Home » Modeling » Graphiti » Use export diagram to bitmap(Is it possible to use the standard export to bitmap feature for own code?)
Use export diagram to bitmap [message #758427] Wed, 23 November 2011 04:18 Go to next message
I was wondering if it is possible to use the export to bitmap feature for my own code? The reason is that I need to export a rich text document from the diagram contents. The document should contain information about the domain/business model, some model analysis results, and the diagram itself for an overview. Does anybody have an idea how to retrieve the diagram as a bitmap via the Graphiti (or any other) API?
Best,
Georg
Re: Use export diagram to bitmap [message #759389 is a reply to message #758427] Mon, 28 November 2011 09:33 Go to previous messageGo to next message
Hi again,
Georg Hackenberg wrote on Wed, 23 November 2011 10:18
To be more precise: I am talking about the "Export Diagram..." feature, which is accessible via the diagram's context menu.
Maybe there is also an alternative to generating a bitmap programmatically from the diagram via the Graphiti API (e.g. accessing the rendering algorithms directly)?
Best,
Georg
Re: Use export diagram to bitmap [message #768609 is a reply to message #759389] Tue, 20 December 2011 08:08 Go to previous messageGo to next message
Hi again,
a colleague of mine, who is using Draw2D directly, was suggesting to access somehow the editor's IFigure interface. Did anybody try that before? Do you think that might work with Graphiti?
Best,
Georg
Re: Use export diagram to bitmap [message #774756 is a reply to message #768609] Wed, 04 January 2012 09:37 Go to previous message
Hey,
for everybody who faces the same issue: Have a look at the Graphiti source code, in particular the class
org.eclipse.graphiti.ui.internal.action.SaveImageAction
Best,
Georg
Previous Topic:Editor API Changes for Juno M5 (Graphiti 0.9.0)
Next Topic:Palette Layout
Current Time: Sat Jul 26 08:59:33 EDT 2025
Powered by FUDForum. Page generated in 0.04153 seconds
