Home » Modeling » GMF (Graphical Modeling Framework) » Saving diagram drawn on the GMF Editor(Saving diagram drawn on the GMF Editor)
Saving diagram drawn on the GMF Editor [message #758207] Tue, 22 November 2011 05:46 Go to next message
Hi All,
Is it possible to save the diagram which is drawn on the GMF Editor ?
Like If I draw some diagram on GMF Editor, When I open it next time I should be able to retrieve the diagram... This would save a lot of time from creating a diagram which is similar to my previous diagram.
Vinay
Re: Saving diagram drawn on the GMF Editor [message #758215 is a reply to message #758207] Tue, 22 November 2011 06:07 Go to previous messageGo to next message
Of course the editor saves and lets you reload what you saved.
On 22/11/2011 11:46 AM, vinny503 wrote:
> Hi All,
> Regards,
> Vinay
Re: Saving diagram drawn on the GMF Editor [message #758228 is a reply to message #758215] Tue, 22 November 2011 06:49 Go to previous messageGo to next message
Vinay,
You just forgot to hit the Save button! I think GMF is all about displaying data and persisting data, if it is not capable of persisting data, then there is no purpose for such a framework.
Hoang.
Re: Saving diagram drawn on the GMF Editor [message #758229 is a reply to message #758215] Tue, 22 November 2011 06:50 Go to previous messageGo to next message
Hi Ed Merks,
Can you please tell me, How to acheive that ? Or Can you please provide any links that gives information on saving the diagram.
Vinay
Re: Saving diagram drawn on the GMF Editor [message #758244 is a reply to message #758228] Tue, 22 November 2011 07:31 Go to previous messageGo to next message
Hi Hoang,
I have hit the save button but we have implemented some logic for our application because of that we are not able to retain the diagram.
Is it possible to have a Project Explorer window where we could save all the diagrams created. Now we are having a property window similarly having another window called Project Explorer which will have all the diagrams saved.
vinay
Re: Saving diagram drawn on the GMF Editor [message #758249 is a reply to message #758229] Tue, 22 November 2011 07:44 Go to previous messageGo to next message
Vinay,
The generated editor supports File->Save.
On 22/11/2011 12:50 PM, vinny503 wrote:
> Hi Ed Merks,
> Regards,
> Vinay
Re: Saving diagram drawn on the GMF Editor [message #758258 is a reply to message #758249] Tue, 22 November 2011 08:20 Go to previous messageGo to next message
Hi Ed Merks,
Why "File->Save As..." is disabled ??
Vinay
Re: Saving diagram drawn on the GMF Editor [message #758263 is a reply to message #758258] Tue, 22 November 2011 08:38 Go to previous messageGo to next message
Vinay,
It's disabled until you make the first change.
On 22/11/2011 2:20 PM, vinny503 wrote:
> Hi Ed Merks,
> Regards,
> Vinay
Re: Saving diagram drawn on the GMF Editor [message #758396 is a reply to message #758263] Wed, 23 November 2011 01:03 Go to previous messageGo to next message
Even after First change it is disabled and I notice that it is never enabled .Please let me know how do I enable it.
Vinay
Re: Saving diagram drawn on the GMF Editor [message #758397 is a reply to message #758396] Wed, 23 November 2011 01:24 Go to previous messageGo to next message
Vinay,
This just works out of the box, so you've changed something, right? You
checked what's going on with isDirty?
On 23/11/2011 7:03 AM, vinny503 wrote:
> Regards,
> Vinay
Re: Saving diagram drawn on the GMF Editor [message #758421 is a reply to message #758397] Wed, 23 November 2011 03:59 Go to previous messageGo to next message
Where I can find isDirty ? And I am trying in a newly created project, I have not changed anything in the RCP code .
Vinay
Re: Saving diagram drawn on the GMF Editor [message #758480 is a reply to message #758421] Wed, 23 November 2011 07:22 Go to previous messageGo to next message
Hi Ed Merks,
I was asking about saving the previous diagram, But Is it possible to save all the diagrams, Like I draw different diagrams whenever I open a GMF Editor, So When I open it next time, Is it possible to retain the diagram which I have drawn 1st. Like saving it in hard disk.
Vinay
Re: Saving diagram drawn on the GMF Editor [message #758497 is a reply to message #758480] Wed, 23 November 2011 08:07 Go to previous messageGo to next message
Vinay,
You seem to be repeating yourself. If you open your generated editor
and hit Ctrl-O twice, you should be able to find the isDirty method.
Every thing a command is executed the editor should test this state again...
On 23/11/2011 1:22 PM, vinny503 wrote:
> Hi Ed Merks,
> Regards,
> Vinay
Re: Saving diagram drawn on the GMF Editor [message #758506 is a reply to message #758497] Wed, 23 November 2011 08:54 Go to previous message
I am able to find isDirty() method in DiagramDocumentEditor class which is being extended by xxxDiagramEditor.java file, But since it is not present in xxxDiagramEditor.java file,So the Save and Save All will be enabled, But Save As...is still disabled.
Vinay
Previous Topic:call of toString() method in xxxImpl.java class in GMF
Next Topic:comboboxcelleditor not firing
Current Time: Thu Jul 24 20:24:12 EDT 2025
Powered by FUDForum. Page generated in 0.07824 seconds
