Home » Modeling » TMF (Xtext) » Combining the IJvmModelInferrer with custom code generation
Combining the IJvmModelInferrer with custom code generation [message #755749] Wed, 09 November 2011 08:21 Go to next message
I am extending Xbase and use the IJvmModelInferrer to map my language to JVM Concepts. This works quite amazing with the resulting generated Java code.
However there are some things that need custom code and cannot be simply mapped.
So my question is how can I customize the code generation already done by Xtext?
~Goran
Re: Combining the IJvmModelInferrer with custom code generation [message #755770 is a reply to message #755749] Wed, 09 November 2011 09:34 Go to previous messageGo to next message
What kind of things are that?
You can add method bodies and field initializers using
JvmTypesBuilder.setBody(JvmExecutable, Function1<ImportManager, ?
extends CharSequence>)
JvmTypesBuilder.initialization(JvmField, Function1<ImportManager, ?
Am 09.11.11 14:21, schrieb Goran:
> code.
> mapped.
> by Xtext?
> ~Goran
Re: Combining the IJvmModelInferrer with custom code generation [message #758372 is a reply to message #755770] Tue, 22 November 2011 17:03 Go to previous messageGo to next message
What I mean is the following. I am using xtend2 for code generation for example:
	return element.toMethod(name, returnType)[
		for(p : element.advice.parameters.parameters) {
			parameters += p.toParameter(p.name, p.parameterType)
		documentation = element.documentation
		final = element.^final
		body = element.body
This causes a method like below to be generated:
  public void before_advice_method() {
      System.out.println("Advice 1");
      this.authenticator.authenticate();
The body of the method can contain arbitrary Java statements from my DSL. I want to include my own code beside the already generated body of Java statements for example instead of "body = element.advice.body" I tried the following:
	body = ['''
		«element.body»
		System.out.println("Some generated custom statement besides the automatically generated statements");
However the «element.body» doesn't cause the proper generation of Java statements. The above leads to the following:
    org.eclipse.xtext.xbase.impl.XBlockExpressionImpl@4772dd46
instead of
How do I cause the XBlockExpressionImpl to be properly converted to Java statements?
Re: Combining the IJvmModelInferrer with custom code generation [message #758377 is a reply to message #758372] Tue, 22 November 2011 17:50 Go to previous messageGo to next message
Have a look at JvmModelGenerator and/or xbasecompiler
Regards Christian
Re: Combining the IJvmModelInferrer with custom code generation [message #758504 is a reply to message #758372] Wed, 23 November 2011 08:48 Go to previous messageGo to next message
> statements?
I've just blogged something similar/related:
"Xtext 2.1: using Xbase expressions"
http://www.rcp-vision.com/?p=1640
hope it helps
cheers
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: Combining the IJvmModelInferrer with custom code generation [message #758849 is a reply to message #758504] Thu, 24 November 2011 12:41 Go to previous messageGo to next message
Thanks Lorenzo,
That's a great blog post indeed. You described a switch to your custom generator instead of the JvmModelGenerator. What was not very clear to me is if we could still use the JvmModelInferrer when using the custom code generator you described. Do you know if this is possible?
I was able to put the following into the JvmModelInferrer which helped:
	val importManager = new ImportManager(true, getJvmType(aspectFQN))
        val mainMethod = compile(element.advice.body, importManager)
        body = ['''
		«mainMethod»
def compile(XExpression xExpression, ImportManager importManager) {
	val result = new StringBuilderBasedAppendable(importManager)
	compiler.toJavaStatement(xExpression, result, true)
	result
However now I also would like to customize the import statements. I know how to do that according to your post however I would like to avoid throwing away my JvmModelInferrer xtend class.
Re: Combining the IJvmModelInferrer with custom code generation [message #758940 is a reply to message #758849] Fri, 25 November 2011 06:04 Go to previous messageGo to next message
On 11/24/2011 06:41 PM, Goran wrote:
> Thanks Lorenzo,
glad you enjoyed it :)
well, I still haven't switched to JvmModelInferrer, but I think that
could be possible... actually I had pointed you to my post just for the
part concerning calling XbaseCompiler explicitly: I didn't mean to point
you to the part concerning using a custom code generator :)
> body = ['''
> «mainMethod»
> result
Re: Combining the IJvmModelInferrer with custom code generation [message #759105 is a reply to message #758940] Sat, 26 November 2011 06:56 Go to previous message
Thanks Lorenzo,
I was able to use both my JvmModelInferrer and custom generator.
I extended the org.eclipse.xtext.xbase.compiler.JvmModelGenerator with a custom implementation. Then I override relevant methods.
public class CustomJvmModelGenerator extends
		org.eclipse.xtext.xbase.compiler.JvmModelGenerator {
	@Inject
	private TypeReferences references;
//override methods
And for the runtime module:
 @SuppressWarnings("all")
public abstract class AbstractAspectJRuntimeModule extends DefaultRuntimeModule {
	public Class<? extends org.eclipse.xtext.generator.IGenerator> bindIGenerator() {
//		return org.eclipse.xtext.xbase.compiler.JvmModelGenerator.class;
		return CustomJvmModelGenerator.class;
Previous Topic:Validator Check Unique Name
Next Topic:[Jvm Model Inferrer]Creating a field from a CrossReference
Current Time: Sat Jul 26 03:00:07 EDT 2025
Powered by FUDForum. Page generated in 0.07051 seconds
