Home » Eclipse Projects » EclipseLink » IllegalArgumentException: eclipselink.profiler
IllegalArgumentException: eclipselink.profiler [message #756955] Tue, 15 November 2011 12:22 Go to next message
I'm getting an exception I can't seem to get past when trying to deploy Eclipselink as a JPA provider with Spring 3.04 in Tomcat 7 on JDK 6.
I see what "eclipselink.profiler" is, but I don't care about it for the moment, and didn't supply a value for it in the persistence.xml file.
Ideas, anyone? Thanks!
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'entityManagerFactory' defined in ServletContext resource [/WEB-INF/config/abis-web.xml]: Invocation of init method failed; nested exception is javax.persistence.PersistenceException: Exception [EclipseLink-28018] (Eclipse Persistence Services - 1.1.0.r3634): org.eclipse.persistence.exceptions.EntityManagerSetupException
Exception Description: Predeployment of PersistenceUnit [abis-web-abisWebDS] failed.
Internal Exception: java.lang.IllegalArgumentException: eclipselink.profiler
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1420)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:291)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:288)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:190)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:563)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:895)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:425)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:276)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:197)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:47)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4681)
at org.apache.catalina.core.StandardContext$1.call(StandardContext.java:5184)
at org.apache.catalina.core.StandardContext$1.call(StandardContext.java:5179)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
at java.util.concurrent.FutureTask.run(FutureTask.java:138)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
Caused by: javax.persistence.PersistenceException: Exception [EclipseLink-28018] (Eclipse Persistence Services - 1.1.0.r3634): org.eclipse.persistence.exceptions.EntityManagerSetupException
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.predeploy(EntityManagerSetupImpl.java:870)
at org.eclipse.persistence.jpa.PersistenceProvider.createContainerEntityManagerFactory(PersistenceProvider.java:189)
at org.springframework.orm.jpa.LocalContainerEntityManagerFactoryBean.createNativeEntityManagerFactory(LocalContainerEntityManagerFactoryBean.java:225)
at org.springframework.orm.jpa.AbstractEntityManagerFactoryBean.afterPropertiesSet(AbstractEntityManagerFactoryBean.java:308)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1477)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1417)
... 20 more
Caused by: Exception [EclipseLink-28018] (Eclipse Persistence Services - 1.1.0.r3634): org.eclipse.persistence.exceptions.EntityManagerSetupException
at org.eclipse.persistence.exceptions.EntityManagerSetupException.predeployFailed(EntityManagerSetupException.java:210)
... 26 more
Caused by: java.lang.IllegalArgumentException: eclipselink.profiler
at org.eclipse.persistence.internal.sessions.PropertiesHandler$Prop.getPropertyValueToApply(PropertiesHandler.java:253)
at org.eclipse.persistence.internal.sessions.PropertiesHandler.getPropertyValueLogDebug(PropertiesHandler.java:97)
at org.eclipse.persistence.internal.sessions.PropertiesHandler.getPropertyValueLogDebug(PropertiesHandler.java:89)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.updateProfiler(EntityManagerSetupImpl.java:474)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.predeploy(EntityManagerSetupImpl.java:743)
... 25 more
Re: IllegalArgumentException: eclipselink.profiler [message #756990 is a reply to message #756955] Tue, 15 November 2011 16:25 Go to previous messageGo to next message
Looks like you are using EclipseLink 1.1. The code involved changed drastically and seems like it may have been fixed in 1.2, can you try a later version?
Chris
Re: IllegalArgumentException: eclipselink.profiler [message #757993 is a reply to message #756955] Tue, 15 November 2011 16:25 Go to previous message
Chris
Previous Topic:Descriptor Events on Entities which have not been modified during a Transaction
Next Topic:How can I check PersistenceContexts for equality
Current Time: Sun Jul 27 22:24:14 EDT 2025
Powered by FUDForum. Page generated in 0.04719 seconds
