[Xtend2] floats [message #718458] |
Wed, 24 August 2011 08:02  |
Hi there,
does Xtend2 not support any float primitive type? I could not write any
float literals like 0.0 or 23.789, however, I can assign floats to
variables which I got from somewhere else.
A workaround is
"23.789".float
and defining a getFloat function that uses Float.getValue(String).
There should be something better, should it not?
Hauke
Re: [Xtend2] floats [message #758149 is a reply to message #753849] |
Tue, 22 November 2011 02:08   |
Am 29.10.2011 14:48, schrieb Meinte Boersma:
> Well, decimals are included since the JVM type's available. There's just
> not a literal for it.
Maybe it would help a lot if it were possible to do infix operator
overloading also by extension methods. I.e. I understand so far you have
to define a method for the class you want to overload, e.g.
class Float{
public Float _operator_multiply(final Float other){
return this * other;
However, we cannot change the basic datatype classes, so it would be
nice I could simply write extensions like
class FloatExtensions{
public Float _operator_multiply(final Float e1, final Float e2){
return e1 * e2;
Which I then can use in my Xtend simply the same:
@Inject
extension FloatExtension
def function(Float a, Float b){
return a._operator_multiply(b)
Hence, it would be nice if in this case operator overloading would work
such I could write a * b instead.
Is this a proper feature request or are there arguments against?
Hauke
Re: [Xtend2] floats [message #758322 is a reply to message #758149] |
Tue, 22 November 2011 13:05  |
if you use the proper naming scheme (operator_multiply instead of
_operator_multiply) everything works.
@Inject
extension Floats
def doSomething(float a, float b) {
a * b
def client(Float a, Float b) {
a * b
public class Floats {
public float operator_multiply(float a, float b) {
return a * b;
Sebastian
Need professional support for Xtext, Xtend or Eclipse Modeling?
On Tue, 22 Nov 2011 08:08:46 +0100, Hauke Fuhrmann
> class Float{
> return e1 * e2;
> @Inject
> Cheers,
> Hauke
FUDForum. Page generated in 0.26339 seconds
