the ones I got from
sr.getActiveSystemProfiles().
I don't have the source of the SystemRegistry class so I can't follow this problem in more detail, sorry! Maybe it is related to the provider of the profile, which is null.
Thanx for your patience!
Julia
Re: programmatically use RSE [message #758587 is a reply to message #758569] Wed, 23 November 2011 14:26 Go to previous messageGo to next message
Hmm, maybe I need to step back for a moment. I was assuming that you had
already defined an RSE IHost but that might not be the case. If not, you'll
need to do that (either via the Remote Systems view or programmatically)
first. If you already have a connection defined, then I suppose you could
use this alternative to get at all the hosts and then find the one that's
applicable to you:
IHost[] hosts = sr.getHosts();
news:jajbi0$8pp$1@news.eclipse.org...
> SystemProfile:
> _isDirty true _isTainted true _propertySets LinkedHashMap<K,V> /* empty */
> _wasRestored false defaultPrivate true isActive true mgr
> provider null suspended false
> from
> Julia
Re: programmatically use RSE [message #758597 is a reply to message #758587] Wed, 23 November 2011 15:08 Go to previous messageGo to next message
You're right, I did not define any RSE IHost yet (sr.getHosts() returns an empty array). I have to do it programmatically, because the RCP application I'm working on runs independently from the Remote Systems view.
Maybe I shortly explain the scenario how I want to use the RSE.
The user has this RCP application on his computer. There he opens a DB table which is displayed in an eclipse editor. The table contains file names. Via a context menu the user can select an action that opens the file in an external editor. The URL where to look for the file is set in the user preferences, which I'm reading in the run() method of that action.
So, I guess in this run() method I have to check whether there is already an IHost defined, and if not, define one.
Or, maybe we have to go back to the solution with an adapter for an IPathEditorInput for FileStoreEditorInput?
I'm a little bit lost in the moment, sorry!
Julia
Re: programmatically use RSE [message #758606 is a reply to message #758597] Wed, 23 November 2011 15:38 Go to previous messageGo to next message
You could try something like this to create your host:
ISystemRegistry systemRegistry = RSECorePlugin.getTheSystemRegistry();
ISystemProfile profile =
systemRegistry.getSystemProfileManager().getDefaultPrivateSystemProfile();
String profileName = profile.getName();
String hostAlias = "myhost";
String hostname = "myhost";
String userId = "myid";
IRSESystemType systemType =
RSECorePlugin.getTheCoreRegistry().getSystemTypeById("org.eclipse.rse.systemtype.ftp");
IHost host = systemRegistry.createHost(profileName, systemType, hostAlias,
hostname, null, userId, IRSEUserIdConstants.USERID_LOCATION_HOST, null);
news:jajjru$p68$1@news.eclipse.org...
> view.
> action.
> Julia
Re: programmatically use RSE [message #758725 is a reply to message #758606] Thu, 24 November 2011 07:07 Go to previous messageGo to next message
Again one more step further... the IHost is created!
But still something is missing unfortunatelly.
And that something is the configuration of the file subsystem for ftp:
IRSESystemType systemType = RSECorePlugin.getTheCoreRegistry().getSystemTypeById("org.eclipse.rse.systemtype.ftp");
IRemoteFileSubSystemConfiguration fssConfig = RemoteFileUtility.getFileSubSystemConfiguration(systemType);
fssConfig is null.
Asking for
also returns null.
For a cross check I tried to configure a connection to this host via the Remote Systems view. When trying to see the files I get the error message
Message reported from file system: 530 This FTP server is anonymous only.
So I can establish the connection but somehow I cannot access any files.
Is there anything special about anonymous servers?
Thanx again!
Julia
Re: programmatically use RSE [message #758812 is a reply to message #758725] Thu, 24 November 2011 10:51 Go to previous messageGo to next message
Hi Julia,
I'm not sure why you'd get null there although I haven't tried this with
FTP. It's possible that you're missing a dependency for that. Could you
instead try with SSH?
When you create an SSH only connection from the Remote Systems view, are you
able to navigate the file system?
Instead of using the hardcoded ftp system type id, try using this:
IRSESystemType.SYSTEMTYPE_SSH_ONLY_ID
Dave
news:jalc1j$6j6$1@news.eclipse.org...
> fssConfig is null.
> Asking for RemoteFileUtility.getFileSubSystem(rseHost);
> also returns null.
> Thanx again!
> Julia
Re: programmatically use RSE [message #758842 is a reply to message #758812] Thu, 24 November 2011 12:08 Go to previous messageGo to next message
Hi Dave,
In the Remote System view I can create an SSH-only connection and browse the files, no problem! But trying this programmatically, I get again null for both, the configuration
IRSESystemType systemType = RSECorePlugin.getTheCoreRegistry().getSystemTypeById(IRSESystemType.SYSTEMTYPE_SSH_ONLY_ID);
as well as the file subsystem
In the RCP Application I have to add every required plugin manually. So far I have
   <requires>
      <import plugin="org.eclipse.ui"/>
      <import plugin="org.eclipse.core.filesystem"/>
      <import plugin="org.eclipse.core.runtime"/>
      <import plugin="org.eclipse.ui.ide"/>
      <import plugin="org.eclipse.core.resources" version="3.7.100"/>
      <import plugin="org.eclipse.rse.core" version="3.2.1"/>
      <import plugin="org.eclipse.rse.subsystems.files.core" version="3.2.101"/>
      <import plugin="org.eclipse.rse.services" version="3.2.101"/>
      <import plugin="org.eclipse.rse.files.ui" version="3.2.1"/>
   </requires>
Maybe that's not enough...
Julia
Re: programmatically use RSE [message #758865 is a reply to message #758842] Thu, 24 November 2011 15:06 Go to previous messageGo to next message
Julia,
In your case do you still have the waitForInitCompletion() call? Perhaps
that's what's preventing things from working. The following code did work
for me after RSE is loaded (after waitForInitCompletion()).
IHost newHost = systemRegistry.createHost(profileName, systemType,
hostAlias, hostname, null, userId, IRSEUserIdConstants.USERID_LOCATION_HOST,
null);
IRemoteFileSubSystem ss = RemoteFileUtility.getFileSubSystem(newHost);
IFile file =
monitor);
Dave
news:jaltm7$bdo$1@news.eclipse.org...
> Hi Dave,
> far I have
> <requires>
> version="3.2.101"/>
> </requires>
> Julia
Re: programmatically use RSE [message #758934 is a reply to message #758865] Fri, 25 November 2011 05:46 Go to previous messageGo to next message
Hi Dave,
I'm doing exactly this, and I'm running into a NullPointerException in createHost.
Maybe the stack trace is helpful.
	at org.eclipse.rse.internal.persistence.dom.RSEDOMExporter.createNode(RSEDOMExporter.java:332)
	at org.eclipse.rse.internal.persistence.dom.RSEDOMExporter.populateRSEDOM(RSEDOMExporter.java:142)
	at org.eclipse.rse.internal.persistence.dom.RSEDOMExporter.createRSEDOM(RSEDOMExporter.java:92)
	at org.eclipse.rse.internal.persistence.RSEPersistenceManager.save(RSEPersistenceManager.java:555)
	at org.eclipse.rse.internal.persistence.RSEPersistenceManager.commitProfile(RSEPersistenceManager.java:257)
	at org.eclipse.rse.internal.core.model.SystemProfileManager.commitSystemProfile(SystemProfileManager.java:117)
	at org.eclipse.rse.internal.core.model.SystemProfile.commit(SystemProfile.java:272)
	at org.eclipse.rse.internal.core.model.SystemProfileManager.commitProfiles(SystemProfileManager.java:108)
	at org.eclipse.rse.internal.core.model.SystemProfileManager.runOperation(SystemProfileManager.java:99)
	at org.eclipse.rse.internal.core.model.SystemProfileManager.run(SystemProfileManager.java:86)
	at org.eclipse.rse.internal.core.model.SystemRegistry.createHost(SystemRegistry.java:1629)
	at org.eclipse.rse.internal.core.model.SystemRegistry.createHost(SystemRegistry.java:1529)
	at eub.lzhview.actions.OpenDocumentAction.internalRun(OpenDocumentAction.java:232)
	at eub.lzhview.actions.OpenDocumentAction.access$0(OpenDocumentAction.java:96)
	at eub.lzhview.actions.OpenDocumentAction$1.runInUIThread(OpenDocumentAction.java:89)
	at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:95)
	at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
	at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
	at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
	at eub.rcplzhview.Application.start(Application.java:22)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
!SESSION 2011-11-25 11:32:47.347 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_29
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments:  -product eub.rcplzhview.JLZHView
Command-line arguments:  -product eub.rcplzhview.JLZHView -data C:\JAVA\Workspace_jLZHview/../runtime-eub.rcplzhview.JLZHView -dev file:C:/JAVA/Workspace_jLZHview/.metadata/.plugins/org.eclipse.pde.core/eub.rcplzhview.JLZHView/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.ui 4 4 2011-11-25 11:33:08.378
!MESSAGE An internal error has occurred.
Unfortunatelly I can not look into the internal rse classes. The host still will be created though. The second time, because I check whether rseHost == null, createHost() is not called again, but the file system can not be loaded.
returns null.
With the same parameters as I call createHost() in the code, I can create a connection in the Remote Systems view without any problem (SSH only, FTP does not work there either because of anonymous server).
My workaround for windows in the moment is to execute a command that uses the windows explorer:
String cmd = "explorer " + fileURL.toExternalForm();
Process process = Runtime.getRuntime().exec(cmd);
Very simple... But our application is supposed to run on Linux, too. So I need something platform independent. The RSE seemed a solution to me...
Do you think it's possible??
Julia
Re: programmatically use RSE [message #759004 is a reply to message #758934] Fri, 25 November 2011 09:47 Go to previous messageGo to next message
Julia, have you had a chance to debug this? For the stack it would appear
that either the host or it's system type are null. Can you check that?
news:janrmb$302$1@news.eclipse.org...
> Hi Dave,
> createHost.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> !SESSION 2011-11-25
> not be loaded. RemoteFileUtility.getFileSubSystem(rseHost);
> returns null.
> need something platform independent. The RSE seemed a solution to me... Do
> Julia
Re: programmatically use RSE [message #759031 is a reply to message #759004] Fri, 25 November 2011 12:18 Go to previous messageGo to next message
Your right! I don't get any system type.
RSECorePlugin.getTheCoreRegistry().getSystemTypeById(id);
returns null for
id = IRSESystemType.SYSTEMTYPE_FTP_ONLY_ID as well as for
id = IRSESystemType.SYSTEMTYPE_SSH_ONLY_ID.
I just checked this also on another pc and it is the same.
The system types I get from
RSECorePlugin.getTheCoreRegistry().getSystemTypes();
are
Windows (org.eclipse.rse.systemtype.windows)
Linux (org.eclipse.rse.systemtype.linux)
Unix (org.eclipse.rse.systemtype.unix)
Local (org.eclipse.rse.systemtype.local)
Seems indeed some dependencies are missing.
[Updated on: Fri, 25 November 2011 12:36] by Moderator
Re: programmatically use RSE [message #759033 is a reply to message #759031] Fri, 25 November 2011 12:44 Go to previous messageGo to next message
Hey Jule, I just looked again at your plugin dependencies and noticed that
org.eclipse.rse.ui isn't there. You will want to include that.
news:jaoikg$i2t$1@news.eclipse.org...
> returns null for id = IRSESystemType.SYSTEMTYPE_FTP_ONLY_ID as well as for
Re: programmatically use RSE [message #759036 is a reply to message #759033] Fri, 25 November 2011 13:21 Go to previous messageGo to next message
The 4 system types I have are defined in org.eclipse.rse.core as extension to the point org.eclipse.rse.core.systemTypes.
org.eclipse.rse.ui does not provide any extensions to this point. I would need the plugin(s) where the extensions for all the other system types are defined. In the interface IRSESystemType there are
SYSTEMTYPE_AIX_ID : String
SYSTEMTYPE_DISCOVERY_ID : String
SYSTEMTYPE_FTP_ONLY_ID : String
SYSTEMTYPE_ISERIES_ID : String
SYSTEMTYPE_LINUX_ID : String
SYSTEMTYPE_LOCAL_ID : String
SYSTEMTYPE_PASE_ID : String
SYSTEMTYPE_POWER_LINUX_ID : String
SYSTEMTYPE_SSH_ONLY_ID : String
SYSTEMTYPE_TELNET_ONLY_ID : String
SYSTEMTYPE_UNIX_ID : String
SYSTEMTYPE_WINDOWS_ID : String
SYSTEMTYPE_ZSERIES_ID : String
SYSTEMTYPE_ZSERIES_LINUX_ID : String
I just wounder where I can find them!
Re: programmatically use RSE [message #759037 is a reply to message #759036] Fri, 25 November 2011 13:36 Go to previous messageGo to next message
The reason I think you need org.eclipse.rse.core is that's where the
Subsystem base class is defined. I doubt the issue is with the system type
ids.
news:jaomau$p8i$1@news.eclipse.org...
Re: programmatically use RSE [message #759039 is a reply to message #759037] Fri, 25 November 2011 13:48 Go to previous messageGo to next message
err.... I mean org.eclipse.rse.ui.
"David McKnight" <dmcknigh@ca.ibm.com> wrote in message
news:jaon6l$qtg$1@news.eclipse.org...
> type ids.
Re: programmatically use RSE [message #759044 is a reply to message #759039] Fri, 25 November 2011 14:25 Go to previous messageGo to next message
But when these extension points are not defined, I will always get null from
except for the four I mentioned. Then the I will create an IHost with a null systemType.
By the way, I found the extension for the SSH Only (org.eclipse.rse.systemtype.ssh) system type in org.eclipse.rse.connectorservice.ssh. Just to check I included this plugin to my dependencies and I got the respective system type from the core registry. I was already quite happy (although I actually need ftp), but even then the two methods
RemoteFileUtility.getFileSubSystemConfiguration(systemType) and
still return null.
By the way no matter if I include org.eclipse.rse.ui or not.
I don't know what's wrong here!
Re: programmatically use RSE [message #759064 is a reply to message #759044] Fri, 25 November 2011 16:25 Go to previous messageGo to next message
If you call the following:
ISubSystem[] sses = host.getSubSystems();
What do you get as sses?
news:jaoq47$tv$1@news.eclipse.org...
> from
> null systemType.
> still return null. By the way no matter if I include org.eclipse.rse.ui or
> not.
Re: programmatically use RSE [message #759121 is a reply to message #759064] Sat, 26 November 2011 09:57 Go to previous messageGo to next message
rseHost.getSubSystems();
RemoteFileUtility.getFileSubSystems(rseHost);
both return an empty array. The rseHost looks like this:
rseHost	Host  (id=4401)
	_isDirty	false
	_isTainted	false
	_profile	SystemProfile  (id=4400)
	_propertySets	LinkedHashMap<K,V>  (id=4408)
	_wasRestored	true
	aliasName	"172.31.10.10" (id=4407)
	defaultUserId	null
	description	null
	hostName	"172.31.10.10" (id=4409)
	offline	false
	pool	SystemHostPool  (id=4410)
	previousUserIdKey	"juliasrechner.172.31.10.10" (id=4411)
	promptable	false
	systemType	RSESystemType  (id=4397)
	ucId	false
	userIdCaseSensitive	false
The defaultUserId is null although I create the rseHost with a non-null string for the defaultUserId. I don't know why this is not kept. The systemType is SSH only.
Re: programmatically use RSE [message #759690 is a reply to message #759121] Tue, 29 November 2011 11:10 Go to previous messageGo to next message
Hi Julia,
I'm not sure what's going on here in your scenario. Some things to
consisder are:
1) Try the scenario with a clean workspace.
2) For FTP, makes sure you have the following dependency:
org.apache.commons.net
3) After creating a connection, you may want to add credentials like this:
SystemSignonInformation info = new SystemSignonInformation(address, userId,
password, systemType);
PasswordPersistenceManager.getInstance().add(info, true, false);
4) Make sure your plugin(s) and launch configurations don't have any errors
before launching.
Dave
news:jaquok$v2u$1@news.eclipse.org...
> rseHost.getSubSystems(); RemoteFileUtility.getFileSubSystems(rseHost);
> rseHost Host (id=4401) _isDirty false _isTainted false _profile
> SystemProfile (id=4400) _propertySets LinkedHashMap<K,V> (id=4408)
> _wasRestored true aliasName "172.31.10.10" (id=4407) defaultUserId null
> description null hostName "172.31.10.10" (id=4409) offline false pool
> SystemHostPool (id=4410) previousUserIdKey "juliasrechner.172.31.10.10"
> (id=4411) promptable false systemType RSESystemType (id=4397) ucId false
Re: programmatically use RSE [message #760545 is a reply to message #759690] Fri, 02 December 2011 14:04 Go to previous messageGo to next message
Hi Dave,
I could achieve
(a) to get the FTP only system type by including org.eclipse.rse.subsystems.files.ftp in my dependencies and
(b) to get the respective file sub system by including org.eclipse.rse.connectorservice.dstore.
So in my application the Enter Password dialog pops up with the Host name and User ID as specified in the code. So far everything is fine.
But the ftp server I want to connect is anonymous, so no matter what user ID and Password I enter in this dialog, the Console view opens with the same message as I also get when connecting via the Remote Systems view:
220 "LZH-Schemata-FTP-Server."
USER lzh
QUIT
221 Goodbye.
and I run into an org.eclipse.rse.services.files.RemoteFileSecurityException: Operation failed. Security violation
Is it possible to connect to an anonymous server with the RSE?
Re: programmatically use RSE [message #760822 is a reply to message #760545] Mon, 05 December 2011 06:40 Go to previous messageGo to next message
The thing is solved!!
I'm pasting here the complete code. Maybe it is helpful for somebody...
				URL fileURL = new URL(EDSPathURL , fileNames[i]); /* create URL from path set in user preferences */
				URI fileNameURI = fileURL.toURI(); /* convert to URI */
				String scheme = fileNameURI.getScheme();
				String host = fileURL.getHost();
				String path = fileURL.getPath();
				IEditorInput editorInput;
				if (scheme.equalsIgnoreCase("file")) { /* open local file */
				} else if (scheme.equalsIgnoreCase("ftp")) { /* open file via ftp */
					RSECorePlugin.waitForInitCompletion();
					ISystemProfile profile = systemRegistry.getSystemProfileManager().getDefaultPrivateSystemProfile();
					IHost rseHost = systemRegistry.getHost(profile, host);
					if (rseHost == null) {
						System.out.println("Create IHost... ");
			 			IRSESystemType systemType = RSECorePlugin.getTheCoreRegistry().getSystemTypeById(IRSESystemType.SYSTEMTYPE_FTP_ONLY_ID);
						int defaultUserIdLocation = IRSEUserIdConstants.USERID_LOCATION_HOST;
						rseHost = systemRegistry.createHost(
								profileName,           /* Name of the system profile the connection is to be added to */
								systemType,            /* system type matching one of the system types defined via the systemTypes extension point */
								host,                  /* unique connection name */
								host,                  /* ip name of host */
								null,                  /* optional description of the connection. Can be null */
								null,                  /* userId to use as the default for the subsystems */
								defaultUserIdLocation, /* one of the constants in IRSEUserIdConstants that tells us where to store the user Id */
								null                   /* these are the configurators supplied by the subsystem configurations that pertain to the specified system type. Else null */
					rseHost.setDefaultUserId("ftp");
					rseHost.getConnectorServices()[0].setPassword("ftp", "", true, true); /* userID must be either 'ftp' or 'anonymous' for an anonymous connection. Otherwise comment this line out and a dialog will pop up for the user to enter a passwort */
					rseHost.getConnectorServices()[0].connect(monitor);
					IFile file = (IFile) UniversalFileTransferUtility.downloadResourceToWorkspace(remoteFile, monitor);
					rseHost.getConnectorServices()[0].disconnect(monitor);
				} else { /* scheme is neither local nor FTP only... do something else... */
				String id = IDE.getEditorDescriptor(fileNames[i]).getId();
				PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage().openEditor(editorInput, id);
When executing this code the server replies the following
USER anonymous
331 Please specify the password.
PASS ******
230 Login successful.
SYST
215 UNIX Type: L8
TYPE I
200 Switching to Binary mode.
PWD
257 "/"
NOOP
200 NOOP ok.
CWD /EDS
250 Directory successfully changed.
PORT 172,31,10,216,10,240
200 PORT command successful. Consider using PASV.
LIST -a
150 Here comes the directory listing.
226 Directory send OK.
QUIT
221 Goodbye.
By the way this works for passive as well for an active connection.
Finally, the required plugins in the dependencies are:
      <import plugin="org.eclipse.rse.subsystems.files.ftp" version="2.1.301"/>
      <import plugin="org.eclipse.rse.ui" version="3.2.1"/>
      <import plugin="org.eclipse.rse.connectorservice.dstore" version="3.1.200"/>
Thanks, Dave, for discussions!
Regards, Julia
Re: programmatically use RSE [message #761063 is a reply to message #760822] Mon, 05 December 2011 15:48 Go to previous message
Hi Julie,
Sorry I missed your last message. I'm glad you got everything working!
Dave
news:jbiain$q69$1@news.eclipse.org...
> be added to */
> null */
> */ defaultUserIdLocation, /* one of the constants in IRSEUserIdConstants
> null */
> enter a passwort */
> monitor);
> id);
> USER anonymous
> PASS ******
> SYST
> 215 UNIX Type: L8
> TYPE I
> PWD
> 257 "/"
> NOOP
> 200 NOOP ok.
> CWD /EDS
> LIST -a
> QUIT
> 221 Goodbye.
> version="3.2.101"/>
> version="2.1.301"/>
> version="3.1.200"/>
> Regards, Julia
Previous Topic:RSE SubSystem - Copy/Paste support
Next Topic:ftp set defualt to passive
Current Time: Wed Jul 23 14:04:08 EDT 2025
Powered by FUDForum. Page generated in 0.09576 seconds
