Home » Archived » Eclipse Process Manager (Stardust) » Infinity Process Plattform - installation("The operation cannot be completed. See the details.")
icon5.gif  Infinity Process Plattform - installation [message #754497] Wed, 02 November 2011 14:37 Go to next message
Hey there,
I'm new to the forums here.
Before I describe what happens I asure you that I tried to find a solution over the search-function but didn't get a hint.
As I try to install Infinity Process Plattform I get the following describtion from the Install-Window:
Cannot complete the install because one or more required items could not be found.
  Software being installed: Infinity Process Reporting Runtime Feature 6.0.2.2-r49368 (ag.carnot.bpm.reporting.runtime.feature.group 6.0.2.2-r49368)
  Missing requirement: XSD Model 2.6.0.v20100914-1218 (org.eclipse.xsd 2.6.0.v20100914-1218) requires 'bundle org.eclipse.core.runtime [3.6.0,4.0.0)' but it could not be found
  Cannot satisfy dependency:
    From: Infinity Process Reporting Runtime Feature 6.0.2.2-r49368 (ag.carnot.bpm.reporting.runtime.feature.group 6.0.2.2-r49368)
    To: ag.carnot.reporting.common [6.0.2.2-r49368]
    From: Infinity Common Reporting Services 6.0.2.2-r49368 (ag.carnot.reporting.common 6.0.2.2-r49368)
    To: bundle org.eclipse.xsd 2.6.0
How may I get the missing bundle? Or do I need something else? I'm not very firm with eclipse and installing software for the workbench. Do I have to expect more errors?
Thanks in advance!
Deniz
[Updated on: Wed, 02 November 2011 14:37] by Moderator
Re: Infinity Process Plattform - installation [message #754541 is a reply to message #754497] Thu, 03 November 2011 03:09 Go to previous messageGo to next message
Hi Deniz,
Did you do a "Select All" for the components under Infinity Process Platform.
Re: Infinity Process Plattform - installation [message #754594 is a reply to message #754541] Thu, 03 November 2011 08:59 Go to previous messageGo to next message
Yes, I did.
I just followed these instructions:
wiki.eclipse.org/STP/Stardust/KnowledgeBase/GettingStarted/Installation
Re: Infinity Process Plattform - installation [message #754786 is a reply to message #754594] Fri, 04 November 2011 07:04 Go to previous messageGo to next message
Deniz,
I have updated the screenshots in the instructions as per the latest release 6.0.2
Could you please try one more time by following the instructions?
I didn't select 'Visual Rules' during installation as it was not required and these steps are working fine at my end.
Re: Infinity Process Plattform - installation [message #754888 is a reply to message #754786] Fri, 04 November 2011 15:38 Go to previous messageGo to next message
Thanks for updating the instructions, Rohit.
Nevertheless I'm still facing the same problems.
I already tried to locate and install the XSD Model, but I can't find it.
I'll leave a screenshot here and post the details as it isn't completely to see.
I would have posted it now, but there is a "more than 5 messages" barrier.
[Updated on: Fri, 04 November 2011 21:16] by Moderator
Re: Infinity Process Plattform - installation [message #754889 is a reply to message #754888] Fri, 04 November 2011 15:39 Go to previous messageGo to next message
- 5 messages barrier -
Re: Infinity Process Plattform - installation [message #754891 is a reply to message #754889] Fri, 04 November 2011 15:39 Go to previous messageGo to next message
Re: Infinity Process Plattform - installation [message #754892 is a reply to message #754891] Fri, 04 November 2011 15:40 Go to previous messageGo to next message
Screenshot and details:
http://www.abload.de/thumb/infinity7re0c.png
Re: Infinity Process Plattform - installation [message #755060 is a reply to message #754892] Mon, 07 November 2011 04:08 Go to previous messageGo to next message
Hi Deniz,
which Eclipse bundle are you using? It should be Eclipse IDE for Java and Report Developers.
May be you don't have the BIRT plug-ins installed yet, which could lead to error message you get.
Andreas
[Updated on: Mon, 07 November 2011 04:16] by Moderator
Re: Infinity Process Plattform - installation [message #755070 is a reply to message #754892] Mon, 07 November 2011 04:28 Go to previous messageGo to next message
Deniz,
I think Andreas is right. Are you using this:
http://www.eclipse.org/downloads/packages/eclipse-ide-java-and-report-developers/heliossr2
Robert
Re: Infinity Process Plattform - installation [message #758067 is a reply to message #754497] Mon, 21 November 2011 15:32 Go to previous messageGo to next message
Thanks a lot!
Truly I was using the Galileo-Bundle. I actually overread that part in the wiki. Sorry for the inconvenience I caused. Everything is working fine now. Waiting for my license now.
Deniz
Re: Infinity Process Plattform - installation [message #758140 is a reply to message #758067] Mon, 21 November 2011 23:10 Go to previous message
Deniz,
Are you still waiting on the license ?
Previous Topic:Warnings about skipped event handling in Stardust log file
Next Topic:Setting scope for the portal backing bean
Current Time: Wed Jul 23 05:15:43 EDT 2025
Powered by FUDForum. Page generated in 0.14278 seconds
