Home » Archived » BIRT » Integration with Active Directory?
Integration with Active Directory? [message #757362] Thu, 17 November 2011 18:23 Go to next message
I've seen before that there was a problem in AD integration and was wondering if that is now possible to do? Is there a module or something else to be added to the installation to make integration with AD possible?
Thanks.
Re: Integration with Active Directory? [message #757390 is a reply to message #757362] Fri, 18 November 2011 03:23 Go to previous messageGo to next message
.rptdesign files in birt-viewer, all in Tomcat.
SQL Server is the db.
Anything? Free?
Thanks.
Re: Integration with Active Directory? [message #757458 is a reply to message #757390] Fri, 18 November 2011 09:00 Go to previous messageGo to next message
What are you needing? Are you trying to read data from an active directory?
Jason
Re: Integration with Active Directory? [message #757471 is a reply to message #757458] Fri, 18 November 2011 10:08 Go to previous messageGo to next message
Hello Jason.
What we need is reports data output filtering corresponding to the groups in AD.
Example with boss and employee looking at the same report, but getting data related to their position (Employee sees only his/hers data, boss sees everything), or management in US receives only data related to US sales and management in Europe gets European sales. Data coming from the same db and from the same run of the report.
Thank you Jason.
[Updated on: Fri, 18 November 2011 10:08] by Moderator
Re: Integration with Active Directory? [message #757834 is a reply to message #757471] Fri, 18 November 2011 12:03 Go to previous messageGo to next message
Is the data secured by a column with user or by connection? Open Source
BIRT does not have a direct integration with AD, but you may be able to
call it from java using something like what is described here:
http://www.myhomepageindia.com/index.php/2009/09/16/active-directory-access-authentication-using-ldap-and-java.html
You could call it in the beforeOpen script of your dataset and then use
the returned information in your query, or the beforeOpen script of your
data source and use the information in your data source. BTW Actuate
has integration with Active Directory if you are interested in a
commercial application.
Jason
On 11/18/2011 10:08 AM, nlajka wrote:
> Hello Jason.
> groups in AD.
> Thank you Jason.
Re: Integration with Active Directory? [message #759059 is a reply to message #757834] Fri, 25 November 2011 16:05 Go to previous messageGo to next message
Happy Thanksgiving Jason.
Thank you for your answer.
Regarding Actuate, I am not the one that makes that type of decision over here.
However, I am pretty sure that getting an idea regarding regarding pricing and possibilities wouldn't be a mistake.
Once again, Happy Thanksgiving to all.
Re: Integration with Active Directory? [message #759460 is a reply to message #759059] Mon, 28 November 2011 13:21 Go to previous message
Just use the "contact us" link on
http://www.birt-exchange.org/org/home/ to get some info.
Jason
> over here. However, I am pretty sure that getting an idea regarding
Previous Topic:reportContext.getLocale()
Next Topic:Slow concurrent report generation
Current Time: Wed Jul 23 15:30:53 EDT 2025
Powered by FUDForum. Page generated in 0.05435 seconds
