Home » Eclipse Projects » EclipseLink » Select from partition ?
Select from partition ? [message #756676] Mon, 14 November 2011 11:08 Go to next message
I have an application running on Oracle and EclipseLink 2.1(if really needed I can upgrade it) using the old ExpressionBuilder api. I would like to optimise a long running query to use only one known partition.
Is it possible to construct a query that use both: a bit of native SQL (From x partition(y)) and ExpressionBuilder api for the rest of query?
Krzysztof Kowalczyk
Re: Select from partition ? [message #758009 is a reply to message #756676] Mon, 21 November 2011 13:12 Go to previous message
It is probably better to use an SQL query then try to mix objects and SQL.
You can use the getTable() API to get a table reference, but I don't think you could generate what you want. EclipseLink's AsOfClause does do something similar in syntax.
James : http://wiki.eclipse.org/EclipseLink : http://en.wikibooks.org/wiki/Java_Persistence : http://java-persistence-performance.blogspot.com/
Previous Topic:Select from partition ?
Next Topic:Problem with @OneToMany from an @Embeddable
Current Time: Wed Jul 23 10:46:02 EDT 2025
Powered by FUDForum. Page generated in 0.09292 seconds
