Home » Archived » BIRT » How to display how much resources BiRT is using to generate a report?
How to display how much resources BiRT is using to generate a report? [message #757788] Mon, 21 November 2011 12:08 Go to next message
Hello All,
I'm hoping someone has seen this before.
I am currently writing reports that use very large >10MB flatfiles as their source file.
Depending on the amount of data used, specifically too much, and BiRT will either crash with a java heap error (my xmxx settings are already close to system capacity in eclipse.ini) or the reports will not finish, HTML just hangs at a certain point.
I used to have an icon in BiRT that would display the amount of memory used by the report, but I am unable to find it.
Is there any other way to find out what resources are consumed by BiRT from inside Eclipse? I am trying to use something more accurate than the OS tools.
I have found a work around solution by throwing bigger,faster hardware at the reports, but that isn't a solution a can always use.
Any suggestions would be great.
H
Re: How to display how much resources BiRT is using to generate a report? [message #758101 is a reply to message #757788] Mon, 21 November 2011 16:28 Go to previous messageGo to next message
Download this zip file:
http://www.birt-exchange.org/org/devshare/deploying-birt-reports/1344-eclipsecon-2011-api-examples/
extract the birt metal ppt and look at slide 21 which contains memory
configuration options for the data engine. You can set them in script like:
importPackage(Packages.org.eclipse.birt.data.engine.api);
importPackage(Packages.java.lang);
//lower memory used before disk writing from 10mb to 2mb per query
reportContext.getAppContext().put( DataEngine.MEMORY_BUFFER_SIZE, new
Integer(2) );
Jason
On 11/21/2011 12:08 PM, henry.golas wrote:
> Hello All,
> their source file.
> OS tools.
> H
Re: How to display how much resources BiRT is using to generate a report? [message #758102 is a reply to message #758101] Mon, 21 November 2011 16:28 Go to previous messageGo to next message
BTW put the script in the beforeFactory.
> Integer(2) );
> Jason
>> Hello All,
>> their source file.
>> OS tools.
>> Thanks,
>> H
Re: How to display how much resources BiRT is using to generate a report? [message #758535 is a reply to message #758102] Wed, 23 November 2011 10:35 Go to previous messageGo to next message
Jason,
Thanks for the response. Please excuse my coding ignorance, I can use Report Designer but haven't dived into scripting.
I've tried adding the following piece of code in "beforeFactory"
reportContext.getAppContext().put( DataEngine.MEMORY_BUFFER_SIZE, new Integer(2) );
I also tried with this line:
reportContext.getAppContext().put( DataEngine.DATA_SET_CACHE_ROW_LIMIT, new Integer(-1) );
And I am not getting any significant performance improvements.
Any other recommendations?
H
Re: How to display how much resources BiRT is using to generate a report? [message #758543 is a reply to message #758535] Wed, 23 November 2011 10:50 Go to previous message
You have the code in the right place.
The value has to be a non-negative integer. You could try 0 but I doubt that will help. Can you try a larger number like 20 and see if it errors out quicker.
Jason
Previous Topic:IncompatibleClassChangeError when running in JBOSS
Next Topic:reportContext.getLocale()
Current Time: Sun Jul 27 03:23:23 EDT 2025
Powered by FUDForum. Page generated in 0.23599 seconds
