How do I pre-populate a sub-diagram? [message #757857] |
Wed, 16 November 2011 05:01  |
I am working on a project in which I like to pre-populate a diagram with
some elements so that the user can focus on the task in hand. I already
have this working on the main diagram, in this case I have added a
static method *DiagramEditorUtil.createInitialLayout(DiagramEditPart
diagram) that is called by the diagram creation wizard to add and layout
the necessary elements.
When I tried to take the same approach for a sub-diagram (opened using
diagram partitioning) this approach fails. I tried to add the
appropriate method call to the OpenDiagramEditPolicy but the EditParts
that get returned are all DummyEditParts. It seems that the
OpenDiagramEditPolicy does not actually open the diagram itself.
Can anyone suggest where a better place may be to add my call? I cannot
see where in the GMF generated code the opening of the diagram happens,
so I suspect this is buried elsewhere in the stack. Is there a better
place for me to do this? I have been trying to identify a point in the
diagrams lifecycle where I could add the call? Specifically is there a
'do stuff once I'm opened' point that would make sense for me to use?
BTW. I have tried adding the elements directly to the model, and they do
get drawn. However I am not able to control the layout of elements in
using this approach. I still need to find a place suggested above to
control the layout.
I'd rather not leave the diagram looking a mess that the user then has
to sort out.
Thanks for any advice,
Nigel
Re: How do I pre-populate a sub-diagram? [message #757860 is a reply to message #757859] |
Fri, 18 November 2011 08:59   |
One further finding, if I only add nodes to the diagram then even though
I do not see them added to the diagram EditPart the diagram continues to
open and the items I added are there. But because it seems my commands
are not executing until a later point I cannot access the compartments
to add and place nodes that should appear within those EditParts.
On 18/11/2011 13:32, Nigel Daniels wrote:
> further debugging turns up that when I form a request and execute a
> command on the diagram EditPart when setting up the main diagram I can
> see the other EditParts appear as children of the diagram. However when
> I do the same thing with the sub-diagram nothing is added but the
> command seems to have executed ok.
> If any one else has got his to work I could really do with your advice,
> Nigel
> On 16/11/2011 10:01, Nigel Daniels wrote:
>> Hi,
>> control the layout.
>> to sort out.
>> Nigel
Re: How do I pre-populate a sub-diagram? [message #758777 is a reply to message #758324] |
Thu, 24 November 2011 09:15  |
Hi Hoang,
I have not found a solution to the problem but I have found a
workaround. I created a command triggered by a pop-up menu item that
appears when the element I want to expand into a sub-diagram is
right-clicked. I have then manually implemented code that is similar to
the OpenDiagramBehaviour. I have also removed the original
OpenDiagramBehavior so I am programatically inserting the DiagramFacets
as I need them.
A side effect of this approach is this would allow me to open multiple
sub-diagrams from the same point. While it's a neat side effect it makes
the user experiance a bit less intuative than I would like.
I hope this helps,
Nigel
On 22/11/2011 18:15, Hoang wrote:
> This is a good idea. I am looking for the same solution for this problem.
> Have you found the solution? Could you please post the sample code so
> that others can take a look at it?
> Thanks.
FUDForum. Page generated in 0.04524 seconds
