Home » Newcomers » Newcomers » JSDAI install problem
JSDAI install problem [message #754713] Thu, 03 November 2011 20:28 Go to next message
I'm trying to install and use JSDAI (www.jsdai.net) under ubuntu 11.o4
with Eclipse Ganimede to no avail. The installation message I receive
when installing the plugin is,
Cannot complete the install because one or more required items could not
be found.
Software being installed: JSDAI Express-G Editor 4.3.0.v201010271301
(net.jsdai.express_g.feature.feature.group 4.3.0.v201010271301)
Missing requirement: JSDAI Common 4.1.6.v201010271301 (net.jsdai.common
4.1.6.v201010271301) requires 'bundle org.eclipse.ui [3.6.0,4.0.0)' but
it could not be found
Cannot satisfy dependency:
From: JSDAI ExpressDoc 4.1.6.v201010262121 (net.jsdai.express_doc
4.1.6.v201010262121)
To: bundle net.jsdai.common [4.1.0,5.0.0)
To: net.jsdai.impexpWizards [4.1.3.v200806021255]
From: JSDAI ExpressDoc Import/Export Wizard declarations
4.1.3.v200806021255 (net.jsdai.impexpWizards 4.1.3.v200806021255)
To: bundle net.jsdai.express_doc [4.1.0,5.0.0)
Would anyone know how to help me, please?
Thanks in advance,
Andre Luiz
Re: JSDAI install problem [message #754727 is a reply to message #754713] Fri, 04 November 2011 00:00 Go to previous messageGo to next message
On 11/03/2011 07:28 PM, Andre Luiz Tietbohl Ramos wrote:
> Hello,
> be found.
> From: JSDAI Express-G Editor 4.3.0.v201010271301
> Thanks in advance,
> Andre Luiz
Ganymede is version 3.4 based. It looks like the package you are trying
to install requires at least version 3.6. The current Eclipse version
is at 3.7.
Re: JSDAI install problem [message #756491 is a reply to message #754727] Sun, 13 November 2011 20:14 Go to previous messageGo to next message
Thanks for the response. I installed Indigo Service Release 1 and
received the following error,
be found.
Software currently installed: Shared profile 1.0.0.1316138634362
(SharedProfile_epp.package.java 1.0.0.1316138634362)
Missing requirement: Shared profile 1.0.0.1316138634362
(SharedProfile_epp.package.java 1.0.0.1316138634362) requires
'org.maven.ide.eclipse [1.0.100.20110804-1717]' but it could not be found
I have the following eclipse_indigo executable script,
#!/bin/sh
# work around for e#290395 / LP: #458703
# https://bugs.eclipse.org/bugs/show_bug.cgi?id=290395
# https://bugs.launchpad.net/bugs/458703
export GDK_NATIVE_WINDOWS=true
export MOZILLA_FIVE_HOME="/usr/lib/xulrunner-$(/usr/bin/xulrunner-1.9.2 --
gre-version)"
#ECLIPSE=/usr/lib/eclipse/eclipse
ECLIPSE=/usr/lib/eclipse_indigo/eclipse/eclipse
inject_update_site(){
if [ ! -e "$1" ] ; then
echo "W: Cannot find $1" 2>&1
return 1
fi
cat - >>"$1" <<EOF
repositories/http\:__download.eclipse.org_releases_galileo/enabled=true
repositories/http\:__download.eclipse.org_releases_galileo/isSystem=false
nickname=Galileo Update Site
repositories/http\:__download.eclipse.org_releases_galileo/uri=http\://
download.eclipse.org/releases/galileo/
EOF
if [ ! -d ~/.eclipse/ ] ; then
$ECLIPSE -clean -initialize || exit $?
settings=`echo ~/.eclipse/org.eclipse.platform_*/p2/
org.eclipse.equinox.p2.engine/profileRegistry/
PlatformProfile.profile/.data/.settings/`
if [ ! -d "$settings" ] ; then
echo "W: Cannot inject update-sites, cannot find the correct
config." 2>&1
else
( inject_update_site "$settings/
org.eclipse.equinox.p2.metadata.repository.prefs" && \
org.eclipse.equinox.p2.artifact.repository.prefs" && \
echo "I: Injected update sites" ) || echo "W: Could not inject
update sites." 2>&1
fi
fi
exec $ECLIPSE "$@"
Any further help greatly appreciated,
Andre Luiz
Re: JSDAI install problem [message #756782 is a reply to message #756491] Mon, 14 November 2011 23:54 Go to previous messageGo to next message
On 11/13/2011 07:14 PM, Andre Luiz Tietbohl Ramos wrote:
> Hello,
> be found.
> #!/bin/sh
> gre-version)"
> return 1
> fi
> cat ->>"$1"<<EOF
> EOF
> config." 2>&1
> else
> org.eclipse.equinox.p2.metadata.repository.prefs"&& \
> org.eclipse.equinox.p2.artifact.repository.prefs"&& \
> update sites." 2>&1
> fi
> fi
> exec $ECLIPSE "$@"
> Andre Luiz
The launch script indicates that you installed Eclipse from the Ubuntu
repositories. Don't do this. You will have problems installing
additional software.
Uninstall the Eclipse and download a package directly from the Eclipse
download page.
Re: JSDAI install problem [message #758136 is a reply to message #756782] Mon, 21 November 2011 22:18 Go to previous messageGo to next message
I'm trying to install packages in Eclipse Indigo under Ubuntu 11.04 as
you suggested and receive this error message,
be found.
BTW, I removed all pre-installed eclipse because it was the Ganymede
version. Now, it is installed under /usr/lib/eclipse_indigo/eclipse as
shown below,
andreltr@stech:~$ cd /usr/lib/eclipse
andreltr@stech:/usr/lib/eclipse$ ls
plugins
andreltr@stech:/usr/lib/eclipse$ ls ../eclipse_indigo/
eclipse
andreltr@stech:/usr/lib/eclipse$ ls ../eclipse_indigo/eclipse/
about_files dropins eclipse.ini libcairo-swt.so readme
about.html eclipse epl-v10.html notice.html
artifacts.xml eclipse_indigo features p2
configuration eclipse_indigo~ icon.xpm plugins
Nothing can be installed any longer. Would anyone be able to help me
please?
Thanks in advance,
Andre Luiz
>> Hello,
>> not be found.
>> found
>> #!/bin/sh
>> # work around for e#290395 / LP: #458703 #
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=290395 #
>> https://bugs.launchpad.net/bugs/458703 export GDK_NATIVE_WINDOWS=true
>> -- gre-version)"
>> return 1
>> fi
>> cat ->>"$1"<<EOF
isSystem=false
>> download.eclipse.org/releases/galileo/ EOF
>> $ECLIPSE -clean -initialize || exit $? settings=`echo
>> config." 2>&1
>> else
>> update sites." 2>&1
>> fi
>> fi
>> exec $ECLIPSE "$@"
>> Andre Luiz
> download page.
Re: JSDAI install problem [message #758363 is a reply to message #758136] Tue, 22 November 2011 16:24 Go to previous message
On 11/21/2011 09:18 PM, Andre Luiz Tietbohl Ramos wrote:
> Hello,
> be found.
Eclipse seems to be looking for the Maven plugin. I'm not sure if it is
required by something you are trying to install or something already
installed.
You could try to install the Maven plugin from the Indigo update site.
The version referenced appears to be the current version on the update site.
> shown below,
> plugins
> eclipse
> please?
> Thanks in advance,
> Andre Luiz
>>> Hello,
>>> not be found.
>>> found
>>> #!/bin/sh
>>> -- gre-version)"
>>> return 1
>>> fi
>>> cat ->>"$1"<<EOF
> isSystem=false
>>> config." 2>&1
>>> else
>>> update sites." 2>&1
>>> fi
>>> fi
>>> exec $ECLIPSE "$@"
>>> Andre Luiz
>> download page.
Previous Topic:Workspaces on smb:// URI ?
Next Topic:eclipse workbench help fails
Current Time: Wed Jul 23 16:57:24 EDT 2025
Powered by FUDForum. Page generated in 0.09125 seconds
