Home » Archived » M2M (model-to-model transformation) » Incorrect output HOT
Incorrect output HOT [message #757633] Sun, 20 November 2011 12:26 Go to next message
Hello all
I am currently trying to to write a HOT that takes as input a weaving model (conforming to my own weaving meta model) and two uml class diagrams. (These two diagrams are also the left and right models for the weaving model.) As output an ATL transformation should be created. But this does not work. As output I get an ATL file but on opening I am presented with the XMI version of the transformation instead of ATL code. Consequently the ATL file does not compile.
I am assuming that there is some sort of syntax error in the resulting transformation causing this behaviour. Is this a correct assumption?
The used HOT looks as follows:
-- @path AMW=/WeavingToTransformation%20HOT/WeavingMetaModel.ecore
-- @path ATL=platform:/plugin/org.eclipse.m2m.atl.common/org/eclipse/m2m/atl/common/resources/ATL.ecore
module weavingToTransformation;
create transformation : ATL from weavingModel : AMW, left : UML, right : UML;
rule ModuleCreation {
	from
		input: AMW!Module
	to
		output: ATL!Module (
			name <- input.name,
			inModels <- input.leftModel,
			outModels <- input.rightModel,
			elements <- input.rules,
			isRefining <- false,
			commentsBefore <- Set {'-- @atlcompiler atl2010'}
rule LeftModelRef {
	from
		input: AMW!LeftModelRef
	to
		output: ATL!OclModel (
			name <- input.name,
			metamodel <- ametamodel
		ametamodel: ATL!OclModel (
			name <-'UML',
			elements <- UML!Classifier.allInstancesFrom('left')
rule RightModelRef {
	from
		input: AMW!RightModelRef
	to
			name <- input.name,
			name <- 'UML',
			elements <- UML!Classifier.allInstancesFrom('right')
rule Classifiers {
	from
		element: UML!Classifier
	to
		atl: ATL!OclModelElement (
			name <- element.name
This HOT is based on examples I found on the web and the WeavingSpectoATL HOT included in AMW. The only differences are that I use UML as metamodel instead of MOF and that I us a different weaving meta model, although it has mostly a similar structure as mmw_qatl.
I am aware that this HOT is not yet complete and it misses, among other things, a rule to create rules. This HOT is a work in progress but since I don't get a valid atl file as output I thought I try to solve this problem first.
Any pointers in the right direction would be appreciated.
Re: Incorrect output HOT [message #757729 is a reply to message #757633] Mon, 21 November 2011 06:34 Go to previous messageGo to next message
An ATL transformation is just the textual version of an ATL model.
When you create a HOT, you create an ATL model that is stored in XMI. To transform it to its corresponding textual version, you have to use the ATL extractor.
For example in ANT you'd do :
<atl.saveModel model="myATL" path="outputs/SavingMySample.atl">
<extractor name="ATL"/>
</atl.saveModel>
Re: Incorrect output HOT [message #757765 is a reply to message #757729] Mon, 21 November 2011 10:06 Go to previous message
Sylvain EVEILLARD wrote on Mon, 21 November 2011 12:34
</atl.saveModel>
Ok I am feeling rather stupid now. Many thanks for the help.
Previous Topic:[ATL] Problems with EMF-Specific VM and Regular VM
Next Topic:[ATL] Unicode string literals in transformation
Current Time: Thu Jul 24 18:46:28 EDT 2025
Powered by FUDForum. Page generated in 0.03848 seconds
