Home » Language IDEs » Java Development Tools (JDT) » ASTVisitor - geting line number of MethodDeclaration
ASTVisitor - geting line number of MethodDeclaration [message #758386] Tue, 22 November 2011 19:42 Go to next message
I am implementing a parser with ASTVisitor and I want to store the initial and last line number (or offset from the initial line) of a method declaration.
i get the initial position:
final int startPosition = methodDeclaration.getStartPosition();
Then i get the offset:
final int offSet = methodDeclaration.getLength();
Then I try to retrieve this snippet by reading it directly from the source code:
final Reader in = new FileReader( "/workspace/Teste/src/Main.java" );
final BufferedReader reader = new BufferedReader( in );
reader.skip( startPosition );
final char[] buf = new char[3000];
reader.read( buf, 0, offSet );
The problem seems to be with my offset. Does anybody knows what am I doing wrong?
[Updated on: Tue, 22 November 2011 19:43] by Moderator
Re: ASTVisitor - geting line number of MethodDeclaration [message #758401 is a reply to message #758386] Wed, 23 November 2011 01:53 Go to previous messageGo to next message
What is the problem you are running into?
Re: ASTVisitor - geting line number of MethodDeclaration [message #758446 is a reply to message #758386] Wed, 23 November 2011 05:28 Go to previous messageGo to next message
> method declaration.
> the initial line I get like this:
> final int lineNumber = compilationUnit.getLineNumber( startPosition );
> source code:
> reader.skip( lineNumber );
Don't think you can skip lines via the skip() method.
> doing wrong?
You could use something like..
IBuffer buffer= compilationUnit.getBuffer();
String source= buffer.getText(method.getStartPosition(),
method.getLength());
(compilationUnit is of type org.eclipse.jdt.core.ICompilationUnit)
Deepak Azad
http://wiki.eclipse.org/JDT/FAQ
Re: ASTVisitor - geting line number of MethodDeclaration [message #758626 is a reply to message #758446] Wed, 23 November 2011 18:29 Go to previous messageGo to next message
@Satyam Kandula my problem is that char [] buf does not contain the correct string corresponding to the source code of the methodDeclaration that I want to retrieve. It gets the initial part correctly, but it truncates the final part. That's why I think my problem is the way I'm getting the offset.
@Deepak Azad How do I get a reference to ICompilationUnit?
Re: ASTVisitor - geting line number of MethodDeclaration [message #758839 is a reply to message #758626] Thu, 24 November 2011 11:53 Go to previous messageGo to next message
Is your java file in an Eclipse project? Do you have an IJavaProject or
IProject object? Or are you using JDT/Core standalone ?
Deepak Azad
Re: ASTVisitor - geting line number of MethodDeclaration [message #758858 is a reply to message #758839] Thu, 24 November 2011 14:03 Go to previous messageGo to next message
JDT/Core standalone.
Re: ASTVisitor - geting line number of MethodDeclaration [message #759359 is a reply to message #758858] Mon, 28 November 2011 08:33 Go to previous message
You cannot get the ICompilationUnit in standalone.
The offset should be correct. How much truncation do you see?
Previous Topic:-----------------------
Next Topic:Is running 32bit/64bit Eclipse fine under 64bit Linux?
Current Time: Sun Jul 27 16:28:21 EDT 2025
Powered by FUDForum. Page generated in 0.04388 seconds
